modules/file/file.h File Reference
Data Structures
struct  file_t
Defines
#define FILE_ERR_SD_CARD   -1
#define FILE_ERR_NO_PARTITION   -2
#define FILE_ERR_NO_VOLUME   -3
#define FILE_ERR_UNKNOWN_FS   -4
#define FILE_ERR_OPEN_READ   -5
#define FILE_ERR_OPEN_READ_WITHOUT_CLOSE   -6
#define FILE_ERR_READ   -7
#define FILE_ERR_READCOUNT   -8
#define FILE_ERR_READCLOSE   -9
#define FILE_ERR_WRITE_MALLOC   -10
#define FILE_ERR_OPEN_WRITE   -11
#define FILE_ERR_OPEN_WRITE_WITHOUT_CLOSE   -12
#define FILE_ERR_WRITE   -13
#define FILE_ERR_WRITECOUNT   -14
#define FILE_ERR_WRITECLOSE   -15
#define FILE_ERR_SEEK   -16
#define FILE_ERR_OPEN_DIR   -17
#define FILE_ERR_COPY   -18
#define FILE_ERR_COPY_NO_FILE   -19
#define FILE_ERR_NO_DIR   -20
#define FILE_ERR_NO_FILE   -21
#define FILE_ERR_SYSEX_READ   -22
#define FILE_ERR_MKDIR   -23
#define FILE_ERR_INVALID_SESSION_NAME   -24
#define FILE_ERR_UPDATE_FREE   -25
#define FILE_ERR_REMOVE   -26
Functions
s32 FILE_Init (u32 mode)
s32 FILE_CheckSDCard (void)
s32 FILE_SDCardAvailable (void)
s32 FILE_VolumeAvailable (void)
u32 FILE_VolumeBytesFree (void)
u32 FILE_VolumeBytesTotal (void)
char * FILE_VolumeLabel (void)
s32 FILE_UpdateFreeBytes (void)
u32 FILE_VolumeSectorsPerCluster (void)
u32 FILE_VolumeCluster2Sector (u32 cluster)
s32 FILE_ReadOpen (file_t *file, char *filepath)
s32 FILE_ReadReOpen (file_t *file)
s32 FILE_ReadClose (file_t *file)
s32 FILE_ReadSeek (u32 offset)
u32 FILE_ReadGetCurrentSize (void)
u32 FILE_ReadGetCurrentPosition (void)
s32 FILE_ReadBuffer (u8 *buffer, u32 len)
s32 FILE_ReadBufferUnknownLen (u8 *buffer, u32 len)
s32 FILE_ReadLine (u8 *buffer, u32 max_len)
s32 FILE_ReadByte (u8 *byte)
s32 FILE_ReadHWord (u16 *hword)
s32 FILE_ReadWord (u32 *word)
s32 FILE_WriteOpen (char *filepath, u8 create)
s32 FILE_WriteClose (void)
s32 FILE_WriteSeek (u32 offset)
u32 FILE_WriteGetCurrentSize (void)
u32 FILE_WriteGetCurrentPosition (void)
s32 FILE_WriteBuffer (u8 *buffer, u32 len)
s32 FILE_WriteByte (u8 byte)
s32 FILE_WriteHWord (u16 hword)
s32 FILE_WriteWord (u32 word)
s32 FILE_Copy (char *src_file, char *dst_file)
s32 FILE_MakeDir (char *path)
s32 FILE_Remove (char *path)
s32 FILE_FileExists (char *filepath)
s32 FILE_DirExists (char *path)
s32 FILE_GetDirs (char *path, char *dir_list, u8 num_of_items, u8 dir_offset)
s32 FILE_GetFiles (char *path, char *ext_filter, char *file_list, u8 num_of_items, u8 file_offset)
s32 FILE_FindNextFile (char *path, char *filename, char *ext_filter, char *next_filename)
s32 FILE_FindPreviousFile (char *path, char *filename, char *ext_filter, char *prev_filename)
s32 FILE_SendSyxDump (char *path, mios32_midi_port_t port, u32 ms_delay_between_dumps)
s32 FILE_PrintSDCardInfos (void)
s32 FILE_SendErrorMessage (s32 error_status)
s32 FILE_BrowserHandler (mios32_midi_port_t port, char *command)
s32 FILE_BrowserUploadCallback_Init (s32(*callback_upload)(char *filename))
Variables
u32 file_dfs_errno
u8 file_copy_percentage
Define Documentation
