Bankstick Routines
This routines will load/save patterns from a bankstick module
We're using the writepage MIOS function because a write to the bankstick takes a long time this way we can write 64bytes at once so only 4 eeprom accesses are necessary
First versions of the firmware had a pattern size of 128bytes so a pattern could be saved with two calls to the writepage function
Saving a pattern with 256bytes takes four page writes, this makes it impossible
to save the four pages after each other without affecting the sequencer timing.
To avoid this the pattern is written over four ticks. Each time the program cycles through
the main loop a block is written until the whole pattern is saved.
Reading from a eeprom is a lot quicker so we can just call readpage for each block…
Code from bankstick.c:
//	This function initialises a pattern save
void BS_SavePat (unsigned char pat_nr){
	//only init block save if no other save is in progress
	if (save_block_cnt < NR_BLOCK)
		return;
	//each pattern contains 256 bytes
	//so address = pat_nr*256
	writeaddr = ((unsigned int)pat_nr) << 8;
	save_block_cnt = 0;
//	This function saves a pattern block to a bankstick
void BS_SaveBlock (){
	unsigned char error = 0;
	//check if something has to be saved
	if (save_block_cnt < NR_BLOCK) {
		//write block
		error |= MIOS_BANKSTICK_WritePage(writeaddr, buffer + (save_block_cnt<<6));
		//calculate address of next block
		writeaddr += 0x40;
		save_block_cnt++;
		if (error) {
			MIOS_LCD_CursorSet(0xC0 + 0);
			MIOS_LCD_PrintCString("error saving pattern");
			MIOS_LCD_MessageStart(128);
			//stop saving pattern
			save_block_cnt = NR_BLOCK;
//	This function loads a pattern from a bankstick
void BS_LoadPat (unsigned char pat_nr){
	unsigned int readaddr;
	unsigned char i;
	readaddr = ((unsigned int)pat_nr) << 8;
	//load all values to bankstick
	//(will be optimised in the future)
	MIOS_BANKSTICK_ReadPage(readaddr + 0x00, buffer + 0x00);
	MIOS_BANKSTICK_ReadPage(readaddr + 0x40, buffer + 0x40);
	MIOS_BANKSTICK_ReadPage(readaddr + 0x80, buffer + 0x80);
	MIOS_BANKSTICK_ReadPage(readaddr + 0xC0, buffer + 0xC0);
	if (MIOS_BOX_STAT.BS_AVAILABLE) {
		MIOS_LCD_PrintCString("load ok");
	} else {
		MIOS_LCD_PrintCString("load error");
back to DSEQ32
