dseq_bs
bankstick code from bankstick.c
this code is outdated, will post the new version soon
// These functions load/save a pattern from bankstick
// using 2 page reads/writes
void BS_SavePat (unsigned char pat_nr){
unsigned char error = 0;
unsigned int writeaddr;
//each pattern contains 128 bytes
//so address = pat_nr*128
writeaddr = ((unsigned int)pat_nr) << 7;
//write all values to bankstick
error = MIOS_BANKSTICK_WritePage(writeaddr, buffer);
error |= MIOS_BANKSTICK_WritePage(writeaddr + 64, buffer+64);
//need to do some error handling
void BS_LoadPat (unsigned char pat_nr){
unsigned int readaddr;
readaddr = ((unsigned int)pat_nr) << 7;
MIOS_BANKSTICK_ReadPage(readaddr, buffer);
MIOS_BANKSTICK_ReadPage(readaddr+64, buffer+64);
back to DSEQ32
dseq_bs.1161802098.txt.gz · Last modified: 2006/11/06 21:11 (external edit)
