Because the information in the SpeakJet Manual is relatively wide spreaded, this page gives a quick overview of the control possibilities of the Speakjet:
MSA (Mathmatical Sound Architecture)
MSA commands are stored in the 64-Byte input buffer and are executed in the order they are received.
MSA Controls
An 'X' indicates that a second number should follow as parameter.
Pause Control
000: Pause 0 ms
001: Pause 100 ms
002: Pause 200 ms
003: Pause 700 ms
004: Pause 30 ms
005: Pause 60 ms
006: Pause 90 ms
016: Wait  Watch out! Waits for event input line or SCP-Start command!
030: Delay, X  number of 10 ms intervals to delay before continuing on to the next code, accepts 0-255
Next Sound Control
007: Play next sound fast
008: Play next sound slow
014: Play next sound high
015: Play next sound low
Volume/Pitch/Speed/Bend Control
020: Volume, X  sets Master Volume Level, accepts 0-127
021: Speed, X  Play Speed, default 114, accepts 0-127
022: Pitch, X  Pitch in Hertz, only for voiced sounds, default 88, accepts 0-255 (=32kHz..240kHz)
023: Bend, X  Sets the Frequency Band (from deep hollow to high metallic), default 5, accepts 0-15
Port Control
024: PortCtr, X  binaurally encoded output line control, see manual for details, default 7, accepts 0-7
025: Port, X  port output value, see manual for details, default 0, accepts 0-7
Phrase Control
026: Repeat, X  repeats the next code x-times, accepts 0-255
028: Call Phrase, X  which EEPROM phrase to play, max 3 level deep nesting
029: Goto Phrase, X  which EEPROM phrase to play
255: End of Phrase
Reset
031: Reset Defaults
MSA Sound Codes
128..254: MSA Sound Phrases and Effects, see SpeakJet Definition List.
SCP (Serial Control Protocol)
SCP commands are executed immediately and provide control over the 5-channel synthesizer as well as accessing the internal speakjet EEPROM.
Entering SCP
'\0' to enter SCP
SCP Commands
'H': Store Memory Type accepts 0 and 32
- '0H': Write a register's value
- '32H': Write to the internal EEPROM
'J': Memory Address
- '0J': Envelope Freq
- '1J': OSC1 Freq .. '5J': OSC5 Freq
- '6J': Distortion
- '7J': Master Volume
- '8J': Envelope Control
- '11J': OSC1 Vol .. '15J': OSC5 Vol
'N': Store Memory
'R': Clear Buffer
'S': Stop Enounciating
'T': Start Enounciating
'V': ACK
'W': Hard Reset
Exiting SCP
'X' or '\A'
Examples
\0 V X*
Enters SCP-Mode, enounciates READY and exits SCP-mode
8J 0N 1J 500N 11J 16N*
1st OSC freq 500 and vol 16
0J 32H 01N*
write 0x1 to the first location of internal EEPROM
8J 00N*
set env-type to SAW
8J 10N*
set env-type to TRIANGLE
* Don't send spaces, this is just for readability!
