MIOS32_USB_COM
Detailed Description
USB COM layer for MIOS32
Based on driver included in STM32 USB library Some code copied and modified from Virtual_COM_Port demo
Applications shouldn't call these functions directly, instead please use MIOS32_COM layer functions
- Note:
- this module can be optionally *ENABLED* in a local mios32_config.h file (included from mios32.h) by adding 'define MIOS32_USE_USB_COM' it's disabled by default, since Windows doesn't allow to use USB MIDI and CDC in parallel!
Not supported for STM32F4 (yet)
Define Documentation
| #define CLEAR_COMM_FEATURE 0x04 |
| #define GET_COMM_FEATURE 0x03 |
| #define GET_ENCAPSULATED_RESPONSE 0x01 |
| #define GET_LINE_CODING 0x21 |
| #define SEND_ENCAPSULATED_COMMAND 0x00 |
| #define SET_COMM_FEATURE 0x02 |
| #define SET_CONTROL_LINE_STATE 0x22 |
| #define SET_LINE_CODING 0x20 |
Function Documentation
| s32 MIOS32_USB_COM_CB_Data_Setup |
u8 |
RequestNo |
| s32 MIOS32_USB_COM_CB_NoData_Setup |
u8 |
RequestNo |
| void MIOS32_USB_COM_CB_StatusIn |
void |
MIOS32_USB callback functions (forwarded from STM32 USB driver)
- Note:
- Applications shouldn't call this function directly, instead please use MIOS32_COM layer functions
| s32 MIOS32_USB_COM_ChangeConnectionState |
u8 |
connected |
This function is called by the USB driver on cable connection/disconnection
- Parameters:
| [in] | connected | connection status (1 if connected) |
- Returns:
- < 0 on errors
- Note:
| s32 MIOS32_USB_COM_CheckAvailable |
void |
This function returns the connection status of the USB COM interface
- Returns:
- 1: interface available
0: interface not available
- Note:
| void MIOS32_USB_COM_EP3_OUT_Callback |
u8 |
bEP, |
u8 |
bEPStatus | |
Called by STM32 USB driver to check for OUT streams
- Note:
also: bEP, bEPStatus only relevant for LPC17xx port
void |
- Note:
| void MIOS32_USB_COM_EP4_IN_Callback |
u8 |
bEP, |
u8 |
bEPStatus | |
Called by STM32 USB driver to check for IN streams
- Note:
void |
- Note:
| s32 MIOS32_USB_COM_Init |
u32 |
mode |
Initializes USB COM layer
- Parameters:
| [in] | mode | currently only mode 0 supported |
- Returns:
- < 0 if initialisation failed
- Note:
| s32 MIOS32_USB_COM_RxBufferFree |
u8 |
usb_com |
Returns number of free bytes in receive buffer
- Parameters:
| [in] | usb_com | USB_COM number (not supported yet, should always be 0) |
- Returns:
- number of free bytes
0 if usb_com not available
- Note:
| s32 MIOS32_USB_COM_RxBufferGet |
u8 |
usb_com |
Gets a byte from the receive buffer
- Parameters:
- Returns:
- -1 if USB_COM not available
-2 if no new byte available
>= 0: received byte
- Note:
| void MIOS32_USB_COM_RxBufferHandler |
void |
| s32 MIOS32_USB_COM_RxBufferPeek |
u8 |
usb_com |
Returns the next byte of the receive buffer without taking it
- Parameters:
- Returns:
>= 0: received byte
- Note:
| s32 MIOS32_USB_COM_RxBufferUsed |
u8 |
usb_com |
Returns number of used bytes in receive buffer
- Parameters:
- Returns:
- number of used bytes
- Note:
| s32 MIOS32_USB_COM_TxBufferFree |
u8 |
usb_com |
returns number of free bytes in transmit buffer
- Parameters:
- Returns:
- Note:
| void MIOS32_USB_COM_TxBufferHandler |
void |
| s32 MIOS32_USB_COM_TxBufferPut |
u8 |
usb_com, |
u8 |
b | |
puts a byte onto the transmit buffer
(blocking function)
- Parameters:
| [in] | b | byte which should be put into Tx buffer |
- Returns:
- 0 if no error
-3 if USB_COM not supported by MIOS32_USB_COM_TxBufferPut Routine
- Note:
| s32 MIOS32_USB_COM_TxBufferPut_NonBlocking |
u8 |
usb_com, |
u8 |
b | |
- Parameters:
- Returns:
- 0 if no error
-2 if buffer full (retry)
- Note:
| s32 MIOS32_USB_COM_TxBufferPutMore |
u8 |
usb_com, |
u8 * |
buffer, |
u16 |
len | |
puts more than one byte onto the transmit buffer (used for atomic sends)
(blocking function)
- Parameters:
| [in] | *buffer | pointer to buffer which should be transmitted |
| [in] | len | number of bytes which should be transmitted |
- Returns:
- 0 if no error
-4 if too many bytes should be sent
- Note:
| s32 MIOS32_USB_COM_TxBufferPutMore_NonBlocking |
u8 |
usb_com, |
u8 * |
buffer, |
u16 |
len | |
- Parameters:
- Returns:
- 0 if no error
-2 if buffer full or cannot get all requested bytes (retry)
- Note:
| s32 MIOS32_USB_COM_TxBufferUsed |
u8 |
usb_com |
Returns number of used bytes in transmit buffer
- Parameters:
- Returns:
- Note:
| u8 * Virtual_Com_Port_SetLineCoding |
u16 |
Length |
Variable Documentation
Initial value: {
115200,
0x00,
0x00,
0x08
Initial value: {
115200,
0x00,
0x00,
0x08
