MIOS32_OSC
Functions
s32 MIOS32_OSC_Init (u32 mode)
u32 MIOS32_OSC_GetWord (u8 *buffer)
u8 * MIOS32_OSC_PutWord (u8 *buffer, u32 word)
mios32_osc_timetag_t MIOS32_OSC_GetTimetag (u8 *buffer)
u8 * MIOS32_OSC_PutTimetag (u8 *buffer, mios32_osc_timetag_t timetag)
s32 MIOS32_OSC_GetInt (u8 *buffer)
u8 * MIOS32_OSC_PutInt (u8 *buffer, s32 value)
float MIOS32_OSC_GetFloat (u8 *buffer)
u8 * MIOS32_OSC_PutFloat (u8 *buffer, float value)
char * MIOS32_OSC_GetString (u8 *buffer)
u8 * MIOS32_OSC_PutString (u8 *buffer, char *str)
u32 MIOS32_OSC_GetBlobLength (u8 *buffer)
u8 * MIOS32_OSC_GetBlobData (u8 *buffer)
u8 * MIOS32_OSC_PutBlob (u8 *buffer, u8 *data, u32 len)
long long MIOS32_OSC_GetLongLong (u8 *buffer)
u8 * MIOS32_OSC_PutLongLong (u8 *buffer, long long value)
double MIOS32_OSC_GetDouble (u8 *buffer)
u8 * MIOS32_OSC_PutDouble (u8 *buffer, double value)
char MIOS32_OSC_GetChar (u8 *buffer)
u8 * MIOS32_OSC_PutChar (u8 *buffer, char c)
mios32_midi_package_t MIOS32_OSC_GetMIDI (u8 *buffer)
u8 * MIOS32_OSC_PutMIDI (u8 *buffer, mios32_midi_package_t p)
s32 MIOS32_OSC_ParsePacket (u8 *packet, u32 len, const mios32_osc_search_tree_t *search_tree)
s32 MIOS32_OSC_SendDebugMessage (mios32_osc_args_t *osc_args, u32 method_arg)
Detailed Description
Functions to send and parse OSC packets
Based on OSC Spec v1.0 http://opensoundcontrol.org/spec-1_0
(please read for background info and nomenclature)
Optimized for embedded systems which provide more code memory (flash) than RAM.
Server Part (parsing incoming OSC packets):
MIOS32_OSC_ParsePacket() has to be called with the OSC package content, packet length and a pointer to the "search tree".
The search tree allows the parser to match parts of the OSC address path which are separated with the '/' delimiter. At the end of a search tree we will find the OSC method which is called with the arguments that are part of the OSC packet.
Usually the search tree is located in flash memory, since it won't change during runtime. Each node of the tree consists of a mios32_osc_search_tree_t structure which defines:
So, a node either defines the link to the next node which is part of the address path, or it defines the method which should be called.
The optional 32bit argument could be useful for re-using the same function for multiple purposes to save memory. Each node contains such an argument value.
It is ORed for each individual path while scanning the search tree, so that it is possible to allocate certain bitfields for each node (e.g. /sid* will add the SID number to bit [31:30] of the argument value, and /sid?/*/<method> will add the parameter address)
OSC allows to use wildcards in the address path like *, ?, [] and {}.
The MIOS32 implementation currently only supports '*' and '?'
Examples: '/sid?/osc/finetune' or '/sid?/osc/fine*' or '/cs/led/*'
While searching through the tree, the appr. functions of all matching methods will be called with the OSC arguments which are part of the packet (+ the method argument):
   s32 osc_method(mios32_osc_args_t *osc_args, u32 method_arg)
All specified OSC arguments are supported, such as following "tags":
Arguments are stored in mios32_osc_args_t before the OSC method function is called.
This structure contains:
An example for a search tree construction and OSC method handling can be found under $MIOS32_PATH/apps/examples/ethernet/osc
Client Part (sending OSC packets):
Outgoing OSC packets can be "constructed" on-the-fly with MIOS32_OSC_Put* functions.
No high-level functions (with large argument lists) are provided to save stack space, and to give the application the highest flexibility. Even unspecified OSC packages can be created if desired.
Following example demonstrates the usage. Note that each MIOS32_OSC_Put* function returns the pointer to the next entry, so that items can be appended without the need for additional pointer calculations.
 // Send a Button Value
 // Path: /cs/button/state <button-number> <0 or 1>
 s32 OSC_CLIENT_SendButtonState(mios32_osc_timetag_t timetag, u32 button, u8 pressed)
   // create the OSC packet
   u8 packet[128];
   u8 *end_ptr = packet;
   u8 *insert_len_ptr;
   end_ptr = MIOS32_OSC_PutString(end_ptr, "#bundle");
   end_ptr = MIOS32_OSC_PutTimetag(end_ptr, timetag);
   insert_len_ptr = end_ptr; // remember this address - we will insert the length later
   end_ptr += 4;
   end_ptr = MIOS32_OSC_PutString(end_ptr, "/cs/button/state");
   end_ptr = MIOS32_OSC_PutString(end_ptr, ",ii");
   end_ptr = MIOS32_OSC_PutInt(end_ptr, button);
   end_ptr = MIOS32_OSC_PutInt(end_ptr, pressed);
   // now insert the message length
   MIOS32_OSC_PutWord(insert_len_ptr, (u32)(end_ptr-insert_len_ptr-4));
   // send packet and exit
   return OSC_SERVER_SendPacket(packet, (u32)(end_ptr-packet));
Function Documentation
u8* MIOS32_OSC_GetBlobData ( u8 *  buffer  )
Returns the data part of a Blob
Parameters:
[in] buffer pointer to OSC message buffer
Returns:
pointer to data part of a Blob
u32 MIOS32_OSC_GetBlobLength ( u8 *  buffer  )
Returns the length of a Blob
Parameters:
Returns:
blob length
char MIOS32_OSC_GetChar ( u8 *  buffer  )
Returns a character
Parameters:
Returns:
a single character
double MIOS32_OSC_GetDouble ( u8 *  buffer  )
Gets two words (8 bytes) from buffer and converts them to a float with double precession
Parameters:
Returns:
float with double procession
float MIOS32_OSC_GetFloat ( u8 *  buffer  )
Gets a word (4 bytes) from buffer and converts it to a float with normal precession
Parameters:
Returns:
float with normal procession
s32 MIOS32_OSC_GetInt ( u8 *  buffer  )
Gets a word (4 bytes) from buffer and converts it to a 32bit signed integer.
Parameters:
Returns:
long long MIOS32_OSC_GetLongLong ( u8 *  buffer  )
Gets two words (8 bytes) from buffer and converts them to a 64bit signed integer.
Parameters:
Returns:
mios32_midi_package_t MIOS32_OSC_GetMIDI ( u8 *  buffer  )
Returns a MIDI package
Note:
doesn't work with SysEx streams - they have to be handled separately
Parameters:
Returns:
a MIOS32 compliant MIDI package
char* MIOS32_OSC_GetString ( u8 *  buffer  )
Returns pointer to a string in message buffer
Parameters:
Returns:
zero-terminated string
mios32_osc_timetag_t MIOS32_OSC_GetTimetag ( u8 *  buffer  )
Gets a timetag (8 bytes) from buffer
Parameters:
Returns:
timetag (seconds and fraction part)
u32 MIOS32_OSC_GetWord ( u8 *  buffer  )
Parameters:
Returns:
32bit unsigned integer
s32 MIOS32_OSC_Init ( u32  mode  )
Initializes OSC layer
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
s32 MIOS32_OSC_ParsePacket ( u8 *  packet,
u32  len,
const mios32_osc_search_tree_t *  search_tree
Parses an incoming OSC packet and calls OSC methods defined in search_tree on matching addresses
Parameters:
[in] packet pointer to OSC packet
[in] len length of packet
[in] search_tree a tree which defines address parts and methods to be called
Returns:
0 if packet has been parsed w/o errors
-1 if packet format invalid
-2 if the packet contains an OSC element with invalid format
-3 if the packet contains an OSC element with an unsupported format returns -4 if MIOS32_OSC_MAX_PATH_PARTS has been exceeded
u8* MIOS32_OSC_PutBlob ( u8 *  buffer,
u8 *  data,
u32  len
Puts an OSC-Blob into buffer and pads with 0 until word boundary has been reached
Parameters:
[in] data blob data
[in] len blob size
Returns:
buffer pointer behind the inserted entry
u8* MIOS32_OSC_PutChar ( u8 *  buffer,
char  c
Puts a character into buffer and pads with 3 zeros (word aligned)
Parameters:
[in] c the character which should be inserted
Returns:
u8* MIOS32_OSC_PutDouble ( u8 *  buffer,
double  value
Puts a float with double precission into buffer
Parameters:
[in] value the double value which should be inserted
Returns:
u8* MIOS32_OSC_PutFloat ( u8 *  buffer,
float  value
Puts a float with normal precission into buffer
Parameters:
[in] value the float value which should be inserted
Returns:
u8* MIOS32_OSC_PutInt ( u8 *  buffer,
s32  value
Puts a 32bit signed integer into buffer
Parameters:
[in] value the integer value which should be inserted
Returns:
u8* MIOS32_OSC_PutLongLong ( u8 *  buffer,
long long  value
Puts a 64bit signed integer into buffer
Parameters:
[in] value the "long long" value which should be inserted
Returns:
u8* MIOS32_OSC_PutMIDI ( u8 *  buffer,
Puts a MIDI package into buffer
Note:
Parameters:
[in] p the MIDI package which should be inserted
Returns:
u8* MIOS32_OSC_PutString ( u8 *  buffer,
char *  str
Puts a string into buffer and pads with 0 until word boundary has been reached
Parameters:
[in] value the string which should be inserted
Returns:
u8* MIOS32_OSC_PutTimetag ( u8 *  buffer,
Puts a timetag (8 bytes) into buffer
Parameters:
[in] timetag the timetag which should be inserted
Returns:
u8* MIOS32_OSC_PutWord ( u8 *  buffer,
u32  word
Puts a word (4 bytes) into buffer
Parameters:
[in] word 32bit word
Returns:
s32 MIOS32_OSC_SendDebugMessage ( mios32_osc_args_t *  osc_args,
u32  method_arg
Sends the argument list of a method to the debug terminal.
By default, the message is sent via MIDI to the MIOS Studio terminal.
Optionally another output function can be used (e.g. printf in emulation) by overruling MIOS32_OSC_DEBUG_MSG in mios32_config.h
Usage Example:
 static s32 OSC_SERVER_MyOSCMethod(mios32_osc_args_t *osc_args, u32 method_arg)
   MIOS32_OSC_SendDebugMessage(osc_args, method_arg);
   return 0; // no error
Parameters:
[in] osc_args pointer to OSC argument list as forwarded by MIOS32_OSC_ParsePacket()
[in] method_args 32bit value as forwarded by MIOS32_OSC_ParsePacket()
Returns:
< 0 on errors
