serial_graphics_tablet
Below is an edited extract from an email I found on Google's Usenet Archive. I think there is enough information in there to allow us to use some older serial port graphics tablets as X-Y controllers under MIOS.
If you are the original author of this post and wish to have it removed, please contact me through the Private Messages at midibox.org/forum
DrBunsen.
Date: Sat, 26 Jul 86 09:12:59 pdt
From: oster%ucbla…@BERKELEY.EDU (David Phillip Oster)
Subject: Re: Digitizing point coordinates (MacTablet)
This letter discusses using Mac compatible digitizing tablets to get high resolution data … since you are not afraid to program, you might try the following:
I assume the MacTablet connects to the Mac using a serial port…
Listen to the tablet using terminal software (Versaterm, naacterm …)(try 9600 baud as an initial guess at the baud rate.)
The tablet probably sends a 5 byte data packet of the following form:
b7 b6 b5 b4 b3 b2 b1 b0bits of a byte
P 1 0 0 0 S 0 0P is parity. S is on if switch is down
P 0 x5 x4 x3 x2 x1 x0low 6 bits of x data
P 0 x11 x10 x9 x8 x7 b6high 6 bits of x data
P 0 y5 y4 y3 y2 y1 y0low 6 bits y data
P 0 y11 y10 y9 y8 y7 y6high 6 bits y data
b6 is 1 only at the start of a 5 byte data packet.
This data is drawn from a Summagraphics data sheet for their Bit Pad 1 digitizer.
Unlike the Mac, point (0,0) is probably at the LOWER-left corner.
If you get data that is consistent with this, then you need only write a basic program to read data at the serial port. Tablets generate so much data that you're program had better check the fullness of the serial buffer and throw away 5 byte data packets periodically to keep the buffer from overflowing. Alternatively, you could write in a language, like C or compiled Pascal, that was fast enough to keep up with the data rate.
Low-resolution Kurta tablets and other-than-MacTablet Summagraphic tablets use this data format when they are not transmitting data as strings of ASCII, base-10 integers.
Kurta's PenMouse, a cordless digitizer considerably cheaper than MacTablet, sends 2400 baud, their other models generally run at 4800 baud. Kurta also makes a MacXL compatible version.
Disclaimer: My opinions are solely my own, but, in evaluating them, you should know that I am currently re-writing Kurta's software.
— David Phillip Oster – “The goal of Computer Science is to
Arpa: o…@lapis.berkeley.edu – build something that will last at
Uucp: ucbvax!ucblapis!oster – least until we've finished building it.”
serial_graphics_tablet.txt · Last modified: 2007/07/26 16:32 by 127.0.0.1
