midiboxmixerhardware
MBMixer
Hardware description: The hardware is designed in a modular form. Each mixer will need one regulator board, one output board, and some number of channel boards. All the boards are about 1“ by 4”, so they are quite small. They stack together to form a complete mixer. There are a LOT of choices to make before you begin to build (or even order parts). Read each of the links below to get a feel for the project requirements.
Before you Build
Choosing Input Types
Soldering surface mount parts
Building the regulator board
Building the Output Board
Building the Channel Board
Stacking the Boards together
midiboxmixerhardware.txt · Last modified: 2008/09/07 15:56 by 127.0.0.1
