Functions | |
void | shell_init (void) |
void | shell_start (void) |
void | shell_input (char *command) |
void | shell_quit (char *) |
void | shell_output (char *str1, char *str2) |
void | shell_prompt (char *prompt) |
void shell_init | ( | void | ) |
Initialize the shell.
Called when the shell front-end process starts. This function may be used to start listening for signals.
void shell_input | ( | char * | command | ) |
Process a shell command.
This function will be called by the shell GUI / telnet server whan a command has been entered that should be processed by the shell back-end.
command | The command to be processed. |
void shell_output | ( | char * | str1, | |
char * | str2 | |||
Print a string to the shell window.
This function is implemented by the shell GUI / telnet server and can be called by the shell back-end to output a string in the shell window. The string is automatically appended with a linebreak.
str1 | The first half of the string to be output. | |
str2 | The second half of the string to be output. |
void shell_prompt | ( | char * | prompt | ) |
Print a prompt to the shell window.
This function can be used by the shell back-end to print out a prompt to the shell window.
prompt | The prompt to be printed. |
void shell_quit | ( | char * | ) |
Quit the shell.
void shell_start | ( | void | ) |
Start the shell back-end.
Called by the front-end when a new shell is started.
