mb-lre8x2cs_pcb_bulk_order
IMPORTANT FOR BULK ORDER LATECOMERS !
This bulk order is officialy closed but I have bought some extra PCBs for latecomers. If you want ones, email me (jeromebo at free dot fr) the quantity you would like and your personal informations:
  • Midibox username
  • Paypal mail address
  • Real name
  • Postal address
  • Country
  • Level of shipping insurance you want to take.
The price of each board is 9€ (I had to buy extra shipping material) and the Paypal fee on the total is 6.5% (with 5% I lost money).
MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface
Welcome to the wiki page of the bulk order of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders.
You can find the tread of this bulk order here.
You can find the tread of the PCB design here.
This bulk order concern the last revision of the PCB that is rev 2.4.
The price is 14€ 11€ 9€ 8,50€ each PCB (+ shipping) - This price can be slightly less expensive regarding number of boards ordered -.
PCB
Top side: Encoders and LEDs.
The PCB is two sides white silkscreened on green FR4 material, 1.6mm thickness, 1Oz copper, HASL, 100% E-tested & ROHS compliant.
The board is 3,368 x 13,472 inch (342,2mm x 85,5mm): just less than 2U standard.
The diameter of each LEDring is 1,299 inch (33 mm) with the use of 3mm LED.
Pictures
Protoboard (note this is not the last version but has same dimensions and LEDs/Encoders positioning):
PCB
PCB
PCB
PCB
PCB
Protoboard in action:
PCB
PCB
PCB
PCB
You can see the LEDring animation in this poorly quality video.
Dimensions
Board
Layout
Layout
Silkscreen
You can download Top silkscreen here.
You can download (mirrored) Bottom silkscreen here.
Schematic
Schematic
Coordinates
LEDs/Encoders
You will find the coordinates of LEDs/Encoders in this files (new version with better accuracy positioning!).
3mm board holes
X Y
0,16 0,16
6,736 0,16
13,312 0,16
0,16 3,208
6,736 3,208
13,312 3,208
BOM
QuantityDevicePartsREICHELTMOUSERNote
2ULN2803 Transistors Darlington arraysULN2803#1, ULN2803#2ULN 2803A595-ULN2803ANoptional
810k 6 Pin SIL resistor networkRN3, RN4, RN5, RN6, RN7, RN8, RN9, RN10SIL 6-5 10K264-10K-RC
474HC165IC1, IC2, IC3, IC474HC 165511-M74HC165
474HC595SR1, SR2, SR3, SR474HC 595511-M74HC595
8Ceramic Cap 100nF=0,1uF “104”C1, C2, C3, C4, C6, C7, C8, C9Z5U-2,5 100n80-C412C104K5R
1Polarized Electrolytic Capacitor 100 uFC5rad 100/16140-REA101M1CBK0611P
2220 Ohm 16 Pin DIL resistor networkRN1, RN2-652-4116R-1LF-220or 16x Resistor 220 Ohm
16220 Ohm metal film resistor8 for RN1, 8 for RN2METALL 220MF1/4DCT52R2200FInstead the 2 RNs above
22-row DIL Header (2×5 pins)“IN”, “OUT”SL 2X10G 2,54649-67996-420HLFFor Reichelt, buy only 1 item and cut it in 2 parts
11-row SIL Header (1×16 pins)“TO_SWITCH_BOARD”SL 1X36G 2,54649-68001-416HLFoptional
16PEC16-4020F-N0024ENC1, ENC2, … , ENC16-652-PEC16-4020FN0024Undetended - without build-in switch
orPEC16-4020F-S0024 -652-PEC16-4020FS0024Undetended - with build-in switch
10Socket 16 pins-GS 16571-1-390261-4
2Socket 18 pins-GS 18571-1-390261-58 (NOT 9) bridges to solder if not using ULN2803s
256LED 3mm or rectangular (2x5x7mm)LED1, LED2, … ,LED256LED 3MM RT-Reichelt model recommended
This is a Mouser Orderlist (Thank you Lamouette). You have only to add your LEDs and Pinheaders.
LED black list
Since Tk discovered a brightness problem with some rectangular 5x2x7mm LEDs, we found it useful to create a list of LEDs wich are successfully or unsuccessfully tested. Members are welcome to edit this page to add their LED feedback.
ModelTypeLinkGoodNot goodCommentAuthor
Kingbright WP103HD5x2x7mm rectangularMouser X Tk
LED 3MM RT3mm roundReichelt X Tk
“10001”5x2x7mm rectangularauspiciousmall.com X Fairlightiii
Kingbright L-934ID3mm roundSegor Electronics X rvlt
Components
LEDs & LEDring
Each LEDring is composed of 16 LEDs.
You can use 3mm LEDs or 5x2x7mm rectangular LEDs (because the different angles of the LEDs in the LEDring) or all other LED with 0.1 inch (2,54 mm) leads spacing.
LEDring
LED polarity
Encoder
You can use instead PEC16-4xxxF-Sxxxx series (with built-in switch). Probably others built-in switch encoders comply the PCB footprint but you have to compare before datasheets.
16 pins SIL header
If you use switched encoders, one of the two pins of the built-in switch is grounded while the other pin is connected to a pin of this SIL connector.
The silkscreen include the name of each switch.
2x5 pins DIL headers
Be careful to the connection to the MBHP_CORE_LPC17 module because it could be confusing, since the SO pin of J8/9 has to be connected to the SI pin of the LRE2x8 board, and SI to the SO pin (for MBHP_DOUT/DIN we usually have the same names for these signals, this detail has been overlooked).
ULN2803
You can use or not Transistors Darlington arrays.
In the second case (and only in this case), you need to bridge 16 of the 18 free pins 2 by 2 (in red on the picture):
Bridges
Be careful to not bridge the 2 last pins
(those opposite to the “head” of the chip).
DIP switchDIP switch
An idea is to use e.g. DIP16 Switch. (NT 08 at Reichelt).
As in the SmashTV's PCB, you can replace a DIL resistor network by 8 resistors.
In this case I recommend to use 1% metal film resistors because with the tolerance of standard carbon resistors you could see maybe different brightness of each LED of the LEDring.
Be careful when sourcing SIL resistor networks because a 6 Pin SIL resistor network can be 5 commoned resistors (what you need here) or 3 independant resistors.
Diagram interconnection
One board connection
Only one 2×5 Pin IDC Ribbon Cable is necessary to connect the board.
Global interconnection
You can chain 4 of this board or connect yours extra DIN/DOUT modules e.g. on the DIL connector named “OUT”.
You can connect also this board at the end of the chain and connect this board with the “IN” connector after yours others modules.
With the use of the upcoming MIDIbox NG (planned for Winter 2012/13) you will be able to have 2 chains of 4 boards each (2x4x16=128 encoders and 2x4x16=128 LEDrings).
BULK ORDER
  • The shipping charges from me to each member has to be add at the total price PCB(s)+ Mouser components.
  • Payment is accepted only by PayPal (5% fees to add on the total including shipping).
  • The eventually custom duty is the responsibility of each member.
Shipping Cost
I won't refund in case of the shipment get lost.
COUNTRYInsurance level Number of PCB
1 2 3 4 5 6 7 8
FranceWithout insurance1,80 €3,10 €3,10 €3,10 €4,00 €4,00 €4,00 €4,00 €
FranceWith insurance 16€6,18 €7,03 €
FranceWith insurance 153€ 7,63 €7,63 €7,63 €8,58 €8,58 €8,58 €8,58 €
European Union (UK, Germany, Greece, …) & SwissWithout insurance4,10 €6,10 €6,10 €6,10 €8,75 €8,75 €8,75 €8,75 €
European Union (UK, Germany, Greece, …) & SwissWith insurance 45€9,70 €11,70 €11,70 €11,70 €14,35 €14,35 €14,35 €14,35 €
European Union (UK, Germany, Greece, …) & SwissWith insurance 150€ 15,35 €15,35 €15,35 €
NorwayWithout insurance5,60 €7,35 €7,35 €7,35 €10,80 €10,80 €10,80 €10,80 €
NorwayWith insurance 45€11,20 €12,95 €12,95 €12,95 €16,40 €16,40 €16,40 €16,40 €
NorwayWith insurance 150€ 17,40 €17,40 €17,40 €
US, Canada, Brazil, Australia, …Without insurance5,60 €7,35 €7,35 €7,35 €10,80 €10,80 €10,80 €10,80 €
US, Canada, Brazil, Australia, …With insurance 45€11,20 €12,95 €12,95 €12,95 €16,40 €16,40 €16,40 €16,40 €
US, Canada, Brazil, Australia, …With insurance 150€ 17,40 €17,40 €17,40 €
If you take “with insurance” you will be compensated of the amount of the insurance in case of lost of the parcel and your shipment is tracked (until your door in this country: Germany, Belgium, Denmark, Finland, UK, Hong-Kong, Ireland, Japan, Luxembourg, The Netherlands, Slovakia, Sweden, Swiss and until the French frontier for the others country). In any case I receive a proof of delivery.
For (french language) tracking page, it's here. Fill the textbox “Numéro de suivi” with your number.
If you take “without insurance” there's no tracking of the parcel.
If your country is not in this table, or if you want more PCBs, PM or email me.
Time Frame
  • Bulk order start: October 29th 2012.
  • End of the list: November 18th 2012.
  • I PM (or email) member with the total amount to pay: November 18th - 20th 2012.
  • Payments will be accepted until November 25th 2012.
  • I order the PCBs: November 26th 2012.
  • PCBs arrive near the December 5th 2012.
  • I ship the PCBs to each member: December 5th - 8th 2012.
  • Time frame may be subject to change due to unforeseeable events.
Because there are not enough stocked DIL resistor networks in Mouser shop, this is the new time-frame:
  • End of the list: November 23th 2012.
  • I PM (or email) member with the total amount to pay: November 24th - 26th 2012.
  • Payments will be accepted until November 30th.
  • I order the PCBs and the Mouser order: December 1st 2012.
  • PCBs and Mouser order arrive near the December 12th 2012.
  • I ship the PCBs and Mouser components to each member: December 13th - 15th 2012.
LIST
By putting your name on the list you agree to the terms and conditions described here: www.midibox.org/dokuwiki/nils_bulk_terms.
Use your full and correct FORUM (not the wiki) name, so I can reach you via PM or email.
Click on the “Edit this page” button (top left corner) and add your MIDIbox username and the number of components you would like.
UPDATE THE QUANTITIES TO THE END OF THE LIST.
Do not edit anything else on this page (except to correct my English or spelling mistakes!).
Username PCB 10k SIL RN 220 Ohm DIL RN
8,50€ (November 20th) 0,08€ (November 20th) 0,26€ (November 16th)
Fairlightiii202412
jojjelito86416
NorthernLightX1
rvlt4328
Hawkeye86416
Lamouette4328
Antix240
shimoda3246
monokinetic2
norbim12164
benuron2164
defenestration4328
kelargo4328
TK4328
johnniebee4328
borbathegeek2164
Beat4328
gslug4328
grizz4328
latigid on216 4
zephyrin2
gtxdude2
Prosperity216 4
dnode64812
ilmenator4
toadstool2 16 4
mburch2 16 4
lylehaze2164
V`cent3246
TheProf2
anderspe2164
taximan 86416
ermangaver2164
Elektruck87020
MaG2k43210
dsdonnes2164
shaduz2164
103 Bert182
dinama4328
ctrl+z182
gomiboy994
raoulblues43210
boops43210
rosch2 4
Dreadknot1108
Milky43210
HerrPaule2106
sam43610
fantomxr2206
technobreath182
Mirmidi4328
Total : 1811194320
Bulk order update
As many people want some onboard components and as resistor networks (SIL and DIL) are not easy to find at good price for few quantity, I add a bulk order only for SIL and DIL resistor networks to this bulk order. Others components (except encoders) are easily “sourcable” on Internet.
I have modified the list with 2 new columns.
Importants informations:
  • I will make the Mouser order the same moment I will order the PCBs.
  • Only member which order PCB(s) can participate (…sorry!).
  • The weight (…and the price) of the shipping of the parcel to each member shouldn't be different (except maybe for 4 boards where the weight was very slightly less than the limit of 0.5kg: But my kitchen food balance say me it should be ok) - Well understood each member doesn't buy to much components! -
  • The price (in euros) of the 652-4116R-1LF-220 and the 264-10K-RC will be the one Mouser propose regarding the quantity ordered for each item.
Jérôme aka Fairlightiii.
—–I tried to be clear but if I made a mistake or if I forgot something, don't hesitate to say it in the forum.—–
PS: Excuse me for my poor English!
mb-lre8x2cs_pcb_bulk_order.txt · Last modified: 2013/01/17 14:25 by fairlightiii
