din_dout_pintable
!!! MIOS DIN/DOUT Pin Numbers
Sometimes the pin numbers of special DINs or DOUTs can be specified in the main.asm or setup_*.asm file of a MIOS application.
Examples: #define DEFAULT_MIDI_RX_LED 0x40 ; DOUT SR#9, pin D0 #define DEFAULT_MIDI_TX_LED 0x41 ; DOUT SR#9, pin D1 or #define DEFAULT_DIN_MENU_EXEC 7 ; menu exec button assigned to DIN pin #7 #define DEFAULT_DIN_MENU_SNAPSHOT 6 ; menu snapshot button assigned to DIN pin #4 #define DEFAULT_DIN_MENU_RIGHT 5 ; NOT USED - overlayed by datawheel #define DEFAULT_DIN_MENU_LEFT 4 ; NOT USED - overlayed by datawheel or ;; SR Pin Mode ENC_ENTRY 5, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 5, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 5, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 5, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4
The following table should give you a quick overview over the numbers. Please bear in mind that we are sometimes counting from 0, and sometimes from 1.
Means: sometimes the first pin or shiftregister has number 0, sometimes it has number 1 - thats always an issue, because programmer mostly prefer to count from 0, users want to count from 1 - it's a bit of a mess! Forgive me! ;-)
In the meantime I've tried to make the setup more consistent. Shiftregisters are always counted from 1, and pins are always counted from 0
Ok, here the table:
Shift Register SR number Pin Name Pin Number Hex number
first 1 D0 0 0x00
first 1 D1 1 0x01
first 1 D2 2 0x02
first 1 D3 3 0x03
first 1 D4 4 0x04
first 1 D5 5 0x05
first 1 D6 6 0x06
first 1 D7 7 0x07
second 2 D0 8 0x08
second 2 D1 9 0x09
second 2 D2 10 0x0a
second 2 D3 11 0x0b
second 2 D4 12 0x0c
second 2 D5 13 0x0d
second 2 D6 14 0x0e
second 2 D7 15 0x0f
third 3 D0 16 0x10
third 3 D1 17 0x11
third 3 D2 18 0x12
third 3 D3 19 0x13
third 3 D4 20 0x14
third 3 D5 21 0x15
third 3 D6 22 0x16
third 3 D7 23 0x17
fourth 4 D0 24 0x18
fourth 4 D1 25 0x19
fourth 4 D2 26 0x1a
fourth 4 D3 27 0x1b
fourth 4 D4 28 0x1c
fourth 4 D5 29 0x1d
fourth 4 D6 30 0x1e
fourth 4 D7 31 0x1f
fifth 5 D0 32 0x20
fifth 5 D1 33 0x21
fifth 5 D2 34 0x22
fifth 5 D3 35 0x23
fifth 5 D4 36 0x24
fifth 5 D5 37 0x25
fifth 5 D6 38 0x26
fifth 5 D7 39 0x27
sixth 6 D0 40 0x28
sixth 6 D1 41 0x29
sixth 6 D2 42 0x2a
sixth 6 D3 43 0x2b
sixth 6 D4 44 0x2c
sixth 6 D5 45 0x2d
sixth 6 D6 46 0x2e
sixth 6 D7 47 0x2f
seventh 7 D0 48 0x30
seventh 7 D1 49 0x31
seventh 7 D2 50 0x32
seventh 7 D3 51 0x33
seventh 7 D4 52 0x34
seventh 7 D5 53 0x35
seventh 7 D6 54 0x36
seventh 7 D7 55 0x37
eighth 8 D0 56 0x38
eighth 8 D1 57 0x39
eighth 8 D2 58 0x3a
eighth 8 D3 59 0x3b
eighth 8 D4 60 0x3c
eighth 8 D5 61 0x3d
eighth 8 D6 62 0x3e
eighth 8 D7 63 0x3f
ninth 9 D0 64 0x40
ninth 9 D1 65 0x41
ninth 9 D2 66 0x42
ninth 9 D3 67 0x43
ninth 9 D4 68 0x44
ninth 9 D5 69 0x45
ninth 9 D6 70 0x46
ninth 9 D7 71 0x47
tenth 10 D0 72 0x48
tenth 10 D1 73 0x49
tenth 10 D2 74 0x4a
tenth 10 D3 75 0x4b
tenth 10 D4 76 0x4c
tenth 10 D5 77 0x4d
tenth 10 D6 78 0x4e
tenth 10 D7 79 0x4f
eleventh 11 D0 80 0x50
eleventh 11 D1 81 0x51
eleventh 11 D2 82 0x52
eleventh 11 D3 83 0x53
eleventh 11 D4 84 0x54
eleventh 11 D5 85 0x55
eleventh 11 D6 86 0x56
eleventh 11 D7 87 0x57
twelfth 12 D0 88 0x58
twelfth 12 D1 89 0x59
twelfth 12 D2 90 0x5a
twelfth 12 D3 91 0x5b
twelfth 12 D4 92 0x5c
twelfth 12 D5 93 0x5d
twelfth 12 D6 94 0x5e
twelfth 12 D7 95 0x5f
thirteenth 13 D0 96 0x60
thirteenth 13 D1 97 0x61
thirteenth 13 D2 98 0x62
thirteenth 13 D3 99 0x63
thirteenth 13 D4 100 0x64
thirteenth 13 D5 101 0x65
thirteenth 13 D6 102 0x66
thirteenth 13 D7 103 0x67
fourteenth 14 D0 104 0x68
fourteenth 14 D1 105 0x69
fourteenth 14 D2 106 0x6a
fourteenth 14 D3 107 0x6b
fourteenth 14 D4 108 0x6c
fourteenth 14 D5 109 0x6d
fourteenth 14 D6 110 0x6e
fourteenth 14 D7 111 0x6f
fifteenth 15 D0 112 0x70
fifteenth 15 D1 113 0x71
fifteenth 15 D2 114 0x72
fifteenth 15 D3 115 0x73
fifteenth 15 D4 116 0x74
fifteenth 15 D5 117 0x75
fifteenth 15 D6 118 0x76
fifteenth 15 D7 119 0x77
sixteenth 16 D0 120 0x78
sixteenth 16 D1 121 0x79
sixteenth 16 D2 122 0x7a
sixteenth 16 D3 123 0x7b
sixteenth 16 D4 124 0x7c
sixteenth 16 D5 125 0x7d
sixteenth 16 D6 126 0x7e
sixteenth 16 D7 127 0x7f
din_dout_pintable.1139183507.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
