ssp_mmc
This wiki will follow the progress and final build of the midibox m.m.c unit (midi.machine.code).
The reason for this was to provide an mmc unit that could apply standard mmc commands over 5 pin midi ports rather than usb. This unit will work in logic pro, pro tools , digital performer to name a few.
The design and code took roughly a week to figure out as did applying the mmc code to meta events in the asm files prior to re-compiling.
This thread will explain the build from initial concept to finished item, also it will include the edited meta events used and the full mmc standard codes for sysex use.
more to follow shortly
ssp_mmc.txt · Last modified: 2010/01/16 20:23 by ssp
