mqzx
    6
Everything posted by mqzx
  1. I don't find it, all the info is on that page : http://q3f.org/develop/eight_kit/ /Edit Ok so after some research i found the ideal layout: So i want to have : - 16 encoders with dual led and a push switch that acts as a button/led matrix as well as classic encoders. - 8 Sliders. - A Bank select encoder - 2 7led Digits So it should make 2DIN and 2Dout + Core. Is this doable ?What do you think ?
  2. I see, but i'think i'll be going for a simple surface for first build, i could still implement a screen if i want to ? I found a pcb that could be interesting for encoders : Would that be compatible with a DIN/DOUT ? I see there is a LEDOUT port and a ENCIN but the one on the left i don't see what it's for. Or would that be too complicated ?
  3. Thanks ! I'll go for the Core + DIN/DOUT for the moment. What is an SCS exactly ?
  4. Ok, you're right about the encs, much more easier for bank changing. About the faders, i read that it's possible to plug 8 pots directly onto the core, wouldn't that be possible with faders ? So to sum it up: Core, AINSER64, Din/Dout, and 1Din for encs + Led digit to indicate on which bank i am. I was planning a 16 led/button matrix for starters, is the left space on the DIN usable to plug the bank selector encoder ? And if I go for a 32 matrix, how do i plug the bank encoder ? I haven't considered an LCD because i need to control a DAW, since all the features will be displayed on screen, is i worth it?… (also, money's short…) Also, should i use tact switches or rubber button ? I don't really get how to make the connections between the buttons and the DIN. Thanks !
  5. Ok thanks ! So if i understand correctly, (and before making the big orders…), I would need: - A Core - An Ainser64 for the Pots/fader - A DIO Matrix for my Leds/Buttons - A Led Digit But if i want an encoder to select the different banks, where will i be plugged in ? Do i have to add a DIN module ? Also, I dont't see how to put physically the button/leds matrix, does it have to have to be mounted on a pcb ? That part is a bit blurry… Cheers!
  6. Hi all ! First post here, It's been a while since i started to document myself about the midibox projects and i'm finally ready to dip into that ocean. I would like a basic 8 to 16 pots, 8 faders and a eventually small button/rgb leds matrix. But i was wondering, is it possible to have multiple banks of controls, changing them on the fly, "Ã la" Livid Instruments Alias 8 :http://www.lividinstruments.com/hardware_alias8.php Would that be possible with the current firmware ? This would definitey be interesting. Cheers !
