temp_template_test
MIBIbox 64
Intro
-All about it, what it does and blah
Features
- up to 64 Pots or Faders, dynamic priorities: latency < 1 ms!
- up to 64 Push-Buttons
- up to 64 LEDs
- one internal bank
- +16 external banks with every BankStick
- sends CC/Note/Aftertouch/PitchBender/ProgramChange
- Min and Max values, scaling over the whole pot range
- Meta Events allow you to define SysEx strings and more
- Normal, Snap (Soft-Takeover), Relative and Parallax Mode for pots
- On/Off, On Only, Toggle Mode for buttons
- integrated MIDI Learn Function
- Setups exchangable via SysEx
- Device IDs to address up to 8 boxes in a MIDI chain
- Menu Buttons
- Snapshot Button with Save/Recall function
- Shortcuts for the buttons (SFB) for faster menu handling
- LC-Display, different Display Modes
- dedicated strings for every pot can be saved in the BankStick
- MIDI-Merger
- MIDI event filter for the merger
- Optional RS232 Interface
Additional features of the MIOS based version:
- runs on a PIC18F452 under MIOS
- On-Screen editing of MIDI Events
- On-Screen editing of pot lables
- On-Screen editing of banknames
- up to 8 BankSticks can be connected (→ up to 128 banks)
- banks can be copied
- Remote Control via SysEx
- an optional global MIDI channel
- Morphing function which allows to fade smoothly between two pot scenes
- optional 8 CV outputs with MBHP_AOUT
- optional 64 CV outputs with MBHP_SHX8
Skills / Equipment Required
Harware
What modules do I need?
- 1x Core Module
- 0-2 AIN Module
- 1-4 DIN Module
- 0-4 DOUT Module
- 0-1 AOUT Module
- 0-1 SHX8 Module
I want 72 buttons, 10 encoders and 12 LED's. How many of each module do I need?
I'm going to build a calculator
List of parts
-list of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hool them up - links
http://www.midibox.org/users/tor_arne/midibox64_walkthrough/parts.html
Connections
-Connection diagrams - link if needed
-Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
http://www.midibox.org/users/tor_arne/midibox64_walkthrough/case.html
Software
- burning bootloader - link
- Core Tools - link
- MIOS Studio and Additional tools - link.
- The app and modification instructions
Extra
usage manual
temp_template_test.txt · Last modified: 2008/10/17 01:11 by 127.0.0.1
