fadercore_-_vlr-8enc
Fadercore
Standard 220mm wide modules
VLR-8Enc
A PCB to add 8 Encoders with LED ring for each.
Eagle Files: https://github.com/novski/Midibox/tree/master/VLR-8Enc
BOM
BIll of Material
Qty Value Device Package
- 2 ML10 ML10
- 2 ULN2803SO18W SO18W
- 3 100n C-EU025-024×044 C025-024×044
- 6 100nF C-EU025-024×044 C025-024×044
- 6 10k 4306R SIL6
- 4 220 4816P-1SOIC16W SOIC16W
- 3 220 R-EU_0204/7 0204/7
- 3 74HC165N 74HC165NSO16D SO16D
- 3 74HC595 74HC595SO16D SO16D
- 8 BOURNS_PEL12T BOURNS_PEL12T_11-LED-RING PEL12T_11-LED-RING
- 3 TPIC6B595 TPIC6B595SO20W SO20W
Allways look for the cheapest seller, the Price may vary heavy!!! And look for Local dealers preferred. http://www.midibox.org/dokuwiki/doku.php?id=where_to_order_components
The Encoders
I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. Its not the cheapest but i sell them for a reasonable price.
The other Materials: Mouser
- 2x10pin Header, 517-30310-6002
- 1xResistor Array 220Ohm SMD,
- 1x74HC595 SMD,
- 2x100nF,
Project Order Basket on Mouser: fadercore_-_vlr-8enc
The PCB is available under: https://vlrlab.com/pcb/10-8-odisplay.html
How to get Started
Prepare the PCB
Prepare the Connection
Test it in MIOS
fadercore_-_vlr-8enc.1406384920.txt.gz · Last modified: 2014/07/26 14:28 by novski
