home:project:midibox_fm
MIDIbox FM
 Update Things
Intro
MIDIBox FM Synthesiser is a project that uses OPL3 FM soundchips (found from many old soundcards) controlled by MIDIBox as a standalone synthesizer.
Features
List 'em
Skills / Equipment Required
Hardware
What modules do I need?
Adjust List as required:
Parts List
List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links
Soundcards
A list of soundcards with YMF262 and/or YAC512 chips
Connections
Connection diagrams
Control Cable Timing Issue
It was been noted on this forum article that errors can surface if the control cable between CORE and OPL3 boards is too long.
- The error shown in the forum article was found when running the testtone application.
- The specific error in the forum article that tone can be heard on outputs 1&2, but not outputs 3&4, however there is no guarantee that this is the only such error that could arise from long cable.
- The error was solved by shortening the control cable between CORE and OPLE3 boards. The cause was confirmed by switching back to a longer cable, at which point the error re-surfaced.
- The error was shown to be on the control cable (RS/A0/A1/WR), not the data cable (D0-D7), however it is advisable to make both these cables as short as is practicable.
Enclosure / Case
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
Enclosure References
Software
Setting Up
We recommend you read software before you continue.
Download
Links
Setup Instructions
Up to you
Extra
home/project/midibox_fm.txt · Last modified: 2016/06/27 12:55 by psykhaze
