MIDIbox Quad Genesis: Front Panel
To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below):
- An aluminum front panel
- A PCB to hold all the buttons, LEDs, encoders, etc., and of course all these electronic components themselves
- A bunch of 3D printed transparent button caps
- Some 3D printed transparent LED pipes for the FM widget
- A 2×40 standard MIDIbox-compliant character LCD screen
- Knob caps for the encoders, including a datawheel-style cap for the datawheel encoder
- The dual-gang and single-gang potentiometers (one each) for the Genesis module volume controls, and their appropriate knob caps (see MBHP_GENESIS)
- A whole bunch of M3 or 4-40 screws, nuts, washers, and standoffs
- Standard MIDIbox 10-pin and 16-pin IDC cables, for connecting the front panel PCB to the core's J8/9 and for connecting the LCD to the core's J15A
Aluminum Front Panel
Here is the design I used to manufacture the aluminum front panel for my synth: mbqg_fp_original.fpd (You will need to be logged in to your MIDIbox Forum account to access these downloads)
Here is a modified design with the LED pipes in the LED rings having been replaced by 3mm LEDs just sticking through holes in the aluminum: mbqg_fp_modledrings.fpd
It took me over 2 hours just to insert the tiny LED pipes in the slits in one single front panel with the first design, which is why I recommend the second. Since they're 3D printed (see below), they have a small range of sizes, and at that scale some are too big and some are too small. I still left them in place for the FM widget and the DAC VU meter; if you don't want those either for some reason, it shouldn't be hard to replace them with holes.
All the LED holes and screw mounting holes are 1/8“ (3.17 mm), which should give 3mm LEDs a little play (some are in practice slightly wider than 3mm, and some aren't actually 3mm at all). On my own panel, I had to drill out some of the holes a bit for the yellow and green LEDs sticking through the front panel; I recommend you buy the LEDs you're going to put through the holes first and measure them before you have the front panel manufactured. These holes are also big enough for both M3 and 4-40” screws, so no problem there.
It may be possible to make the front panel out of acrylic, a-la MIDIbox SEQ V4. Since the front panel PCB is bolted to it in many places, it will probably be sturdy enough. If it's not, there's a row of screw holes slightly below halfway down the panel, and maybe you can have those screws go into an aluminum bar spanning the width of the front panel and attaching to the sides of your case, to provide extra support in the middle.
MBQG_FP PCB
A custom front panel PCB is purchaseable directly from Sauraen for $50 plus at-cost shipping. It includes a free detachable MBHP_GENESIS_LS PCB in the space where the volume knobs will be on the front panel. Contact Sauraen by private message at the MIDIbox Forums or post in the MIDIbox Quad Genesis thread there.
Photos
Parts List for MBQG_FP PCB
This is the set of parts I used to build the two MIDIbox Quad Genesis units I constructed. It can also serve as guidelines for if you're building your own board from scratch on veroboard. Here are some notes and caveats:
- As explained above in the section of the aluminum front panel, I used LED pipes for the LED rings, to give them a distinctive oblong shape. To save money on the milling costs and labor on inserting hundreds of tiny plastic pieces into the front panel, most of which are either too small or too big, I recommend making the LED rings just by having 3mm LEDs sticking up through the aluminum. In this case, the LEDs I used below will be too bright to look at directly–they were used to illuminate the LED pipes. So please consider changing to different LEDs.
- Please note that for the LEDs which are under illuminated buttons or under the remaining LED pipes, you will need LEDs which are very bright like the ones below! Cheap 1mcd LEDs will be completely invisible! You need at least 1000mcd; the brightnesses I used are listed below. If you are going to the trouble of making this thing, don't skimp on the LEDs!
- Also don't skimp on the encoders! For MIDIbox FM V2.0/V2.1 I used cheap encoders from China to save money, and many of them barely work anymore!
- Of course, the color of all the LEDs is completely up to personal preference, though you should always use the same two colors beneath all bi-color buttons. Please plan out carefully how many of each type of LED you will need based on your color preferences and which LEDs will be sticking through the front panel versus lighting up buttons or light pipes. Trust me, you don't want to use regular LEDs to try to light up the plastic, it'll look dim and poor; and you don't want to use the high-brightness LEDs sticking through the front panel, they will blind you!
- On the PCB itself, the individual buttons, LEDs, and diodes are usually not marked. To simplify PCB design in KiCad, “assemblies” were created with e.g. an encoder and 16 LEDs, or a button, two LEDs, and a diode. This is why they're marked “A21” or whatever. All the diodes are the same 1N914 or 1N4148 (or actually any through-hole small signal diode), and each one has a cathode marking, so there should never be any confusion. With the exception of the LEDs in the LED rings, every LED on the board has an actual diode symbol marked, so there should be no confusion about which direction they go (square pad is anode is longer lead). In the LED rings, the four quadrant LEDs' directions are marked, and the rest go in the corresponding direction, following around the circle (anode always on inside). All the tact switches are also the same–just make sure each one is pushed in fully before soldering!
Description | Mouser P/N | Quantity |
Encoders; 0.1“ board mount with switch; bushing; 24 PPR, 24 detent; etc. If you want to save a couple dollars, you can use the ones without the switch for all the encoders except the datawheel and the four Operator Level encoders–those are the only ones for which the switch is wired up. | 652-PEC12R3220FS0024 | 21 |
Tact switches; standard, 5mm high | 611-PTS645SM502 | 115 |
Diodes for button matrix | 583-1N4148-T | 120 |
Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 |
Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 |
Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 24 |
Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 74 |
Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 |
Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 |
Orange LEDs for panel indication (Tinted, Diffused) | 696-SSL-LX3044SOD | 7 |
Yellow LEDs for panel indication (Tinted, Diffused) (For some reason I ended up using these only for the yellow LEDs in the commands display and the load meter, not for the crosspoints in the FM widget; it may have been because I wanted clear-looking LEDs in the FM widget to go with all the other clear/white things there, or because these LEDs are closer to yellow than to amber, and the other LEDs in the FM widget were more amber) | 710-151031YS06000 | 23 |
Green LEDs for panel indication (Tinted, Clear–I couldn't get appropriate brightness diffused ones) | 859-LTL1CHJGTNN | 51 |
Blue LEDs for panel indication (NOT tinted, Diffused–the picture lies, they're white diffused but light up blue; and actually these are a bit too bright to use for sticking through the front panel. You could fudge something with the resistors supplying these columns to try to reduce the brightness, but I might recommend looking for alternative LEDs.) | 593-VAOL-3LSBY1 | 28 |
Red/Green 5mm LEDs for FM widget operator nodes (3 wire common ANODE) | 696-LLX5099SRSGCCA | 4 |
Large LED display | 859-LTC-5623HR | 1 |
Small LED displays | 859-LSHD-7501 | 5 |
Row drive NMOSFETs (2n7000s aren't strong enough) | 689-VN3205N3-G | 8 |
74HC595 shift registers, SOIC-16 | 511-M74HC595YRM13TR | 12 |
74HC165 shift registers, SOIC-16 | 863-MC74HC165ADR2G | 8 |
220 ohm x 8 resistor packs, SOIC-16 | 652-4816P-1LF-220 | 11 |
10k ohm x 4 resistor packs, SIL-5 (RP13–RP28, not RP0 and RP1) | 858-L051S103LF | 16 |
1k ohm x 4 resistor packs, SIL-5 (these are just RP0 and RP1) | 652-4605X-1LF-1K | 2 |
Electrolytic caps (470 uF) | 647-UVR1C471MPD | 3 |
Ceramic/film caps (0.1 uF) | Buy by the 100 from eBay | ~20 |
10k dual gang audio taper panel mount pot (OPN2 volume) | 313-1240F-10K | 1 |
10k audio taper panel mount pot | 858-P160KNPC15A10K | 1 |
5×2 pin header | Buy in larger size (preferably from eBay) and snap off | 1 |
Don't forget: the 2×40 character LCD, the pin header for the LCD, the ribbon cable and IDC connectors for the LCD and front panel, knob caps for the regular encoders, datawheel knob cap for the datawheel, knob caps for the volume pots.
Schematic and Reference Designators
Front panel KiCad project coming soon!
Ref. Des. | Type | Description |
A1 | Encoder + 16-LED ring | FM operator parameter “Harmonic” (“FMult”) |
A2 | Encoder + 7-LED ring | FM operator parameter “Detune” |
A3 | Encoder + 16-LED ring | FM operator parameter “Atk Rate” |
A4 | Encoder + 16-LED ring | FM operator parameter “Dec1 Rate” |
A5 | Encoder + 16-LED ring | FM operator parameter “Dec1 Level” |
A6 | Encoder + 16-LED ring | FM operator parameter “Dec2 Rate” |
A7 | Encoder + 16-LED ring | FM operator parameter “Rel Rate” |
A8 | Encoder + 16-LED ring | OPN2 parameter “Ch3 CSM Freq” |
A9 | Encoder + 16-LED ring | PSG voice parameter “Freq” |
A10 | Encoder + 16-LED ring | PSG voice parameter “Volume” |
A11 | Button + LED | FM operator parameter “KSR” (Key Scale Rate) |
A12 | Button + LED | FM operator SSG-EG parameter “On” |
A13 | Button + LED | FM operator SSG-EG parameter “Init” |
A14 | Button + LED | FM operator SSG-EG parameter “Toggle” |
A15 | Button + LED | FM operator SSG-EG parameter “Hold” |
A16 | Button + LED | FM operator parameter “LFO AM” (LFO → operator amplitude modulation toggle) |
A17 | Button + LED | OPN2 parameter “Ch3 CSM Fast” (originally Timer A fast, now Timer A enable) |
A18–A21 | Encoder + 16-LED ring | FM voice parameter “Oper 1 Level” – “Oper 4 Level” |
A22 | Encoder + 8-LED ring | FM voice parameter “LFO-Freq Depth” (LFO → frequency modulation depth) |
A23 | Encoder + 4-LED ring | FM voice parameter “LFO-Amp Depth” (LFO → amplitude modulation depth) |
A24 | Encoder + 8-LED ring | OPN2 parameter “LFO Freq” |
A25 | Button + LED | OPN2 parameter “Ugly” (now-famous test bit 0x21:4) |
A26 | Button + LED | OPN2 parameter “DAC Override” (test bit 0x2C:5) |
A27 | Button + LED | OPN2 parameter “LFO Enable” |
A28 | Button + LED | OPN2 parameter “EG Enable” (invert of test bit 0x21:5) |
A29–A32 | Button + LED | Operator Selection 1–4 |
A33–A44 | Button + 2 LEDs | Genesis 1 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A45–A56 | Button + 2 LEDs | Genesis 2 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A57 | Encoder + 8-LED ring | OPN2 voice parameter “Feedback” |
A58–A69 | Button + 2 LEDs | Genesis 3 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A70–A81 | Button + 2 LEDs | Genesis 4 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A82 | Button + LED | OPN2 parameter “DAC Enable” |
A83 | Button + LED | System Mode |
A84 | Button + LED | Voice Mode |
A85 | Button + LED | Channel Mode |
A86 | Button + LED | Program Mode |
A87 | Button + LED | VGM Editor Mode |
A88 | Button + LED | Modulator Mode |
A89 | Button + LED | Sample Mode |
A90 | Button + LED | Mute |
A91 | Button + LED | Solo |
A92 | Button + LED | Release |
A93 | Button + LED | Panel Override |
A94 | Button + LED | Restart |
A95 | Button + LED | Play |
A96 | Button + LED | Reset |
A97 | Button + LED | Load |
A98 | Button + LED | Save |
A99 | Button + LED | New |
A100 | Button + LED | Delete |
A101 | Button + LED | Crop |
A102 | Button + LED | Capture |
A103 | Button + LED | Duplicate |
A104 | Button + LED | Paste |
A105 | Button + LED | Ctrl |
A106 | Button + LED | Time |
A107–A120 | 7-LED Column | Columns of VGM Commands Display (also VU meters) |
A121 | Button + LED | Commands View |
A122 | Button + LED | State View |
A123 | Button + LED | Group |
C1–C20 | Capacitor | 0.1uF ceramic or film capacitors for chips |
C21–C23 | Capacitor | 470uF electrolytic capacitors for power rails, reverse mounted |
D1–D5 | Diode | Diodes for encoder buttons; all normal button diodes included in Assembly or Switch |
DS1 | LED Display | Main Display |
DS2 | LED Display | Octave |
DS3–DS6 | LED Display | Frequency |
E1 | Encoder | OPN2 voice parameter “Octave” |
E2 | Encoder | OPN2 voice parameter “Frequency” |
E3 | Encoder | Datawheel |
LDXX | LED | TODO |
R1–R2 | Resistors | 2.2k terminating resistors for clock and latch lines |
RP0–RP1 | Resistor Packs | 1k row driver pull-ups (to reduce ghosting) |
RP2–RP12 | Resistor Packs | 220 ohm LED column current limiters |
RP13–RP28 | Resistor Packs | 10k button column pull-ups |
Custom PCB / Veroboard Info
This is the mapping for the MBQG_FP board itself–if you have the commercially produced PCB from Sauraen, you don't need this info because it's already in the copper!
MIDIbox Quad Genesis supports its front panel controls in any valid MIDIbox button-LED matrix configuration, with the following restrictions:
DOUT Restrictions
- The same BLM must be used for buttons and LEDs, and it must have 8 rows.
- LED display digits must be common anode, connected with their anode to a DOUT shift register pin, and their cathodes to the row lines in the order 0-7 = A-B-C-D-E-F-G-DP.
DIN Restrictions
- Encoders must have their common pin grounded, and their two switching pins directly connected to two DIN shift register pins (not in the matrix).
For now, the mapping is hard-coded in frontpanel.c, but eventually (if there is interest), it will be read from a text-based configuration file on the SD card upon startup. If you match the matrix maps below, you won't need to edit this at all.
DOUT Matrix Map
Syntax:
- X = no item
- B = button
- EB = encoder button (push)
- L = LED
- R = Red
- G = Green
- G# = Genesis #
- O# = LED Ring Segment # (counted from bottom, clockwise)
- LW# = LED, FM Widget, Reference Designator # (since there is no good way to label the individual widget segments)
All LED display digits are wired, from rows 0 to 7: A-B-C-D-E-F-G-DP
VGM Commands Matrix is wired, from top to bottom, 0-1-2-3-4-5-6 (row 7 not used for any columns)
Counting the individual segments in the LED displays, there are 638 LEDs on the front panel.
SR | IDX | BIT | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
U1 | 1 | 0 | ROW0 DRIVER (ACTIVE HIGH) | |||||||
1 | ROW1 DRIVER (ACTIVE HIGH) | |||||||||
2 | ROW2 DRIVER (ACTIVE HIGH) | |||||||||
3 | ROW3 DRIVER (ACTIVE HIGH) | |||||||||
4 | ROW4 DRIVER (ACTIVE HIGH) | |||||||||
5 | ROW5 DRIVER (ACTIVE HIGH) | |||||||||
6 | ROW6 DRIVER (ACTIVE HIGH) | |||||||||
7 | ROW7 DRIVER (ACTIVE HIGH) | |||||||||
U2 | 2 | 0 | LR_G1_DAC | LG_G1_DAC | LR_G2_DAC | LG_G2_DAC | LR_G3_DAC | LG_G3_DAC | LR_G4_DAC | LG_G4_DAC |
1 | LR_G1_V1 | LG_G1_V1 | LR_G2_V1 | LG_G2_V1 | LR_G3_V1 | LG_G3_V1 | LR_G4_V1 | LG_G4_V1 | ||
2 | LR_G1_V2 | LG_G1_V2 | LR_G2_V2 | LG_G2_V2 | LR_G3_V2 | LG_G3_V2 | LR_G4_V2 | LG_G4_V2 | ||
3 | LR_G1_V3 | LG_G1_V3 | LR_G2_V3 | LG_G2_V3 | LR_G3_V3 | LG_G3_V3 | LR_G4_V3 | LG_G4_V3 | ||
4 | LR_G1_V4 | LG_G1_V4 | LR_G2_V4 | LG_G2_V4 | LR_G3_V4 | LG_G3_V4 | LR_G4_V4 | LG_G4_V4 | ||
5 | LR_G1_V5 | LG_G1_V5 | LR_G2_V5 | LG_G2_V5 | LR_G3_V5 | LG_G3_V5 | LR_G4_V5 | LG_G4_V5 | ||
6 | X | X | X | X | LFOFREQ_O4 | LFOFREQ_O5 | LFOFREQ_O6 | LFOFREQ_O7 | ||
7 | X | X | X | X | LFOFREQ_O11 | LFOFREQ_O10 | LFOFREQ_O9 | LFOFREQ_O8 | ||
U3 | 3 | 0 | LR_G1_V6 | LG_G1_V6 | LR_G2_V6 | LG_G2_V6 | LR_G3_V6 | LG_G3_V6 | LR_G4_V6 | LG_G4_V6 |
1 | LR_G1_OPN2 | LG_G1_OPN2 | LR_G2_OPN2 | LG_G2_OPN2 | LR_G3_OPN2 | LG_G3_OPN2 | LR_G4_OPN2 | LG_G4_OPN2 | ||
2 | LG_CTRL | X | LR_CTRL | X | LG_TIME | L_CMDS | LR_TIME | L_STATE | ||
3 | L_GROUP | L_MUTE | L_RESTART | L_SOLO | L_PLAY | L_RELEASE | L_RESET | L_PNLOVR | ||
4 | LR_G1_S1 | LG_G1_S1 | LR_G2_S1 | LG_G2_S1 | LR_G3_S1 | LG_G3_S1 | LR_G4_S1 | LG_G4_S1 | ||
5 | LR_G1_S2 | LG_G1_S2 | LR_G2_S2 | LG_G2_S2 | LR_G3_S2 | LG_G3_S2 | LR_G4_S2 | LG_G4_S2 | ||
6 | LR_G1_S3 | LG_G1_S3 | LR_G2_S3 | LG_G2_S3 | LR_G3_S3 | LG_G3_S3 | LR_G4_S3 | LG_G4_S3 | ||
7 | LR_G1_NOISE | LG_G1_NOISE | LR_G2_NOISE | LG_G2_NOISE | LR_G3_NOISE | LG_G3_NOISE | LR_G4_NOISE | LG_G4_NOISE | ||
U4 | 4 | 0 | X | X | X | X | X | L_CH3NORM | L_CH34FREQ | L_CH3CSM |
1 | X | X | L_EG | L_LFO | L_DACOVR | L_UGLY | L_CH3FAST | X | ||
2 | L_NFMED | L_NFHI | L_KSR | L_SSGON | L_SSGINIT | L_SSGTGL | L_SSGHOLD | L_LFOAM | ||
3 | L_NFSQ3 | L_NFLO | L_NMPLS | L_NMWHT | X | X | X | X | ||
4 | PSGVOL_O15 | PSGVOL_O14 | PSGVOL_O13 | PSGVOL_O12 | PSGVOL_O11 | PSGVOL_O10 | PSGVOL_O9 | PSGVOL_O8 | ||
5 | PSGVOL_O0 | PSGVOL_O1 | PSGVOL_O2 | PSGVOL_O3 | PSGVOL_O4 | PSGVOL_O5 | PSGVOL_O6 | PSGVOL_O7 | ||
6 | PSGFREQ_O15 | PSGFREQ_O14 | PSGFREQ_O13 | PSGFREQ_O12 | PSGFREQ_O11 | PSGFREQ_O10 | PSGFREQ_O9 | PSGFREQ_O8 | ||
7 | PSGFREQ_O0 | PSGFREQ_O1 | PSGFREQ_O2 | PSGFREQ_O3 | PSGFREQ_O4 | PSGFREQ_O5 | PSGFREQ_O6 | PSGFREQ_O7 | ||
U5 | 5 | 0 | RELRATE_O15 | RELRATE_O14 | RELRATE_O13 | RELRATE_O12 | RELRATE_O11 | RELRATE_O10 | RELRATE_O9 | RELRATE_O8 |
1 | RELRATE_O0 | RELRATE_O1 | RELRATE_O2 | RELRATE_O3 | RELRATE_O4 | RELRATE_O5 | RELRATE_O6 | RELRATE_O7 | ||
2 | CSMFREQ_O15 | CSMFREQ_O14 | CSMFREQ_O13 | CSMFREQ_O12 | CSMFREQ_O11 | CSMFREQ_O10 | CSMFREQ_O9 | CSMFREQ_O8 | ||
3 | CSMFREQ_O0 | CSMFREQ_O1 | CSMFREQ_O2 | CSMFREQ_O3 | CSMFREQ_O4 | CSMFREQ_O5 | CSMFREQ_O6 | CSMFREQ_O7 | ||
4 | DECLVL_O15 | DECLVL_O14 | DECLVL_O13 | DECLVL_O12 | DECLVL_O11 | DECLVL_O10 | DECLVL_O9 | DECLVL_O8 | ||
5 | DECLVL_O0 | DECLVL_O1 | DECLVL_O2 | DECLVL_O3 | DECLVL_O4 | DECLVL_O5 | DECLVL_O6 | DECLVL_O7 | ||
6 | DEC2R_O15 | DEC2R_O14 | DEC2R_O13 | DEC2R_O12 | DEC2R_O11 | DEC2R_O10 | DEC2R_O9 | DEC2R_O8 | ||
7 | DEC2R_O0 | DEC2R_O1 | DEC2R_O2 | DEC2R_O3 | DEC2R_O4 | DEC2R_O5 | DEC2R_O6 | DEC2R_O7 | ||
U6 | 6 | 0 | DEC1R_O15 | DEC1R_O14 | DEC1R_O13 | DEC1R_O12 | DEC1R_O11 | DEC1R_O10 | DEC1R_O9 | DEC1R_O8 |
1 | DEC1R_O0 | DEC1R_O1 | DEC1R_O2 | DEC1R_O3 | DEC1R_O4 | DEC1R_O5 | DEC1R_O6 | DEC1R_O7 | ||
2 | ATTACK_O15 | ATTACK_O14 | ATTACK_O13 | ATTACK_O12 | ATTACK_O11 | ATTACK_O10 | ATTACK_O9 | ATTACK_O8 | ||
3 | ATTACK_O0 | ATTACK_O1 | ATTACK_O2 | ATTACK_O3 | ATTACK_O4 | ATTACK_O5 | ATTACK_O6 | ATTACK_O7 | ||
4 | X | X | X | X | DETUNE_O11 | DETUNE_O10 | DETUNE_O9 | DETUNE_O8 | ||
5 | X | X | X | X | X | DETUNE_O5 | DETUNE_O6 | DETUNE_O7 | ||
6 | HARM_O15 | HARM_O14 | HARM_O13 | HARM_O12 | HARM_O11 | HARM_O10 | HARM_O9 | HARM_O8 | ||
7 | HARM_O0 | HARM_O1 | HARM_O2 | HARM_O3 | HARM_O4 | HARM_O5 | HARM_O6 | HARM_O7 | ||
U7 | 7 | 0 | OP1LVL_O0 | OP1LVL_O1 | OP1LVL_O2 | OP1LVL_O3 | OP1LVL_O4 | OP1LVL_O5 | OP1LVL_O6 | OP1LVL_O7 |
1 | OP1LVL_O15 | OP1LVL_O14 | OP1LVL_O13 | OP1LVL_O12 | OP1LVL_O11 | OP1LVL_O10 | OP1LVL_O9 | OP1LVL_O8 | ||
2 | OP2LVL_O0 | OP2LVL_O1 | OP2LVL_O2 | OP2LVL_O3 | OP2LVL_O4 | OP2LVL_O5 | OP2LVL_O6 | OP2LVL_O7 | ||
3 | OP2LVL_O15 | OP2LVL_O14 | OP2LVL_O13 | OP2LVL_O12 | OP2LVL_O11 | OP2LVL_O10 | OP2LVL_O9 | OP2LVL_O8 | ||
4 | FREQUENCY DIGIT 3 COMMON ANODE | |||||||||
5 | FREQUENCY DIGIT 2 COMMON ANODE | |||||||||
6 | FREQUENCY DIGIT 1 COMMON ANODE | |||||||||
7 | OCTAVE DIGIT COMMON ANODE | |||||||||
U8 | 8 | 0 | OP3LVL_O0 | OP3LVL_O1 | OP3LVL_O2 | OP3LVL_O3 | OP3LVL_O4 | OP3LVL_O5 | OP3LVL_O6 | OP3LVL_O7 |
1 | OP3LVL_O15 | OP3LVL_O14 | OP3LVL_O13 | OP3LVL_O12 | OP3LVL_O11 | OP3LVL_O10 | OP3LVL_O9 | OP3LVL_O8 | ||
2 | OP4LVL_O0 | OP4LVL_O1 | OP4LVL_O2 | OP4LVL_O3 | OP4LVL_O4 | OP4LVL_O5 | OP4LVL_O6 | OP4LVL_O7 | ||
3 | OP4LVL_O15 | OP4LVL_O14 | OP4LVL_O13 | OP4LVL_O12 | OP4LVL_O11 | OP4LVL_O10 | OP4LVL_O9 | OP4LVL_O8 | ||
4 | X | X | X | X | LFOFDEP_O4 | LFOFDEP_O5 | LFOFDEP_O6 | LFOFDEP_O7 | ||
5 | X | X | X | X | LFOFDEP_O11 | LFOFDEP_O10 | LFOFDEP_O9 | LFOFDEP_O8 | ||
6 | X | X | X | X | LFOADEP_O4 | LFOADEP_O10 | LFOADEP_O6 | LFOADEP_O8 | ||
7 | FREQUENCY DIGIT 4 COMMON ANODE | |||||||||
U9 | 9 | 0 | X | X | X | X | L_DACB9 | L_DACENAB | LW46 | X |
1 | LW45 | LW48 | LW51 | LW49 | L_KON1 | L_KON2 | L_KON3 | L_KON4 | ||
2 | FEEDBACK_O11 | FEEDBACK_O10 | FEEDBACK_O9 | FEEDBACK_O8 | L_DACB5 | L_DACB6 | L_DACB7 | L_DACB8 | ||
3 | FEEDBACK_O4 | FEEDBACK_O5 | FEEDBACK_6 | FEEDBACK_7 | L_DACB1 | L_DACB2 | L_DACB3 | L_DACB4 | ||
4 | LW32 | LW33 | LW37 | LW38 | LW34 | LW39 | LW40 | LW35 | ||
5 | L_OUTL | L_OUTR | LW24 | LW25 | LW26 | LW27 | LW28 | LW29 | ||
6 | LR_OP1 | LG_OP1 | LR_OP2 | LG_OP2 | LR_OP3 | LG_OP3 | LR_OP4 | LG_OP4 | ||
7 | L_SELO1 | L_CARRO1 | L_SELO2 | L_CARRO2 | L_SELO3 | L_CARRO3 | L_SELO4 | L_CARRO4 | ||
U10 | 10 | 0 | MAIN DIGIT 4 COMMON ANODE | |||||||
1 | MAIN DIGIT 3 COMMON ANODE | |||||||||
2 | MAIN DIGIT 2 COMMON ANODE | |||||||||
3 | MAIN DIGIT 1 COMMON ANODE | |||||||||
4 | L_RAM0 | L_RAM1 | L_RAM2 | L_RAM3 | L_RAM4 | L_RAM5 | L_RAM6 | L_RAM7 | ||
5 | L_CHIP0 | L_CHIP1 | L_CHIP2 | L_CHIP3 | L_CARD3 | L_CARD2 | L_CARD1 | L_CARD0 | ||
6 | L_LOAD | L_CROP | L_SAVE | L_CAPTURE | L_NEW | L_DUPL | L_DELETE | L_PASTE | ||
7 | L_PROG | X | L_VGM | L_SYSTEM | L_MDLTR | L_VOICE | L_SAMPLE | L_CHAN | ||
U11 | 11 | 0 | VGM COMMANDS MATRIX COLUMN 7: FM 4 | |||||||
1 | VGM COMMANDS MATRIX COLUMN 6: FM 3 | |||||||||
2 | VGM COMMANDS MATRIX COLUMN 5: FM 2 | |||||||||
3 | VGM COMMANDS MATRIX COLUMN 4: FM 1 | |||||||||
4 | VGM COMMANDS MATRIX COLUMN 3: OPN2 | |||||||||
5 | VGM COMMANDS MATRIX COLUMN 2: TIME | |||||||||
6 | VGM COMMANDS MATRIX COLUMN 1: CTRL | |||||||||
7 | X | |||||||||
U12 | 12 | 0 | X | |||||||
1 | VGM COMMANDS MATRIX COLUMN 14: OP4/NS | |||||||||
2 | VGM COMMANDS MATRIX COLUMN 13: OP/SQ 3 | |||||||||
3 | VGM COMMANDS MATRIX COLUMN 12: OP/SQ 2 | |||||||||
4 | VGM COMMANDS MATRIX COLUMN 11: OP/SQ 1 | |||||||||
5 | VGM COMMANDS MATRIX COLUMN 10: DAC | |||||||||
6 | VGM COMMANDS MATRIX COLUMN 9: FM 6 | |||||||||
7 | VGM COMMANDS MATRIX COLUMN 8: FM 5 |
DIN Matrix Map
U13 | 1 | 0 | OP4LVL ENCODER A | |||||||
1 | OP4LVL ENCODER B | |||||||||
2 | LFOFDEP ENCODER B | |||||||||
3 | LFOFDEP ENCODER A | |||||||||
4 | LFOADEP ENCODER B | |||||||||
5 | LFOADEP ENCODER A | |||||||||
6 | LFOFREQ ENCODER A | |||||||||
7 | LFOFREQ ENCODER B | |||||||||
U14 | 2 | 0 | B_MENU | B_G1_V2 | X | B_G2_V2 | X | B_G3_V2 | B_ENTER | B_G4_V2 |
1 | B_SOFT1 | B_G1_V3 | B_SOFT2 | B_G2_V3 | B_SOFT3 | B_G3_V3 | B_SOFT4 | B_G4_V3 | ||
2 | B_SOFT5 | B_G1_V4 | B_SOFT6 | B_G2_V4 | B_SOFT7 | B_G3_V4 | B_SOFT8 | B_G4_V4 | ||
3 | B_MARKST | B_G1_V5 | B_MOVEUP | B_G2_V5 | B_MARKEND | B_G3_V5 | B_MOVEDN | B_G4_V5 | ||
4 | X | B_G1_V1 | X | B_G2_V1 | X | B_G3_V1 | X | B_G4_V1 | ||
5 | X | B_G1_DAC | X | B_G2_DAC | X | B_G3_DAC | X | B_G4_DAC | ||
6 | B_SELO1 | B_OUT | B_SELO2 | B_ALG | B_SELO3 | B_DACEN | B_SELO4 | B_KON | ||
7 | X | X | X | X | EB_OP1LVL | EB_OP2LVL | EB_OP3LVL | EB_OP4LVL | ||
U15 | 3 | 0 | X | B_G1_V6 | X | B_G2_V6 | X | B_G3_V6 | X | B_G4_V6 |
1 | X | B_G1_OPN2 | X | B_G2_OPN2 | X | B_G3_OPN2 | X | B_G4_OPN2 | ||
2 | X | B_G1_S1 | X | B_G2_S1 | X | B_G3_S1 | X | B_G4_S1 | ||
3 | X | B_G1_S2 | X | B_G2_S2 | X | B_G3_S2 | X | B_G4_S2 | ||
4 | X | B_G1_S3 | X | B_G2_S3 | X | B_G3_S3 | X | B_G4_S3 | ||
5 | X | B_G1_NOISE | X | B_G2_NOISE | X | B_G3_NOISE | X | B_G4_NOISE | ||
6 | B_NSTYPE | B_NSFREQ | B_EG | B_LFO | B_DACOVR | B_UGLY | B_FAST | B_CH3MODE | ||
7 | X | X | B_KSR | B_SSGON | B_SSGINIT | B_SSGTGL | B_SSGHOLD | B_LFOAM | ||
U16 | 4 | 0 | CSMFREQ ENCODER A | |||||||
1 | CSMFREQ ENCODER B | |||||||||
2 | RELRATE ENCODER A | |||||||||
3 | RELRATE ENCODER B | |||||||||
4 | PSGFREQ ENCODER A | |||||||||
5 | PSGFREQ ENCODER B | |||||||||
6 | PSGVOL ENCODER A | |||||||||
7 | PSGVOL ENCODER B | |||||||||
U17 | 5 | 0 | DEC2R ENCODER B | |||||||
1 | DEC2R ENCODER A | |||||||||
2 | DECLVL ENCODER B | |||||||||
3 | DECLVL ENCODER A | |||||||||
4 | DEC1R ENCODER B | |||||||||
5 | DEC1R ENCODER A | |||||||||
6 | FREQ ENCODER B | |||||||||
7 | FREQ ENCODER A | |||||||||
U18 | 6 | 0 | ATTACK ENCODER B | |||||||
1 | ATTACK ENCODER A | |||||||||
2 | DETUNE ENCODER B | |||||||||
3 | DETUNE ENCODER A | |||||||||
4 | HARM ENCODER B | |||||||||
5 | HARM ENCODER A | |||||||||
6 | OCTAVE ENCODER B | |||||||||
7 | OCTAVE ENCODER A | |||||||||
U19 | 7 | 0 | OP2LVL ENCODER B | |||||||
1 | OP2LVL ENCODER A | |||||||||
2 | OP3LVL ENCODER B | |||||||||
3 | OP3LVL ENCODER A | |||||||||
4 | OP1LVL ENCODER B | |||||||||
5 | OP1LVL ENCODER A | |||||||||
6 | FEEDBACK ENCODER B | |||||||||
7 | FEEDBACK ENCODER A | |||||||||
U20 | 8 | 0 | DATAWHEEL ENCODER B | |||||||
1 | DATAWHEEL ENCODER A | |||||||||
2 | X | |||||||||
3 | X | |||||||||
4 | B_CTRL | B_CMDDN | B_CMDUP | B_STATEDN | B_TIME | B_CMDS | B_STATEUP | B_STATE | ||
5 | B_LOAD | B_CROP | B_SAVE | B_CAPTURE | B_NEW | B_DUPL | B_DELETE | B_PASTE | ||
6 | B_GROUP | B_MUTE | B_RESTART | B_SOLO | B_PLAY | B_RELEASE | B_RESET | B_PNLOVR | ||
7 | B_PROG | EB_DATAWHL | B_VGM | B_SYSTEM | B_MDLTR | B_VOICE | B_SAMPLE | B_CHAN |
