mbqg_tb_case
MIDIbox Quad Genesis Case designed by Technobreath
The case is designed by Technobreath to be easily replicated by the community without requiring much skills or tools.
Here you will find a pdf with dimensions and building instructions for a wooden case designed for the MIDIbox Quad Genesis by user Technobreath:
building-instructions4.pdf
Please see this forum post in the Quad Genesis Build Guide Thread for further step by step instructions on how to build the case: http://midibox.org/forums/topic/20619-build-guide-midibox-quad-genesis/?do=findComment&comment=180084
Huge thanks to Technobreath for taking the time to design this case!
You will need 8 threaded inserts with an internal diameter of 3mm for use with Smithy's PCB Front panel You can find these m3 threaded inserts with an external diameter of 5mm commonly on [[https://a.aliexpress.com/_ExA45x3]AliExpress]
mbqg_tb_case.1705717946.txt.gz · Last modified: 2024/01/20 02:32 by smithy
