electronics_diy_common_tools
DIY Common Tools for Electronics
You will find Here a List of Common Tools Used For Electronics DIY.
You don't absolutely need to have all of these things, but it sure helps!
Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :)
General / Safety
General
- Workbench - Protect your house, have a proper work area
- Storage Unit - Put your tools and components somewhere safe
- Small Plastic Cups - Somewhere to put things temporarily. Don't leave your kit lying around.
Safety
- Safety Glasses - Protect your sense of sight
- Face mask - Protect your lungs
- Fire Extinguisher - Don't let your soldering iron start a fire you can't put out
- Fire Blanket - As above
- Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm…. I think not.
Electrical Instruments
- Multimeter - For testing circuitry Voltages, Resistors and Transistors
- Oscilloscope - For testing signals. Dual trace is better , allow signals comparison
- Power Supply - Regulated lab power supply . Help in getting the right Voltages inputs
Video Tutorials
Soldering
- Soldering Iron or Station with Stand- Temperature controlled
- Solder - Good quality solder for good quality joints, 63/37 Eutectic
- Desoldering Pump - - For removing soldered chips
- Soldering Iron Tip Cleaner - Take care of your tools
- Tinning Block - for taking care of soldering iron tips
- PCB Holders - Make soldering easier and cleaner
Trimming and Fastening
- Cutters - For trimming componenet leads
- Screwdriver Set - Various sizes
- IC Puller / Placer
- Wire Strippers - For stripping insulation from cabling
- Pliers Set - Various Sizes and types
- Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach
- IDC Crimping Tool - Because doing it with pliers sucks
- Electrical Tape
Misc
- Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach
- Compressed Air Can - For cleaning stuff by blasting off dust
electronics_diy_common_tools.txt · Last modified: 2016/07/19 15:07 by psykhaze
