MIOS32_ENC28J60
Defines
#define MIOS32_ENC28J60_MUTEX_TAKE   {}
#define MIOS32_ENC28J60_MUTEX_GIVE   {}
#define WCR   (0x2<<5)
#define BFS   (0x4<<5)
#define BFC   (0x5<<5)
#define RCR   (0x0<<5)
#define RBM   ((0x1<<5) | 0x1A)
#define WBM   ((0x3<<5) | 0x1A)
#define SR   ((0x7<<5) | 0x1F)
#define CSN_0   { MIOS32_SPI_RC_PinSet(MIOS32_ENC28J60_SPI, MIOS32_ENC28J60_SPI_RC_PIN, 0); }
#define CSN_1   { MIOS32_SPI_RC_PinSet(MIOS32_ENC28J60_SPI, MIOS32_ENC28J60_SPI_RC_PIN, 1); }
#define RAMSIZE   0x2000
#define RXSTART   0x0000
#define RXEND   0x0FFF
#define TXSTART   0x1000
#define TXEND   0x1fff
#define RXSTOP   ((TXSTART - 2) | 0x0001)
#define RXSIZE   (RXSTOP - RXSTART + 1)
Functions
struct __attribute__ ((packed))
s32 MIOS32_ENC28J60_Init (u32 mode)
s32 MIOS32_ENC28J60_PowerOn (void)
s32 MIOS32_ENC28J60_PowerOff (void)
s32 MIOS32_ENC28J60_CheckAvailable (u8 was_available)
s32 MIOS32_ENC28J60_LinkAvailable (void)
s32 MIOS32_ENC28J60_RevIDGet (void)
s32 MIOS32_ENC28J60_MAC_AddrSet (u8 new_mac_addr[6])
u8 * MIOS32_ENC28J60_MAC_AddrGet (void)
s32 MIOS32_ENC28J60_PackageSend (u8 *buffer, u16 len, u8 *buffer2, u16 len2)
s32 MIOS32_ENC28J60_PackageReceive (u8 *buffer, u16 buffer_size)
s32 MIOS32_ENC28J60_MACDiscardRx (void)
s32 MIOS32_ENC28J60_ReadETHReg (u8 address)
s32 MIOS32_ENC28J60_ReadMACReg (u8 address)
s32 MIOS32_ENC28J60_ReadPHYReg (u8 reg)
s32 MIOS32_ENC28J60_WriteReg (u8 address, u8 data)
s32 MIOS32_ENC28J60_BFCReg (u8 address, u8 data)
s32 MIOS32_ENC28J60_BFSReg (u8 address, u8 data)
s32 MIOS32_ENC28J60_WritePHYReg (u8 reg, u16 data)
s32 MIOS32_ENC28J60_BankSel (u16 reg)
s32 MIOS32_ENC28J60_SendSystemReset (void)
s32 MIOS32_ENC28J60_MACGet (void)
s32 MIOS32_ENC28J60_MACGetArray (u8 *buffer, u16 len)
s32 MIOS32_ENC28J60_MACPut (u8 value)
s32 MIOS32_ENC28J60_MACPutArray (u8 *buffer, u16 len)
Variables
 ENC_PREAMBLE
Detailed Description
ENC28J60 is accessed via SPI1 (J16) or alternatively via SPI2 (J8/9) A bitbanging solution (for using alternative ports) will be provided later.
The chip has to be supplied with 3.3V!
MIOS32_ENC28J60_Init(0) has to be called only once to initialize the driver.
MIOS32_ENC28J60_CheckAvailable() should be called to connect with the device. If 0 is returned, it can be assumed that no ENC28J60 chip is connected. The function can be called periodically from a low priority task to retry a connection, resp. for an auto-detection during runtime
Most parts of the driver have been taken from ENC28J60.c file of the Microchip TCP/IP stack, and adapted to MIOS32 routines.
philetaylor (07 Jan 10): I have added mutex support. As many functions are not used externally they rely on the mutex being taked/given by the calling function. Please bear this in mind if calling functions directly. Only MIOS32_ENC28J60_Init(), MIOS32_ENC28J60_CheckAvailable() MIOS32_ENC28J60_PackageSend() and MIOS32_ENC28J60_PackageReceive() Will handle mutexes themselves all other functions will not.
Define Documentation
Function Documentation
struct __attribute__ ( (packed)   )  [read]
s32 MIOS32_ENC28J60_BankSel ( u16  reg  )
Takes the high byte of a register address and changes the bank select bits in ETHCON1 to match.
Parameters:
[in] reg Register address with the high byte containing the two bank select bits.
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_BFCReg ( u8  address,
u8  data
Sends the 8 bit BFC opcode/Address byte over the SPI and then sends the data in the next 8 SPI clocks
This routine is almost identical to the MIOS32_ENC28J60_WriteReg() and MIOS32_ENC28J60_BFSReg() functions. It is separate to maximize speed.
MIOS32_ENC28J60_BFCReg() must only be used on ETH registers.
Parameters:
[in] address 5 bit address of the register to modify. The top 3 bits must be 0
[in] data Byte to be used with the Bit Field Clear operation
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_BFSReg ( u8  address,
u8  data
Sends the 8 bit BFS opcode/Address byte over the SPI and then sends the data in the next 8 SPI clocks
This routine is almost identical to the MIOS32_ENC28J60_WriteReg() and MIOS32_ENC28J60_BFCReg() functions. It is separate to maximize speed.
MIOS32_ENC28J60_BFSReg() must only be used on ETH registers.
Parameters:
[in] data Byte to be used with the Bit Field Set operation
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_CheckAvailable ( u8  was_available  )
Checks if the chip is still connected by reading the revision ID.
This takes ca. 2 uS
If the ID value is within the range of 0x01..0x1f, MIOS32_ENC28J60_PowerOn() will be called by this function to initialize the device completely.
Example for Connection/Disconnection detection:
 // this function is called each second from a low-priority task
 // If multiple tasks are accessing the ENC28J60 chip, add a semaphore/mutex
 //  to avoid IO access collisions with other tasks!
 u8 enc28j60_available;
 s32 ETHERNET_CheckENC28J60(void)
   // check if ENC28J60 is connected
   u8 prev_enc28j60_available = enc28j60_available;
   enc28j60_available = MIOS32_ENC28J60_CheckAvailable(prev_enc28j60_available);
   if( enc28j60_available && !prev_enc28j60_available ) {
     // ENC28J60 has been connected
     // now it's possible to receive/send packages
   } else if( !enc28j60_available && prev_enc28j60_available ) {
     // ENC28J60 has been disconnected
     // here you can notify your application about this state
   return 0; // no error
Parameters:
[in] was_available should only be set if the ENC28J60 was previously available
Returns:
0 if no response from ENC28J60
1 if ENC28J60 is accessible
s32 MIOS32_ENC28J60_Init ( u32  mode  )
Initializes SPI pins and peripheral to access ENC28J60
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
s32 MIOS32_ENC28J60_LinkAvailable ( void   )
Returns the PHSTAT1.LLSTAT bit (ethernet cable connected)
Returns:
0 if ethernet cable not connected
1 if ethernet cable connected and link available
u8* MIOS32_ENC28J60_MAC_AddrGet ( void   )
Returns the current MAC address
Returns:
u8 pointer with 6 bytes
s32 MIOS32_ENC28J60_MAC_AddrSet ( u8  new_mac_addr[6]  )
Changes the MAC address.
Usually called by MIOS32_ENC28J60_PowerOn(), but could also be used during runtime.
The default MAC address is predefined by MIOS32_ENC28J60_MY_MAC_ADDR[123456] and can be overruled in mios32_config.h if desired.
Parameters:
[in] new_mac_addr an array with 6 bytes which define the MAC address. If all bytes are 0 (default), the serial number of STM32 will be taken instead, which should be unique in your private network.
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_MACDiscardRx ( void   )
Marks the last received packet (obtained using MIOS32_ENC28J60_PackageReceive()) as being processed and frees the buffer memory associated with it
It is safe to call this function multiple times between MIOS32_ENC28J60_PackageReceive() calls. Extra packets won't be thrown away until MIOS32_ENC28J60_PackageReceive() makes it available.
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_MACGet ( void   )
Returns the byte pointed to by ERDPT and increments ERDPT so MIOS32_ENC28J60_MACGet() can be called again. The increment will follow the receive buffer wrapping boundary.
EWRPT is incremented after the read.
Returns:
< 0 on errors
>= 0: Byte read from the ENC28J60's RAM
s32 MIOS32_ENC28J60_MACGetArray ( u8 *  buffer,
u16  len
Burst reads several sequential bytes from the data buffer and places them into local memory. With SPI burst support, it performs much faster than multiple MIOS32_ENC28J60_MACGet() calls.
ERDPT is incremented after each byte, following the same rules as MIOS32_ENC28J60_MACGet()
Parameters:
[in] buffer target buffer
[in] len number of bytes which should be read
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_MACPut ( u8  value  )
Outputs the Write Buffer Memory opcode/constant (8 bits) and data to write (8 bits) over the SPI.
EWRPT is incremented after the write.
Parameters:
[in] value Byte to write into the ENC28J60 buffer memory
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_MACPutArray ( u8 *  buffer,
u16  len
writes several sequential bytes to the ENC28J60 RAM. It performs faster than multiple MIOS32_ENC28J60_MACPut() calls.
EWRPT is incremented by len.
Parameters:
[in] buffer source buffer
[in] len number of bytes which should be written
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_PackageReceive ( u8 *  buffer,
u16  buffer_size
Receives a package from ENC28J60 chip param[in] buffer Pointer to buffer which gets the playload param[in] buffer_size Max. number of bytes which can be received
Returns:
< 0 on errors
-16 if inconsistencies have been detected, and the ENC28J60 device has been reseted
0 if no package has been received
> 0 number of received bytes
s32 MIOS32_ENC28J60_PackageSend ( u8 *  buffer,
u16  len,
u8 *  buffer2,
u16  len2
Sends a package to the ENC28J60 chip param[in] buffer Pointer to buffer which contains the playload param[in] len number of bytes which should be sent param[in] buffer2 Pointer to optional second buffer which contains additional playload (can be NULL if no additional data) param[in] len2 number of bytes in second buffer (should be 0 if no additional data)
Returns:
< 0 on errors
-16 if previous package hasn't been sent yet (this is checked 1000 times before the function exits)
s32 MIOS32_ENC28J60_PowerOff ( void   )
Disconnects from ENC28J60
Returns:
< 0 on errors
Todo:
not implemented yet
s32 MIOS32_ENC28J60_PowerOn ( void   )
Connects to ENC28J60 chip
Returns:
< 0 if initialisation sequence failed
-16 if clock not ready after system reset
-17 if unsupported revision ID
s32 MIOS32_ENC28J60_ReadETHReg ( u8  address  )
Sends the 8 bit RCR opcode/Address byte over the SPI and then retrives the register contents in the next 8 SPI clocks.
This routine cannot be used to access MAC/MII or PHY registers. Use MIOS32_ENC28J60_ReadMACReg() or MIOS32_ENC28J60_ReadPHYReg() for that purpose.
Parameters:
[in] address 5 bit address of the ETH control register to read from.
Returns:
< 0 on errors
>= 0: Byte read from the Ethernet controller's ETH register.
s32 MIOS32_ENC28J60_ReadMACReg ( u8  address  )
Sends the 8 bit RCR opcode/Address byte as well as a dummy byte over the SPI and then retrives the register contents in the last 8 SPI clocks.
This routine cannot be used to access ETH or PHY registers. Use MIOS32_ENC28J60_ReadETHReg() or MIOS32_ENC28J60_ReadPHYReg() for that purpose.
Parameters:
[in] address 5 bit address of the MAC or MII register to read from.
Returns:
< 0 on errors
>= 0: Byte read from the Ethernet controller's MAC/MII register.
s32 MIOS32_ENC28J60_ReadPHYReg ( u8  reg  )
Performs an MII read operation. While in progress, it simply polls the MII BUSY bit wasting time (10.24us).
Parameters:
[in] reg Address of the PHY register to read from.
Returns:
< 0 on errors
>= 0: u16 read from the Ethernet controller's MAC/MII register.
s32 MIOS32_ENC28J60_RevIDGet ( void   )
Returns ENC28J60 Revision ID
Value is only valid if MIOS32_ENC28J60_PowerOn() passed without errors.
Returns:
revision id (8-bit value)
s32 MIOS32_ENC28J60_SendSystemReset ( void   )
Sends the System Reset SPI command to the Ethernet controller. It resets all register contents (except for ECOCON) and returns the device to the power on default state.
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_WritePHYReg ( u8  reg,
u16  data
Performs an MII write operation.
While in progress, it simply polls the MII BUSY bit wasting time.
Alters bank bits to point to Bank 3
Parameters:
[in] reg Address of the PHY register to write to.
[in] data 16 bits of data to write to PHY register.
Returns:
< 0 on errors
s32 MIOS32_ENC28J60_WriteReg ( u8  address,
u8  data
Sends the 8 bit WCR opcode/Address byte over the SPI and then sends the data in the next 8 SPI clocks
This routine is almost identical to the MIOS32_ENC28J60_BFCReg() and MIOS32_ENC28J60_BFSReg() functions. It is separate to maximize speed.
Unlike the MIOS32_ENC28J60_ReadETHReg/MIOS32_ENC28J60_ReadMACReg functions, MIOS32_ENC28J60_WriteReg() can write to any ETH or MAC register. Writing to PHY registers must be accomplished with MIOS32_ENC28J60_WritePHYReg().
Parameters:
[in] address 5 bit address of the ETH, MAC, or MII register to modify. The top 3 bits must be 0
[in] data Byte to be written into register
Returns:
< 0 on errors
Variable Documentation
