MIDIBox64E is a midi controlled based on MBHP/MIOS
- MIDIbox 64E uCApps
- MIDIbox 64E Tutorial uCApps
DIN register allocation
Question from Dan aka Digineural:
I understand that the following is setting shift registers 5-8 to be used for encoders 1-16.
MIOS_ENC_PIN_TABLE
;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 5, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 5, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 5, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 5, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4 ENC_ENTRY 6, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 5 ENC_ENTRY 6, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 6 ENC_ENTRY 6, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 7 ENC_ENTRY 6, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 8 ENC_ENTRY 7, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 9 ENC_ENTRY 7, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 10 ENC_ENTRY 7, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 11 ENC_ENTRY 7, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 12 ENC_ENTRY 8, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 13 ENC_ENTRY 8, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 14 ENC_ENTRY 8, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 15 ENC_ENTRY 8, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 16
However I'm not quite sure what is being defined here
#define DEFAULT_DIN_SR_PIN_01_08   2
#define DEFAULT_DIN_SR_PIN_09_16   3
#define DEFAULT_DIN_SR_PIN_17_24   1
#define DEFAULT_DIN_SR_PIN_25_32   4
#define DEFAULT_DIN_SR_PIN_33_40   8
#define DEFAULT_DIN_SR_PIN_41_48   10
#define DEFAULT_DIN_SR_PIN_49_56   11
#define DEFAULT_DIN_SR_PIN_57_64   12
Answer: MB64E supports up to 64 button functions, and they are assiged to 8 shift registers. With the DEFAULT_DIN_SR_* settings you can change the mapping. This is important, if the appr. shift registers are already allocated by encoders (defined in mios_tables.inc) - if this is the case, change the DEFAULT_DIN_SR_* values to unused shift register numbers.
Forum FAQ
Be sure to make a search of the forum;
these are some useful infos from old threads:
- http://www.midibox.org/forum/index.php?topic=6395.0 Testing AIN Board
- http://www.midibox.org/forum/index.php?topic=7149.0 Mapping Buttons to Midi Ch
- http://www.midibox.org/forum/index.php?topic=7104.0 Enabling Pots
- http://www.midibox.org/forum/index.php?topic=6938.0 MB64E Encoders
