Hello everyone,
I hope you guys can help and i have posted this in the right place!!
I dont have a MIDIbox, but i do have a Commodore 128 computer with a 6581 SID chip, stamped 2385 (manufactured wk 23, 1985).
Anyway, the sound output is very faint and i have to turn the volume control up on the computer monitor to hear the sound. The sound works fine but is very faint. I have replaced the inline electrolytic capacitor in the circuit, and the 1kohm load resistor seems fine, and i have also replaced the 2SC1815 transistor in the circuit. All other capacitors and resistors like for the low pass filter seems ok (removed most of the components from the board and tested them).
The SID is getting +12V and +5VDC, and the earth continuity seems fine.
But after all this, i still only get faint sound.......
From reading output on a multimeter (no oscilloscope available). I programmed the SID in 128 mode (basic) to cycle the volume from 1 to 15 playing all notes in a sequence ABCDEFG repeat.
When the SID is commanded to change the volume setting in one step, there is no difference in the output volume, but the step causes the output to 'crunch' loudly. Then when it goes from volume 15 down to 1, it makes a really loud statically 'crunch' (if you know what i mean).
At volume 0, the output on pin 27 is 3.7V DC. As the SID volume is commanded to go louder, the output DC voltage goes down from 4.7V DC to about 3VDC (15 down to 1) in uniform steps. There is no apparent AC output on the multimeter. So i dont know if its the inputs/output circuit or the chip itself....
Does this sound normal? Has anyone had any similar issues and ideas what could be wrong or what to look/test for? Do you think the SID chip is dud??
Hope you can help.
Cheers,
Simon
