BUFLCD
Functions
s32 BUFLCD_Init (u32 mode)
s32 BUFLCD_MaxBufferGet (void)
s32 BUFLCD_DeviceNumXSet (u8 num_x)
s32 BUFLCD_DeviceNumXGet (void)
s32 BUFLCD_DeviceNumYSet (u8 num_y)
s32 BUFLCD_DeviceNumYGet (void)
s32 BUFLCD_DeviceWidthSet (u8 width)
s32 BUFLCD_DeviceWidthGet (void)
s32 BUFLCD_DeviceHeightSet (u8 height)
s32 BUFLCD_DeviceHeightGet (void)
s32 BUFLCD_DeviceFontHandlingEnabled (void)
s32 BUFLCD_OffsetXSet (u8 offset)
s32 BUFLCD_OffsetXGet (void)
s32 BUFLCD_OffsetYSet (u8 offset)
s32 BUFLCD_OffsetYGet (void)
s32 BUFLCD_BufferGet (char *str, u8 line, u8 len)
s32 BUFLCD_Clear (void)
s32 BUFLCD_FontInit (u8 *font)
s32 BUFLCD_PrintChar (char c)
s32 BUFLCD_CursorSet (u16 column, u16 line)
s32 BUFLCD_Update (u8 force)
s32 BUFLCD_PrintString (char *str)
s32 BUFLCD_PrintFormattedString (char *format,...)
s32 BUFLCD_PrintSpaces (int num)
s32 BUFLCD_PrintStringPadded (char *str, u32 width)
Detailed Description
Buffered LCD output driver
This module provides similar functions like MIOS32_LCD, but characters are not print immediately. Instead, they will be buffered.
This method has the advantage, that multiple tasks can write to the LCD without accessing the IO pins or the requirement for semaphores (to save time)
Only changed characters (marked with flag 7 of each buffer byte) will be transfered to the LCD. This greatly improves performance as well, especially if a graphical display is connected.
Another advantage: LCD access works independent from the physical dimension of the LCDs. E.g. two 2x40 LCDs can be combined to one large 2x80 display, and BUFLCD_Update() function will take care for switching between the devices and setting the cursor.
BUFLCD_Update() has to be called periodically from a low-priority task!
Usage examples:
$MIOS32_PATH/apps/controllers/midibox_lc
$MIOS32_PATH/apps/controllers/midibox_mm
Function Documentation
s32 BUFLCD_BufferGet ( char *  str,
u8  line,
u8  len
copies the current LCD buffer line into the output string
s32 BUFLCD_Clear ( void   )
clears the buffer
s32 BUFLCD_CursorSet ( u16  column,
u16  line
sets the cursor to a new buffer location
s32 BUFLCD_DeviceFontHandlingEnabled ( void   )
Returns:
1 if GLCD font handling enabled
s32 BUFLCD_DeviceHeightGet ( void   )
Returns:
the display height (in characters) of a single LCD
s32 BUFLCD_DeviceHeightSet ( u8  height  )
sets the display height (in characters) of a single LCD
s32 BUFLCD_DeviceNumXGet ( void   )
Returns:
the number of devices which are combined to a single line
s32 BUFLCD_DeviceNumXSet ( u8  num_x  )
sets the number of devices which are combined to a single line
s32 BUFLCD_DeviceNumYGet ( void   )
Returns:
the number of devices which are available in Y direction
s32 BUFLCD_DeviceNumYSet ( u8  num_y  )
sets the number of devices which are available in Y direction
s32 BUFLCD_DeviceWidthGet ( void   )
Returns:
the display width (in characters) of a single LCD
s32 BUFLCD_DeviceWidthSet ( u8  width  )
sets the display width (in characters) of a single LCD
s32 BUFLCD_FontInit ( u8 font  )
selects a font for GLCD (only works with BUFLCD_SUPPORT_GLCD_FONTS)
s32 BUFLCD_Init ( u32  mode  )
Display Initialisation
s32 BUFLCD_MaxBufferGet ( void   )
max. number of characters depends on GLCD and BUFLCD_SUPPORT_GLCD_FONTS
s32 BUFLCD_OffsetXGet ( void   )
returns the first column at which a line is print
s32 BUFLCD_OffsetXSet ( u8  offset  )
sets the first column at which a line is print
s32 BUFLCD_OffsetYGet ( void   )
returns the first column at which characters are print
s32 BUFLCD_OffsetYSet ( u8  offset  )
sets the first line at which characters are print
s32 BUFLCD_PrintChar ( char  c  )
prints char into buffer and increments cursor
s32 BUFLCD_PrintFormattedString ( char *  format,
prints a formatted string
s32 BUFLCD_PrintSpaces ( int  num  )
prints <num> spaces
s32 BUFLCD_PrintString ( char *  str  )
prints a string
s32 BUFLCD_PrintStringPadded ( char *  str,
u32  width
prints padded string replacement for not supported "%:-40s" of simple sprintf function
s32 BUFLCD_Update ( u8  force  )
transfers the buffer to LCDs
Parameters:
[in] force if != 0, it is ensured that the whole screen will be refreshed, regardless if characters have changed or not
