MIOS32_UART_MIDI
Data Structures
struct  midi_rec_t
Functions
s32 MIOS32_UART_MIDI_Init (u32 mode)
s32 MIOS32_UART_MIDI_CheckAvailable (u8 uart_port)
s32 MIOS32_UART_MIDI_RS_OptimisationSet (u8 uart_port, u8 enable)
s32 MIOS32_UART_MIDI_RS_OptimisationGet (u8 uart_port)
s32 MIOS32_UART_MIDI_RS_Reset (u8 uart_port)
s32 MIOS32_UART_MIDI_Periodic_mS (void)
s32 MIOS32_UART_MIDI_PackageSend_NonBlocking (u8 uart_port, mios32_midi_package_t package)
s32 MIOS32_UART_MIDI_PackageSend (u8 uart_port, mios32_midi_package_t package)
s32 MIOS32_UART_MIDI_PackageReceive (u8 uart_port, mios32_midi_package_t *package)
Variables
u8 midi_rec_t::running_status
u8 midi_rec_t::expected_bytes
u8 midi_rec_t::wait_bytes
u8 midi_rec_t::sysex_ctr
u16 midi_rec_t::timeout_ctr
Detailed Description
UART MIDI layer for MIOS32
Applications shouldn't call these functions directly, instead please use MIOS32_MIDI layer functions
Function Documentation
s32 MIOS32_UART_MIDI_CheckAvailable ( u8  uart_port  )
This function can be used to determine, if a UART interface is available
Parameters:
[in] uart_port UART number (0..2)
Returns:
1: interface available
0: interface not available
Note:
Applications shouldn't call this function directly, instead please use MIOS32_MIDI layer functions
s32 MIOS32_UART_MIDI_Init ( u32  mode  )
Initializes UART MIDI layer
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
Note:
s32 MIOS32_UART_MIDI_PackageReceive ( u8  uart_port,
This function checks for a new package
Parameters:
[in] uart_port UART_MIDI module number (0..2)
[out] package pointer to MIDI package (received package will be put into the given variable
Returns:
0: no error
-1: no package in buffer
-10: incoming MIDI package timed out (incomplete package received)
Note:
s32 MIOS32_UART_MIDI_PackageSend ( u8  uart_port,
This function sends a new MIDI package to the selected UART_MIDI port (blocking function)
Parameters:
[in] package MIDI package
Returns:
0: no error
-1: UART_MIDI device not available
Note:
s32 MIOS32_UART_MIDI_PackageSend_NonBlocking ( u8  uart_port,
Parameters:
Returns:
0: no error
-2: UART_MIDI buffer is full caller should retry until buffer is free again
Note:
s32 MIOS32_UART_MIDI_Periodic_mS ( void   )
This function should be called periodically each mS to handle timeout and expire counters.
Not for use in an application - this function is called from MIOS32_MIDI_Periodic_mS(), which is called by a task in the programming model!
Returns:
< 0 on errors
s32 MIOS32_UART_MIDI_RS_OptimisationGet ( u8  uart_port  )
This function returns the running status optimisation enable/disable flag for the given MIDI OUT port.
Parameters:
Returns:
-1 if port not available
0 if optimisation disabled
1 if optimisation enabled
Note:
s32 MIOS32_UART_MIDI_RS_OptimisationSet ( u8  uart_port,
u8  enable
This function enables/disables running status optimisation for a given MIDI OUT port to improve bandwidth if MIDI events with the same status byte are sent back-to-back.
Note that the optimisation is enabled by default.
Parameters:
[in] enable 0=optimisation disabled, 1=optimisation enabled
Returns:
0 on success
Note:
s32 MIOS32_UART_MIDI_RS_Reset ( u8  uart_port  )
This function resets the current running status, so that it will be sent again with the next MIDI Out package.
Parameters:
Returns:
< 0 on errors
Note:
Variable Documentation
