- D
: md5_ctx
- dac_enable
: opn2_chip_t
- dac_high
: opn2_chip_t
- dac_low
: opn2_chip_t
- dac_override
: opn2_chip_t
- dacenablereg
: opn2_chip_t
- data
: mbnet_msg_t
- data_h
: mbnet_msg_t
- data_l
: mbnet_msg_t
- data_ptr
: MINFS_file_t
- data_ptr_block_offset
: MINFS_file_t
- dataarea
: _tagVOLINFO
- database
: _FATFS_
- datatype
: LINE_CODING
- dDataLength
: _Bulk_Only_CBW
- dDataResidue
: _Bulk_Only_CSW
- deadband
: mios32_mf_config_t
- debounce_delay
: blm_config_t
, blm_scalar_config_t
, blm_x_config_t
- dec1amreg
: opn2_operator_t
- dec2reg
: opn2_operator_t
- decay
: opl3_operator_t
, sid_voice_t
- decay1rate
: opn2_operator_t
- decay2rate
: opn2_operator_t
- decaylevel
: opn2_operator_t
- decinc
: enc_state_t
- default_router
: dhcpc_state
- DEFER
: _REG
- delay_fastest
: keyboard_config_t
- delay_fastest_black_keys
: keyboard_config_t
- delay_fastest_release
: keyboard_config_t
- delay_fastest_release_black_keys
: keyboard_config_t
- delay_key
: keyboard_config_t
- delay_slowest
: keyboard_config_t
- delay_slowest_release
: keyboard_config_t
- depressed
: notestack_item_t
- dest
: opl3_channel_t
- detune
: opn2_operator_t
- DeviceSize
: mios32_sdcard_csd_t
- DeviceSizeMul
- din
: blm_scalar_config_t
- din_inverted
: keyboard_config_t
- din_key_offset
: keyboard_config_t
- din_l_sr
: blm_config_t
- din_r_sr
: blm_config_t
- din_sr1
: keyboard_config_t
- din_sr2
: keyboard_config_t
- dir
: _DIR_
- dir_ptr
: _FIL_
, file_t
- dir_sect
: _FIL_
, file_t
- dirbase
: _FATFS_
- direct_control
: mf_state_t
- direction
: mf_state_t
- diroffset
: _tagFILEINFO
- dirsector
: _tagFILEINFO
- Divider
: Matrix
- dlc
: mbnet_packet_t
- DMAIE
: _REG
- DMAIF
: _REG
- DMAST
: _REG
- Dn
: Matrix
- dnsaddr
: dhcpc_state
- Done
: TXSTATUS
- dosustain
: opl3_operator_t
- dout
- dout_cathodes
- dout_cathodes_sr1
: blm_config_t
- dout_cathodes_sr2
: blm_config_t
- dout_l1_sr
: blm_config_t
- dout_l2_sr
: blm_config_t
- dout_l3_sr
: blm_config_t
- dout_r1_sr
: blm_config_t
- dout_r2_sr
: blm_config_t
- dout_r3_sr
: blm_config_t
- dout_sr1
: keyboard_config_t
- dout_sr2
: keyboard_config_t
- down
: mf_state_t
- DPXSTAT
: PHYREG
- DribbleNibble
: RXSTATUS
- drive
: _FATFS_
- dsect
: _FIL_
, file_t
- dSignature
: _Bulk_Only_CSW
, _Bulk_Only_CBW
- DSRImpl
- dst_chn
: midi_router_node_entry_t
- dst_port
- dTag
: _Bulk_Only_CBW
, _Bulk_Only_CSW
- dummy
: sid_voice_t
, mf_state_t
, opl3_operator_t
, opl3_channel_t
, opl3_chip_t
, psg_square_t
, sid_cs_pin_t
- dummy1
: genesis_board_t
, psg_noise_t
- dummy1_cable
: mios32_midi_package_t
- dummy1_chn
- dummy1_event
- dummy2
: genesis_board_t
, opl3_chip_t
, opn2_chip_t
, opl3_channel_t
- dummy2_cable
- dummy2_chn
- dummy2_cin
- dummy2_event
- dummy3
, opn2_operator_t
- dummy3_cable
- dummy3_chn
- dummy3_cin
- dummy3_event
- dummy4
: opn2_operator_t
- dummy5
: opn2_operator_t
, opn2_chip_t
- dummy6
: opn2_operator_t
- dummy7
: opn2_operator_t
- dummy8
: opn2_chip_t
- dummy9
: opn2_operator_t
- dummy_v1
: sid_regs_t
- dummy_v1_2
: sid_regs_t
- dummy_v2
: sid_regs_t
- dummya
: opn2_channel_t
- dummyb
: opn2_chip_t
, opn2_channel_t
- dummyb4
: opn2_channel_t
- dummyc
: opn2_chip_t
- dwCBWDataTransferLength
: TCBW
- dwCBWSignature
: TCBW
- dwCBWTag
: TCBW
- dwCSWDataResidue
: TCSW
- dwCSWSignature
: TCSW
- dwCSWTag
: TCSW
- dwDTERate
: TLineCoding
Generated on 22 Jan 2016 for MIOS32 by
1.6.1
