dip_switch
                A series of tiny switches built into circuit boards. The housing for the switches, which has the same shape as a chip, is the DIP. An acronym for Dual Inline Package, DIP switches enable you to configure a circuit board for a particular type of computer or application. The installation instructions should tell you how to set the switches. DIP switches are always toggle switches, which means they have two possible positions, on or off. (Instead of on and off, you may see the numbers 1 and 0. See binary.)
dip_switch.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
