dipboardf4
dipBoardF4
MIDIbox Hardware Platform extension for dipCoreF4.
Features
- Very small size 65x46mm(less than your credit card).
- Very low profile.
- Your application board can be stacked on bottom with 'Micro-match' connectors.
- The dipCoreF4 can be installed on the two side.
- Provides all the most important features and ports for regular mbhp.
Dimension
PCB
BOM
version 1. Mouser BOM:toDo
| Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | Other | Notes |
| Resistors | ||||||||
| 2 | 680R 5% | 0603 | R1, R2 | 667-ERJ-PA3J681V | Depends on Leds | |||
| 4 | 1K 5% | 0603 | R3, R4, R5, R6 | 755-ESR03EZPJ102 | R3 if you use CAN without transceiver | |||
| PTC fuses, resettable thermistors | ||||||||
| 1 | 1206L150THWR | 1206 | F1 | 576-1206L150THWR | ||||
| Capacitors | ||||||||
| 1 | 100n | 0603 | C2 | 710-885012206071 | ||||
| 1 | 47u | SMC_B | C1 | 581-F931C476MBA | ||||
| Diode | ||||||||
| 1 | 1N4148WS | SOD323-W | D1 | 512-1N4148WS | Only if you use CAN without transceiver | |||
| LEDs | ||||||||
| 2 | – | 0805 | 5V, 3V3 | 755-SML-H12U8TT86C | ||||
| dipCoreF4 socket | ||||||||
| 2 | 1×20 | low profile female | 517-929870-01-20-RA | for pads 1 to 40 | ||||
| 2 | 1×5 | low profile female | 517-929870-01-05-RA | for pads 41 to 50 | ||||
| 1 | 1×2 | low profile female | 517-929870-01-02-RA | for pads 51 to 52 | ||||
| Connector | ||||||||
| 1 | micro-match 2×6 | Female | J1A | 571-8-215079-2 or 571-1-2178710-2 (value line) | Place on top | |||
| 3 options available for PORTs connectors(depends on you app.) | ||||||||
| Option 1 - Regular Shrouded Headers | ||||||||
| 3 | 2×3 | Male | J5, J11, J18 | 710-61200621621 | Place on top | |||
| 4 | 2×5 | Male | J4, J8/9, J15, J19 | 710-61201021621 | Place on top | |||
| 1 | 2×7 | Male | J16E | 710-61201421621 | Place on top | |||
| Option 2 - Stacking Micro-Match Connector | ||||||||
| 1 | 2×2 | Female | J1B | 571-7-215079-4 or 571-2178710-4 (value line) | Place on bottom | |||
| 3 | 2×3 | Female | J5, J11, J18 | 571-215079-6 or 571-2178710-6 (value line) | Place on bottom | |||
| 4 | 2×5 | Female | J4, J8/9, J15, J19 | 571-12150790 or 571-1-2178710-0(value line) | Place on bottom | |||
| 1 | 2×7 | Female | J16E | 571-8-215079-4 or 571-1-2178710-4 (value line) | Place on bottom | |||
| Option 3 - Micro-Match Paddle Board for low profile connector | ||||||||
| 3 | 2×3 | IDC | J5, J11, J18 | 571-7-215570-6 | Place on top | |||
| 4 | 2×5 | IDC | J4, J8/9, J15, J19 | 571-8-215570-0 | Place on top | |||
| 1 | 2×7 | IDC | J16E | 571-8-215570-4 | Place on top | |||
Ports and features.
toDo
Compatible/stack-able boards options
- All uCapps mbhp modules are compatibles.
- USB, SD-Card, External Power and MCAN modules are available.
- M16 Interface, stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO
For any questions, informations or observations do not hesitate to contact me (Forum).
Antichambre.
dipboardf4.1538916383.txt.gz · Last modified: 2018/10/07 12:46 by antichambre
