Microsoft Word to DokuWiki Converter
This is a vbScript that will do basic formatting conversion from word to dokuwiki. It's not perfect, but it will save you a lot of time if you have lots of word docs like me. Also, cells pasted into word from excel will be converted, so it's almost an excel converter.
It's poorly written ugly uncommented crappy code that has come to you as a fixed up version of an old version which supported old syntax which was created by someone else mashing together conversion code for openoffice and mediawiki. So yeh, it's crap!! Here's a readme that, just like the code, is mostly ripped off from other people. I give all the credit for this to whoever it was that did it, except for the bits I fixed up so it would actually work ;) So here's a fixed up version of their readme:
INTRO
Convert Microsoft Word document content to MediaWiki markup.
This is a Word Visual Basic macro. Usage requires a running copy of Microsoft Word that supports Visual Basic macros. (Word 97 or greater). Features
- Replaces smart quotes/double-quotes with dumb equivalents
- Escapes the following characters: * # { } [ ] ~ ^^ | '
- Converts external hyperlinks
- Converts H1-H5 headings
- Converts bold/italic/underline/strikethrough/superscript/subscript formatting
- Converts bulleted/numbered lists
CAVEATS
- No guarantees, no official support, just like the DokuWiki itself (or Word =} )
- No in-document hyperlink conversion (so make Wiki links yourself after pasting)
- May not work well with documents that have highly customized styles/templates. It works best with documents written in the default “Normal” template
- Image/graphics/figures are not supported.
- Tables go a bit crazy if you have carriage returns inside the cells… I can't get around that, it's a microsoft thing.
- | or ^ characters within tables get converted to I and /\ or they'll screw it up.
INSTALLATION
1. Copy the code from below, and save it to a file on your disk named Word2Doku.bas 2. Start Word 3. Bring up the Visual Basic Editor (Tools->Macro->Visual Basic Editor or Alt+F11). 4. From the VBE, import the macro library (File->Import File...) and select the file you downloaded.
USAGE
1. Open a word document to convert 2. Run the Word2DokuWiki macro by bringing up the Macros dialog (Tools->Macro->Macros or Alt+F8), selecting Word2DokuWiki and clicking Run. 3. The macro converts the document to DokuWiki markup and places a copy of the content on the system clipboard. 4. Switch to a DokuWiki editor page (or new page) and paste the result in.
ATTRIBUTION
I did not come up with this macro, though I was looking to make something similar. The actual coding was done by http://infpro.com/projekte/wordwiki/ . Thank them for the fact you're using this. I only trivially hacked the functions to work with the slight differences inherent in DokuWiki formatting. And I rarely use Word. =}
A similar macro is available for converting OpenOffice documents to DokuWiki format at : http://homepages.paradise.net.nz/hillview/OOo/
I don't foresee any problems or need for this macro to be enhanced, but if you need to get a hold of me, the best way is by leaving a comment on my blog Across Weirdish Wild Space @ http://www.wakatara.com/blog/
Enjoy !
So yeh, ignore that stuff above, if you're a MIDIBoxer, just hit me up if you need support. Cheers!
Attribute VB_Name = "Word2DokuWikiv3"
Sub Word2DokuWiki()
Application.ScreenUpdating = False
ReplaceQuotes
DokuWikiEscapeChars
DokuWikiConvertHyperlinks
DokuWikiConvertH1
DokuWikiConvertH2
DokuWikiConvertH3
DokuWikiConvertH4
DokuWikiConvertH5
DokuWikiConvertItalic
DokuWikiConvertBold
DokuWikiConvertUnderline
DokuWikiConvertStrikeThrough
DokuWikiConvertSuperscript
DokuWikiConvertSubscript
DokuWikiConvertLists
DokuWikiConvertTable
UndoDokuWikiEscapeChars
' Copy to clipboard
ActiveDocument.Content.Copy
Application.ScreenUpdating = True
End Sub
Private Sub DokuWikiConvertH1()
ReplaceHeading wdStyleHeading1, "======"
End Sub
Private Sub DokuWikiConvertH2()
ReplaceHeading wdStyleHeading2, "====="
End Sub
Private Sub DokuWikiConvertH3()
ReplaceHeading wdStyleHeading3, "===="
End Sub
Private Sub DokuWikiConvertH4()
ReplaceHeading wdStyleHeading4, "==="
End Sub
Private Sub DokuWikiConvertH5()
ReplaceHeading wdStyleHeading5, "=="
End Sub
Private Sub DokuWikiConvertH6()
ReplaceHeading wdStyleHeading5, "="
End Sub
Private Sub DokuWikiConvertBold()
ActiveDocument.Select
With Selection.Find
.ClearFormatting
.Font.Bold = True
.Text = ""
.Format = True
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
.Forward = True
.Wrap = wdFindContinue
Do While .Execute
With Selection
If Len(.Text) > 1 And InStr(1, .Text, vbCr) Then
' Just process the chunk before any newline characters
' We'll pick-up the rest with the next search
.Collapse
.MoveEndUntil vbCr
End If
' Don't bother to markup newline characters (prevents a loop, as well)
If Not .Text = vbCr Then
If Not Left(.Text, 2) = "**" Then
.InsertBefore "**"
End If
If Not Right(.Text, 2) = "**" Then
.InsertAfter "**"
End If
End If
.Style = ActiveDocument.Styles("Default Paragraph Font")
.Font.Bold = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertItalic()
With Selection.Find
.ClearFormatting
.Font.Italic = True
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
.Collapse
.MoveEndUntil vbCr
End If
If Not Left(.Text, 2) = "//" Then
.InsertBefore "//"
End If
If Not Right(.Text, 2) = "//" Then
.InsertAfter "//"
End If
End If
.Font.Italic = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertUnderline()
With Selection.Find
.ClearFormatting
.Font.Underline = True
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
.Collapse
.MoveEndUntil vbCr
End If
If Not Left(.Text, 2) = "__" Then
.InsertBefore "__"
End If
If Not Right(.Text, 2) = "__" Then
.InsertAfter "__"
End If
End If
.Font.Underline = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertStrikeThrough()
With Selection.Find
.ClearFormatting
.Font.StrikeThrough = True
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
.Collapse
.MoveEndUntil vbCr
End If
If Not Left(.Text, 2) = "<del>" Then
.InsertBefore "<del>"
End If
If Not Right(.Text, 2) = "</del>" Then
.InsertAfter "</del>"
End If
End If
.Font.StrikeThrough = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertSuperscript()
With Selection.Find
.ClearFormatting
.Font.Superscript = True
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
.Text = Trim(.Text)
.Collapse
.MoveEndUntil vbCr
End If
If Not Left(.Text, 2) = "<sup>" Then
.InsertBefore "<sup>"
End If
If Not Right(.Text, 2) = "</sup>" Then
.InsertAfter "</sup>"
End If
End If
.Font.Superscript = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertSubscript()
With Selection.Find
.ClearFormatting
.Font.Subscript = True
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
.Text = Trim(.Text)
.Collapse
.MoveEndUntil vbCr
End If
If Not Left(.Text, 2) = "<sub>" Then
.InsertBefore "<sub>"
End If
If Not Right(.Text, 2) = "</sub>" Then
.InsertAfter "</sub>"
End If
End If
.Font.Subscript = False
End With
Loop
End With
End Sub
Private Sub DokuWikiConvertLists()
Dim para As Paragraph
For Each para In ActiveDocument.ListParagraphs
With para.Range
.InsertBefore " "
If .ListFormat.ListType = wdListBullet Then
.InsertBefore "*"
Else
.InsertBefore "-"
End If
For i = 1 To .ListFormat.ListLevelNumber
.InsertBefore " "
Next i
.ListFormat.RemoveNumbers
End With
Next para
End Sub
Private Sub DokuWikiConvertHyperlinks()
Dim hyperCount As Integer
hyperCount = ActiveDocument.Hyperlinks.Count
For i = 1 To hyperCount
With ActiveDocument.Hyperlinks(1)
Dim addr As String
addr = .Address
.Delete
.Range.InsertBefore "["
.Range.InsertAfter "-" & addr & "]"
End With
Next i
End Sub
' Replace all smart quotes with their dumb equivalents
Private Sub ReplaceQuotes()
Dim quotes As Boolean
quotes = Options.AutoFormatAsYouTypeReplaceQuotes
Options.AutoFormatAsYouTypeReplaceQuotes = False
ReplaceString ChrW(8220), """"
ReplaceString ChrW(8221), """"
ReplaceString "ë", "'"
ReplaceString "í", "'"
Options.AutoFormatAsYouTypeReplaceQuotes = quotes
End Sub
Private Sub DokuWikiEscapeChars()
EscapeCharacter "*"
EscapeCharacter "#"
EscapeCharacter "_"
EscapeCharacter "-"
EscapeCharacter "+"
EscapeCharacter "{"
EscapeCharacter "}"
EscapeCharacter "["
EscapeCharacter "]"
EscapeCharacter "~"
EscapeCharacter "^^"
EscapeCharacter "|"
EscapeCharacter "'"
End Sub
Private Function ReplaceHeading(styleHeading As String, headerPrefix As String)
Dim normalStyle As Style
Set normalStyle = ActiveDocument.Styles(wdStyleNormal)
With Selection.Find
.ClearFormatting
.Style = ActiveDocument.Styles(styleHeading)
.Text = ""
.Format = True
.MatchCase = False
.Forward = True
Do While .Execute
With Selection
If InStr(1, .Text, vbCr) Then
.Collapse
.MoveEndUntil vbCr
End If
.InsertBefore headerPrefix
.InsertBefore vbCr
.InsertAfter headerPrefix
End If
.Style = normalStyle
End With
Loop
End With
End Function
Private Sub DokuWikiConvertTable()
Dim TotTables As Long
Do While ActiveDocument.Tables.Count() > 0
ActiveDocument.Tables(1).Range.Select
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " $s$|$s$ "
.Replacement.Text = "I"
.Forward = True
.Format = False
.MatchCase = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
With Selection.Find
.Text = " $s$^^$s$ "
.Replacement.Text = "/\"
.Forward = True
.Format = False
.MatchCase = False
End With
Application.DefaultTableSeparator = "|"
Selection.Rows.ConvertToText Separator:=wdSeparateByDefaultListSeparator, NestedTables:=True
With Selection.Find
.Text = "^p"
.Replacement.Text = "|^p|"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
Selection.InsertBefore ("|")
Selection.InsertParagraphAfter
With Selection.Find
.Text = "^p|^p"
.Replacement.Text = "^p"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
With Selection.Find
.Text = "$s$blank$s$"
.Replacement.Text = ""
.Forward = True
.Format = False
.MatchCase = False
End With
With Selection.Find
.Text = "||"
.Replacement.Text = "| |"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
With Selection.Find
.Text = "||"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
With Selection.Find
.Text = "| |"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
With Selection.Find
.Text = "| |"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
Selection.Paragraphs(1).Range.Select
With Selection.Find
.Text = "|"
.Replacement.Text = "^^"
.Forward = True
.Wrap = wdFindStop
.Format = False
.MatchCase = False
End With
Loop
End Sub
Private Sub UndoDokuWikiEscapeChars()
UndoEscapeCharacter "*"
UndoEscapeCharacter "#"
UndoEscapeCharacter "_"
UndoEscapeCharacter "-"
UndoEscapeCharacter "+"
UndoEscapeCharacter "{"
UndoEscapeCharacter "}"
UndoEscapeCharacter "["
UndoEscapeCharacter "]"
UndoEscapeCharacter "~"
UndoEscapeCharacter "^^"
UndoEscapeCharacter "|"
UndoEscapeCharacter "'"
End Sub
Private Function EscapeCharacter(char As String)
ReplaceString char, " $s$" & char & "$s$ "
End Function
Private Function UndoEscapeCharacter(char As String)
ReplaceString " $s$" & char & "$s$ ", char
End Function
Private Function ReplaceString(findStr As String, replacementStr As String)
With Selection.Find
.Text = findStr
.Replacement.Text = replacementStr
.Forward = True
.Format = False
.MatchCase = False
End With
End Function
