tk_gm5_jaycar_partlist
WIP
Bulk order is closed, PM's have been sent please reply ASAP, Levon
Aussie order
Nick Base kits Extra ports (Max 4 per base kit) Midi Cables
Durisian 5 16
Levon 5 20 4
drboom 2 8
H2O 2 4
Wilba 2 8
/tilted/ 10 40
diablojoy 5 12
theprotool 7 28
matoz 10 40 8
j00lz 2 8
goldbug 4 8 8
TOTAL5418820
stryd_one 10 40 Waiting for next batch
Prices for the GM5 USB-Midi interface
Base Kit
www.jaycar.com.au
Prices correct from 07/07/08
Description Qty Part # Price Bulk 10+ Bulk 25+ Bulk 50+ Bulk 100+
Crystal 16 MHz 1 NA
Optocoupler 6N138 1 6N 138 4.25 3.75 2.90
Optocoupler 6N138 10PACK 1 ZD1943 19.95 17.70 13.70
Serial EEPROM 24C04 (Optional!) 1
IC-Socket for Optocoupler and EEPROM 1 PI6452 1.00 0.90 0.80
Resistor 4.7 kOhm pk of 8 1 RR0588 0.38 0.34 0.31
Resistor 1 kOhm pk of 8 3 ???? * 0.38 0.34 0.31
Resistor 220 Ohm pk of 8 4 RR0556 0.38 0.34 0.31
Ceramic Cap 100 nF pk of 2 2 RC5360 0.28 0.19 0.16
Ceramic Cap 1000 nF (1 uF) 1 ???? * 0.28 0.19 0.16
Ceramic Cap 22 pF pk of 2 2 RC5316 0.28 0.19 0.16
Polarised Capacitor 10 uF 1 RE6066 0.20 0.14 0.12
Diode 1N4148 pk of 5 1 ZR1100 0.32 0.28 0.26
Green Rx/Tx LED 1 ZD0120 0.20 0.18 0.14
USB Socket B-Type for PCB mounting 1 PS0920 2.20 1.95 1.75
MIDI sockets for PCB mounting 2 PS0350 1.70 1.50 1.35
2-row SIL Headers (2*5 and 2 pins) 1 HM3250 1.44 1.15
18.89
* i couldn't find some parts on the jaycar website, some of the prices are approximated
^ need to buy 25+ to get discount
t Midi Sockets $1.35 when ordering 50+
http://www.rockby.com.au
Description Qty Stock # Price bulk 10+ Bulk 100+
Crystal 16 MHz 1 13681 2.118 1.906
Optocoupler 6N138 1 26172 2.110 1.900
IC-Socket for Optocoupler and EEPROM 1 13746 0.770 0.501 0.300
Resistor 4.7 kOhm 1 15312 0.044 0.013
Resistor 1 kOhm 3 28694 0.088 * 0.033
Resistor 220 Ohm 4 15336 0.044 0.013
Ceramic Cap 100 nF 2 13091 0.090 0.065
Ceramic Cap 1000 nF (1 uF) 1 19800 0.545 0.490 0.429
Ceramic Cap 22 pF 2 13049 0.090 0.065
Polarised Capacitor 10 uF 1 24449 0.194 0.174
Diode 1N4148 1 13992 0.050 0.030 0.025
Green Rx/Tx LED 1 15096 0.182 0.163 0.099
USB Socket B-Type for PCB mounting 1 29893 0.847 0.561
MIDI sockets *not suitable for Surface mounting 2 14206 2.299 2.069
MIDI CABLE 1.8m 14447 2.695 2.035
12.08
* 1K 1/4W were out of stock, these are 1K 1/2W
Extra Port
Description Qty Price
Optocoupler 6N138 1
Resistor 4.7 kOhm 1
Resistor 1 kOhm 1
Resistor 220 Ohm 3
$7 ish
There is an option to do a Split Buy from Jaycar and Rockby. the optocoupler is cheaper at Jaycar, and also Rockby's midi ports are not suitable for Surface mounting, and are cheaper at Jaycar. (levon)
Is there a reason the rockby midi ports are not suitable? they look pretty standard to me… (durisian)
I sware someone changed the image on the rockby site, when i checked a while ago it wasn't a surface mounting port, what im confused is the plug says its 180deg.. not 90deg like the image (levon) still , the optocouplers at jaycar are alot cheaper.. $13 for a 10 pack at jaycar… $19 for 10 at rockby. we would save around 50c per midi port. seeing as we are buying 219 optocouplers and 438 midi ports… thats about $250 difference.
We are now looking at 100+ for almost all items
I have been doing some calculations in spreadsheets, looks like we will get the following prices:
base kit extra port
Jaycar 10.01 * 5.07
Rockby 10.87 6.5
Split purchase 9.84 4.48
*excluding crystal
tk_gm5_jaycar_partlist.txt · Last modified: 2008/11/24 04:55 by levon
