modules/uwindows/UWindows.h File Reference
#include "list.h"
#include "UW_Config.h"
Data Structures
struct  tstrTimer
struct  UW_CallBack
struct  UW_Window
struct  UW_ListBox
Defines
#define DEFAULT_FORM_LENGTH   160
#define DEFAULT_FORM_HEIGHT   104
#define DEFAULT_BTN_LENGTH   16
#define DEFAULT_BTN_HEIGHT   16
#define DEFAULT_EDIT_LENGTH   16
#define DEFAULT_EDIT_HEIGHT   16
#define DEFAULT_CHECK_LENGTH   16
#define DEFAULT_CHECK_HEIGHT   16
#define DEFAULT_LABEL_LENGTH   16
#define DEFAULT_LABEL_HEIGHT   16
#define DEFAULT_LIST_LENGTH   16
#define DEFAULT_LIST_HEIGHT   16
#define DEFAULT_ICON_LENGTH   32
#define DEFAULT_ICON_HEIGHT   32
#define DEFAULT_FADER_LENGTH   4
#define DEFAULT_FADER_HEIGHT   32
#define DEFAULT_POT_LENGTH   8
#define DEFAULT_POT_HEIGHT   8
#define RGB_MAKE(xR, xG, xB)
#define RGB_RED   0x00F8
#define RGB_BLACK   0x0000
#define RGB_WHITE   0xffff
#define RGB_BLUE   0x1F00
#define RGB_GREEN   0xE007
#define RGB_YELLOW   (RGB_GREEN|RGB_RED)
#define RGB_MAGENTA   (RGB_BLUE|RGB_RED)
#define RGB_LIGHTBLUE   (RGB_BLUE|RGB_GREEN)
#define RGB_ORANGE   (RGB_RED | 0xE001)
#define RGB_PINK   (RGB_MAGENTA | 0xE001)
#define GRAY   (RGB_MAKE(180,180,180))
#define BLUE   (RGB_BLUE)
#define RED   (RGB_RED)
#define BLACK   (RGB_BLACK)
#define WHITE   (RGB_WHITE)
#define SIMPLE_BLACK   0x00
#define SIMPLE_BLUE   0x01
#define SIMPLE_GRAY   0x02
#define SIMPLE_WHITE   0x03
#define CH_WIDTH   0x07
#define CH_HEIGHT   0x10
#define UW_SetType(pWindow, Type)   (pWindow->type = Type)
#define UW_SetPosition(pWindow, x, y)
#define UW_SetSize(pWindow, x, y)
#define UW_SetCaption(pWindow, pcaption, length)
#define UW_SetVisible(pWindow, vvisible)
#define UW_SetEnable(pWindow, value)
#define UW_SetOnClick(pWindow, pFunction)
#define UW_SetOnButtonPress(pWindow, pFunction)
#define UW_SetTimer(pWindow, pFunction, Duration)
#define UW_SetValue(pCheckBox, vvalue)
Enumerations
enum  UW_Type {
  UW_FORM = 0, UW_BUTTON = 1, UW_LABEL = 2, UW_EDIT = 3,
  UW_CHECKBOX = 4, UW_ICON = 5, UW_LISTBOX = 6, UW_FADER = 100,
  UW_POT = 101, UW_ENVELOPE = 102
enum  UW_ButtonState {
  PUSHED = 0, LEFT = 1, UP = 2, RIGHT = 3,
  DOWN = 4
enum  MENU_code {
  MENU_LEAVE = 0, MENU_CONTINUE = 1, MENU_REFRESH = 2, MENU_CHANGE = 3,
  MENU_CONTINUE_COMMAND = 4, MENU_LEAVE_AS_IT = 5, MENU_RESTORE_COMMAND = 6
Functions
void UW_ListBoxSetItemHeight (UW_Window *pListBox, u8 value)
 API Set List Box Items Height.
void UW_ListBoxAddItem (UW_Window *ListBox, UW_Window *Item)
 API add item to list box.
void UW_ListBoxRemoveItem (UW_Window *ListBox, UW_Window *Item)
 API remove item from list box.
UW_WindowUW_ListBoxGetActiveItem (UW_Window *ListBox)
 get active item
UW_WindowUW_ListBoxGetItem (UW_Window *ListBox, u32 index)
 get item with a certain index
s32 UW_ListBoxGetIndex (UW_Window *ListBox, UW_Window *Item)
void ialloc ()
char * UW_Malloc (unsigned long nbytes)
void UW_Free (char *ap)
void * UW_MemCpy (void *s1, const void *s2, int n)
void * UW_MemSet (void *s1, unsigned char val, int n)
Variables
UW_Window UWindows
UW_WindowpUW_Infocus
bool Refresh
Define Documentation
#define RGB_MAKE ( xR,
xG,
xB   )
Value:
( ( (xG&0x07)<<13 ) + ( (xG)>>5 )  +      \
                                 ( ((xB)>>3) << 8 )          +      \
                                 ( ((xR)>>3) << 3 ) )
#define UW_SetCaption ( pWindow,
pcaption,
length   )
Value:
do        \
        (pWindow)->caption              = (u8 *)pcaption;                       \
        (pWindow)->captionlen   = (u8)length    ;                       \
        Refresh                                 = 1;                                    \
} while(0)
#define UW_SetEnable ( pWindow,
value   )
Value:
do        \
        (pWindow)->enable               = (bool)value;                          \
        Refresh                                 = 1;                                    \
} while(0)
#define UW_SetOnButtonPress ( pWindow,
pFunction   )
Value:
do        \
        (pWindow)->CallBacks.ButtonPress        = pFunction;            \
} while(0)
#define UW_SetOnClick ( pWindow,
pFunction   )
Value:
do        \
        (pWindow)->CallBacks.Click      = (void *)pFunction;    \
} while(0)
#define UW_SetPosition ( pWindow,
x,
Value:
do        \
        (pWindow)->Absx                 = (s32)x;                       \
        (pWindow)->Absy                 = (s32)y;                       \
        Refresh                                 = 1;                    \
} while(0)
#define UW_SetSize ( pWindow,
x,
Value:
do        \
        (pWindow)->length               = (s32)x;                               \
        (pWindow)->height               = (s32)y;                               \
        Refresh                                 = 1;                            \
} while(0)
#define UW_SetTimer ( pWindow,
pFunction,
Duration   )
Value:
do        \
        (pWindow)->CallBacks.TimerCallBack.u32TimeOut = Duration;       \
        (pWindow)->CallBacks.TimerCallBack.u32CurrentTime = 0;          \
        (pWindow)->CallBacks.TimerCallBack.Timer        = pFunction;    \
} while(0)
#define UW_SetType ( pWindow,
Type   )     (pWindow->type = Type)
#define UW_SetValue ( pCheckBox,
vvalue   )
Value:
do        \
        (pCheckBox)->value              = vvalue;                                       \
        Refresh                                 = 1;                                            \
} while(0)
#define UW_SetVisible ( pWindow,
vvisible   )
Value:
do        \
        (pWindow)->visible              = (bool)vvisible;               \
        Refresh                                 = 1;                            \
} while(0)
Enumeration Type Documentation
enum MENU_code
Enumerator:
MENU_LEAVE
MENU_CONTINUE
MENU_REFRESH
MENU_CHANGE
MENU_LEAVE_AS_IT
Enumerator:
PUSHED
Joystick was just pressed down.
LEFT
Joystick was just pushed left.
UP
Joystick was just pushed up.
RIGHT
Joystick was just pushed right.
DOWN
Joystick was just pushed down.
enum UW_Type
Enumerator:
UW_FORM
UW_BUTTON
UW_LABEL
UW_EDIT
UW_CHECKBOX
UW_ICON
UW_LISTBOX
UW_FADER
UW_POT
UW_ENVELOPE
Function Documentation
void ialloc (  )
void UW_Free ( char *  ap  )
void UW_ListBoxAddItem ( UW_Window ListBox,
UW_Window Item
This is used add item to list box
Parameters:
[in] pListBox,: pointer to UWindow Object treated as ListBox
[in] Item,: a new Item, pointer t UWindow treated as EditBox
Returns:
none
UW_Window* UW_ListBoxGetActiveItem ( UW_Window ListBox  )
get active item
This is used get current item currently pointed to in ListBox
Parameters:
Returns:
pointer to UWindow Object Active Item in list Box
s32 UW_ListBoxGetIndex ( UW_Window ListBox,
UW_Window Item
UW_Window* UW_ListBoxGetItem ( UW_Window ListBox,
u32  index
Items are indexed from 0 to TotalCount-1, This is used get item with certain index
Parameters:
[in] index,: index of the Item
Returns:
void UW_ListBoxRemoveItem ( UW_Window ListBox,
UW_Window Item
This is used remove item from list box
Parameters:
Returns:
none
void UW_ListBoxSetItemHeight ( UW_Window pListBox,
u8  value
This should set List Box Items Height
Parameters:
[in] value : Height of Items
Returns:
none
char* UW_Malloc ( unsigned long  nbytes  )
void* UW_MemCpy ( void *  s1,
const void *  s2,
int  n
void* UW_MemSet ( void *  s1,
unsigned char  val,
int  n
Variable Documentation
bool Refresh
