wcore_line-transmit
Line Transmit
A slightly more compact version of the MBHP Line Driver Transmitter.
Schematic
MBHP Transmitter.
The two obvious differences are the J3 jumper (disconnects +5V from being sent) and the addition of a 100mil header. This way a DB-25 (or something else?) with ribbon cable mounting could be positioned off-board and wired to the line driver with an IDC.
BOM v1.0
Please find the current BOM on http://midiphy.com. The table below is depreciated and will not be updated.
Type Qty Value Package PartsMouserReicheltConradOtherNotes
Resistors
0 (2) 100R 5% THT not really needed
Capacitors
2 100nF THT 2.5mm C1, C2
ICs
2 MC3487 DIP16 IC1, IC2
IC sockets
2 DIP16
Headers
2 1*2 male
1 (0) 1*3 male
2 2*5 male
0 (1) 2*13 male
Sockets
1 (0) DB-25 female
Hardware
0 (3) M3 spacer optional, suggest to panel mount
Versions
v1.0: first release.
Assembly
Building is straightforward, just decide on whether CONN1 is the typical DB-25 or a pin header.
License
wcore_line-transmit.txt · Last modified: 2018/12/18 09:39 by latigid_on
