I have a strange issue with a sammichFM I recently acquired (I didn't build it). After a clean firmware installation, everything works as expected (as far as I can tell). As soon as I change a patch however, incoming MIDI notes start getting skipped by the synthesizer. The LED on the front panel lights up, but no audio output is produced. This continues to get worse and worse until only 1 out of every 10 or so notes is played, and then it finally stops producing audio altogether. Reading/writing patches still works, all of the menu navigation works, and LEDs light up on incoming MIDI, but no output. Powering on/off doesn't help. Resetting the firmware appears to help, though this may be coincidental.
I'll add 1 more bit of info. Last night I reached the same zero-output state with only 1 audio cable plugged in (OUT1/2). Plugging in another cable (OUT3/4) appeared to fix the issue temporarily, but it eventually went back to producing no audio. Strange!
I have a feeling it may have to do with cables I'm using. For each OUT socket, I'm using an insert cable (Y-cable, stereo 1/4" TRS to 2 mono 1/4" TS). Is that the proper cabling?
Thanks for any help.
EDIT: It appears reading/writing of patches is not working fully. Some recalled values are garbled.
