doutx2dinx1
DinX2DoutX1
it gives;
16 Digital Inputs
8 Digital Outputs
The Board is fully SMD, and made for pick and place - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build, or order any component
you need this PCB 1x for OpenPAD
BOM
Follwing list is for reference, and debugging only, no need to order them! all the parts are already soldered on the PCB!
qty reference value jlc
5 C1, C3, C4, C5, C6 100n C307331 81-GRM155R61E104KA7J
1 C2 10uF C440198 81-GRM21BR61H106KE3K
2 DIN1,DIN2 Gates C124391 649-1012938391001ALF
3 DOUT1, Jin8/1, Jout8/9 DIN/DOUT C124391 649-1012938391001ALF
1 IC1 74HC595 C5947 595-SN74HC595DR
2 IC5, IC6 74HC165 C5613 595-SN74HC165DRG3
18 R1-R18 10K C25744 303-0402WGF1002TCE
8 R19-R26 220 C25294
To Do
waiting for the assembled Prototype
Community users working on it
  • Phatline = PCB & Shematic, UI-Programming, Documentation…
doutx2dinx1.1673226542.txt.gz · Last modified: 2023/01/09 01:09 by phatline
