MBHP_Genesis_LS
This is the schematic for the breakaway MBHP_Genesis_LS board included with the MBQG_FP front panel board. This should be sufficient for anyone to build a copy of this circuit on prototype board.
Explanation
When using the MBHP_Genesis module with a MCU supplied at less than 5V, especially when using several modules in parallel, a buffer circuit will be required between the MCU and the modules. This is a very simple circuit that consists of two 20-pin 74HCT series ICs and two power supply bypass capacitors, and can easily be built on prototyping board.
For buffering the data lines, a bidirectional buffer must be used; a common one is 74HCT245. Connect the eight lines from the MCU board to data pins B; connect the eight lines from the MBHP_Genesis board to data pins A; connect the /OE pin to the buffered /CS line (on the MBHP_Genesis side of the buffer); connect the DIR pin to the buffered /RD line (same thing); and connect a 0.1uF capacitor across the supply rails of the buffer chip.
For buffering the address lines, which are unidirectional from MCU to MBHP_Genesis, use a 74HCT541, with its two /OE pins always active (grounded). Alternatively you can use another 74HCT245, with /OE permanently active (grounded) and DIR set appropriately to always send the signals from the MCU to the MBHP_Genesis board. Again, bypass the supply rails with a capacitor.
Both buffers must be powered from +5V, not +3.3V or whatever the MCU uses. In addition, the MCU must be tolerant of 5V signals being applied to its I/O pins (the CORE_STM32F4 module is tolerant)–otherwise it will damage the MCU!
Parts List
| Qty | Ref. Deg. | Part Name | Mouser Part Number | Description / Notes |
| 1 | U101 | 74HCT245 | 595-SN74HCT245N | Bidirectional buffer chip |
| 1 | U102 | 74HCT541 | 595-SN74HCT541N | Buffer chip |
| 2 | [U101], [U102] | 20-pin 0.3“ DIP socket | 571-1-2199298-6 | Socket for chips |
| 2 | J101, J102 | 10×2 pin header, 0.1” pitch | 649-68691-420HLF | Connectors to core and MBHP_Genesis module |
| 1 | J103 | 2×1 pin header, 0.1“ pitch | 571-826936-2 | Connector for +5V power from core |
| 2 | C101, C102 | 0.1 uF | 21RZ310-RC | Power supply filtering capacitors for chips (place one next to each chip's +5V connection) |
| 1 | C103 | 10 uF | 140-REA100M1HBK0511P | Power supply filtering capacitor for board |
| 1 | — | — | e.g. 854-SB4 | Prototyping board to build circuit on |
