To daysichain multiple AOUT_NG modules, I connected J2 of the first module to J1 of the second AOUT_NG.
And as much as I understand from the Midibox_NG manual, the config for two AOUT_NGs should simply be:
AOUT type=AOUT_NG cs=1 num_channels=16 (cs=1 as I use an AINSER64 at cs=0)
After that, I should be able to address CVs 1-16
However, the second module doesn't respond. Am I missing something? If I hook my osciloscope to J2, I do see the clock signal at pin 5 but no DOUT at pin
