MIOS32_SRIO
Functions
s32 MIOS32_SRIO_Init (u32 mode)
u8 MIOS32_SRIO_ScanNumGet (void)
s32 MIOS32_SRIO_ScanNumSet (u8 new_num_sr)
s32 MIOS32_SRIO_DoutPageGet (void)
u32 MIOS32_SRIO_DebounceGet (void)
s32 MIOS32_SRIO_DebounceSet (u8 _debounce_time)
s32 MIOS32_SRIO_DebounceStart (void)
s32 MIOS32_SRIO_ScanStart (void *_notify_hook)
Variables
volatile u8 mios32_srio_dout [MIOS32_SRIO_NUM_DOUT_PAGES][MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_din [MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_din_buffer [MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_din_changed [MIOS32_SRIO_NUM_SR]
Detailed Description
SRIO Driver for MIOS32
Function Documentation
u32 MIOS32_SRIO_DebounceGet ( void   )
Returns the debounce counter reload value of the DIN SR registers
Returns:
debounce counter reload value (0 if disabled, otherwise 1..255)
s32 MIOS32_SRIO_DebounceSet ( u8  _debounce_time  )
Sets the debounce counter reload value for the DIN SR registers which are not assigned to rotary encoders (or other drivers which get use of MIOS32_DIN_SRChangedGetAndClear()) to debounce low-quality buttons.
Debouncing is realized in the following way: on every button movement the debounce preload value will be loaded into the debounce counter register. The counter will be decremented on every SRIO update cycle (usually 1 mS) As long as this counter isn't zero, button changes will still be recorded, but they won't trigger the APP_DIN_NotifyToggle hook.
No (intended) button movement will get lost, but the latency will be increased. Example: if the update frequency is set to 1 mS, and the debounce value to 32, the first button movement will be regognized with a worst-case latency of 1 mS. Every additional button movement which happens within 32 mS will be regognized within a worst-case latency of 32 mS. After the debounce time has passed, the worst-case latency is 1 mS again.
This function affects all DIN registers. If the application should record pin changes from digital sensors which are switching very fast, then debouncing should be ommited.
Parameters:
[in] debounce_time delay in mS (1..255)
0 disables debouncing (default)
Returns:
< 0 on errors
s32 MIOS32_SRIO_DebounceStart ( void   )
Internally used function to start the debounce delay after a button has been moved.
This function is used by MIOS32_DIN_Handler(), there is no need to use it in a common application.
Returns:
< 0 on errors
s32 MIOS32_SRIO_DoutPageGet ( void   )
Returns:
the DOUT page which is currently active (counted from 0)
(changes with each SRIO update cycle)
s32 MIOS32_SRIO_Init ( u32  mode  )
Initializes SPI pins and peripheral
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
u8 MIOS32_SRIO_ScanNumGet ( void   )
Returns the number of SRs which will be scanned by the SRIO driver
Returns:
number of SRs
s32 MIOS32_SRIO_ScanNumSet ( u8  new_num_sr  )
Allows to change the number of SRs which will be scanned by the SRIO driver during runtime.
Parameters:
[in] new_num_sr must be lower or equal MIOS32_SRIO_NUM_SR
Returns:
!= 0 on errors
s32 MIOS32_SRIO_ScanStart ( void *  _notify_hook  )
(Re-)Starts the SPI IRQ Handler which scans the SRIO chain
Parameters:
[in] _notify_hook notification function which will be called after the scan has been finished (all DOUT registers written, all DIN registers read) use NULL if no function should be called
Returns:
< 0 if operation failed
Variable Documentation
volatile u8 mios32_srio_din[MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_din_buffer[MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_din_changed[MIOS32_SRIO_NUM_SR]
volatile u8 mios32_srio_dout[MIOS32_SRIO_NUM_DOUT_PAGES][MIOS32_SRIO_NUM_SR]
