modules/uwindows/UWindows.c File Reference
#include <mios32.h>
#include <app_lcd.h>
#include "UWindows.h"
#include "UW_CharSet.h"
Defines
#define MAX_X   128
#define MAX_Y   64
#define CURSOR_SIZE   3
Functions
void swap (u32 *a, u32 *b)
void UW_Add (UW_Window *pWindow, UW_Type Type, UW_Window *pParent, void *ExtraProperties)
 API to add a new UWindow.
void UW_DrawLine (s32 x1, s32 y1, s32 x2, s32 y2, u16 color)
void UW_ListBoxSetItemHeight (UW_Window *pListBox, u8 value)
 API Set List Box Items Height.
void UW_ListBoxAddItem (UW_Window *ListBox, UW_Window *Item)
 API add item to list box.
void UW_ListBoxRemoveItem (UW_Window *ListBox, UW_Window *Item)
 API remove item from list box.
UW_Window * UW_ListBoxGetActiveItem (UW_Window *ListBox)
 get active item
UW_Window * UW_ListBoxGetItem (UW_Window *ListBox, u32 index)
 get item with a certain index
s32 UW_ListBoxGetIndex (UW_Window *ListBox, UW_Window *Item)
void ExitUWindows (void)
 Eixt Windows.
void UW_Init (void)
 API to initialize UWindows.
void UW_Run (void)
 API main running function of UWindows.
Variables
const char ExitLabel [] = "SHUT DOWN"
bool Refresh
bool bExit
UW_Window UWindows
UW_Window ExitBtn
u8 UWImage [4 *1040]
u16 Colors [4] = {BLACK,BLUE,GRAY,WHITE}
UW_Window * pUW_Infocus
u8 CursorXPos
u8 CursorYPos
const u8 CurrentFont [224 *14]
Define Documentation
#define MAX_X   128
#define MAX_Y   64
Function Documentation
void ExitUWindows ( void   )
Eixt Windows.
set bExit Flag to exit Windows
Returns:
none
void swap ( u32 *  a,
u32 *  b
void UW_Add ( UW_Window *  pWindow,
UW_Type  Type,
UW_Window *  pParent,
void *  ExtraProperties
This function will : add a new UWindow Objet to pParent do all nessecary and default initializations attach the New Window to its extra properties if available
Parameters:
[in] pWindow : Pointer to new window object
[in] Type : Type of the new windows
[in] pParent : Ponter to Parent window
[in] ExtraProperties : Pointer to Extra properties object
Returns:
none
void UW_DrawLine ( s32  x1,
s32  y1,
s32  x2,
s32  y2,
u16  color
void UW_Init ( void   )
This should be called at Application Init
Returns:
none
void UW_ListBoxAddItem ( UW_Window *  ListBox,
UW_Window *  Item
This is used add item to list box
Parameters:
[in] pListBox,: pointer to UWindow Object treated as ListBox
[in] Item,: a new Item, pointer t UWindow treated as EditBox
Returns:
none
UW_Window* UW_ListBoxGetActiveItem ( UW_Window *  ListBox  )
get active item
This is used get current item currently pointed to in ListBox
Parameters:
Returns:
pointer to UWindow Object Active Item in list Box
s32 UW_ListBoxGetIndex ( UW_Window *  ListBox,
UW_Window *  Item
UW_Window* UW_ListBoxGetItem ( UW_Window *  ListBox,
u32  index
Items are indexed from 0 to TotalCount-1, This is used get item with certain index
Parameters:
[in] index,: index of the Item
Returns:
void UW_ListBoxRemoveItem ( UW_Window *  ListBox,
UW_Window *  Item
This is used remove item from list box
Parameters:
Returns:
none
void UW_ListBoxSetItemHeight ( UW_Window *  pListBox,
u8  value
This should set List Box Items Height
Parameters:
[in] value : Height of Items
Returns:
none
void UW_Run ( void   )
This should be called at Application Handler
Returns:
none
Variable Documentation
bool bExit
u16 Colors[4] = {BLACK,BLUE,GRAY,WHITE}
const u8 CurrentFont[224 *14]
const char ExitLabel[] = "SHUT DOWN"
bool Refresh
u8 UWImage[4 *1040]
