dipcoref4
dipCoreF4
Features
- MIOS32 uses same processor family and drivers(no deep change).
- Same internal hardware as Disco or wCore (speed, memory, peripherals, etc…) .
- Board pinout and package compatible with a MIOS8 PIC
- USB connector onboard. 2 OTG are available, second(new) USB is Host only.
- 5V power input and led.
- 3.3V regulator and led on board.
- 74HCT541 on board for the 5V output ports.
- User and Reset buttons.
- 2 user leds.
- 12 extra pins for USB, buttons and leds.
- Your favorite Core is now a current component easy to integrate.
All commons MIOS32 ports are available except:
- General purpose J10x ports were removed.
- LCD port was reduced to a serial one, no more pins J15.D0-D7 , no back-light power supply.
- 2 UART only(2 MIDI In/2Out).
- 2 AIN channels only(e.g. pedal inputs).
- SPI slave only supported by J19(SPI3).
Check the dipBoardF4 for more details
Download
dipCoreF4 eagle lib for easy integration in your design. dipcoref4_beta.zip
PCB
BOM
Mouser BOM version 1to complete
| Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | LCSC | Notes |
| Resistors | ||||||||
| 1 | 100R 5% | 0603 | R3 | 755-ESR03EZPF1000 | C253328 | |||
| 4 | 680R 5% | 0603 | R1, R2, R8, R9 | 667-ERJ-PA3J681V | C103784 | Depends on Led | ||
| 4 | 10K 5% | 0603 | R4, R5, R6, R7 | 755-ESR03EZPJ103 | C103199 | |||
| 1 | 100K 5% | 0603 | R11 | 755-ESR03EZPJ104 | C103211 | |||
| PTC fuses, resettable thermistors | ||||||||
| 1 | 1206L150THWR | 1206 | F1 | 576-1206L150THWR | C261956 | |||
| Capacitors | ||||||||
| 2 | 20p | 0603 | C12, C13 | 581-06035A200K | C91702 | |||
| 9 | 100n | 0603 | C2, C5, C6, C7, C8, C9, C14, C15, C16 | 80-C0603C104Z3V | C1688 | |||
| 3 | 2,2u | 0603 | C4, C10, C11 | 81-GRM188R61E225MA2D | C71001 | |||
| 1 | 10u Tantalum | SMC_A(1206) | C3 | 647-F931C106MAA | C8015 | |||
| 1 | 47u Tantalum | SMC_B(1210) | C1 | 74-TMCMB1C476MTRF | C112105 | |||
| Crystal | ||||||||
| 1 | 8MHz | 3.2×2.5_KX-7 | Q1 | oups! Not easy to find :( | wait! | will be changed… | ||
| LEDs | ||||||||
| 4 | – | 0805 | 5V, 3V3, L1, L2 | 755-SML-H12U8TT86C | C72037 | |||
| ICs | ||||||||
| 1 | STM32F405RG | LQFP64 | IC1 | 511-STM32F405RGT6 | C15742 | |||
| 1 | 74HCT541 | TSSOP20 | IC2 | 771-74HCT541PW-T | C131314 | |||
| 1 | LD1117AS33TR | SOT223 | REG | 511-LD1117AS33 | C126055 | |||
| Switches | ||||||||
| 2 | Micro Switches | KMR2 4.6×2.8 | RESET, USER | 611-KMR221NGLFS | C72443 | SMT Tact Switches | ||
| Headers | ||||||||
| 3 | 1*20 | male | 649-68000-420HL | C50981 | Termination Post Length max 2.57mm | |||
| Connnector | ||||||||
| 1 | mini-USB | THT | USB | 571-1734510-1 | no! | for other ref take care about restricted area! | ||
Pinout
First, was a chart.
The dipCoreF4 and the legacy MIOS32 ports.
Check dipBoardF4 for more details about the connectors.
407VG vs 405RG
The 405RG is a TQFP64, a 10x10mm package and only 64 pins.
No Ethernet MAC and camera interface.
In MIOS32
We use the same peripheral drivers same family, some compilation defined conditions were added for the specific pinout and type, number of ports.
toDo
dipcoref4.1585673822.txt.gz · Last modified: 2020/03/31 16:57 by antichambre
