midibox_arp
MIDIBox Arp
A standalone arpeggiator for MBHP.
http://www.midibox.org/forum/index.php?topic=8993.msg63842#msg63842
This first release is supposed to be a base for a future powerfull arpeggiator !! :)
The features
  • it read incoming notes, (and forward the rest)
  • Sort and hold notes in a 32byte buffer. (is it big enough ?)
  • Then play buffered notes Ascendingly.
  • The tempo is fixed, and the arpeggio speed is set to 3 tik (ppqn)
And now, let's discuss about some features and arp algorythm in the forum :)
Todo
  • Define how to set the Bpm (cc#)
  • Define how to set the Arp speed (cc#)
  • Read midi channel from incoming midi notes ( yes it's fixed, i'm lazy, as you can see ;) )
  • Define note length
  • Create some cool arp algorythms (plus defining method to select the algorythm)
  • Octave range
  • Latch (HOLD)
  • Add velocity support
The Code
Source code (based on clockbox) : arp_v0.1.zip
The hardware
to keep it simple, the only hardware needed is a core module.
( please wait for more features then we'll add some pots and buttons ;) )
Hehehe
doesn't it look cute ?
midibox_arp.txt · Last modified: 2007/11/17 15:03 by 127.0.0.1
