morphe777
    2
morphe777's Achievements
MIDIbox Newbie
  1. I find the solution by myself. I disconnect the MIDI OUT (of the midi Box) and re-upload the MIOS 1.09. As it can not get response, it asks for a reboot. Just before rebooting the midibox, I reconnect the midi out, then I reboot it. The MIOS 1,09 is then uploaded, and my bad code is erased. I have just delete the wrong part of the code, and re-upload my app. and now it works like a charm. In conclusion, do not use this code (get on ucapps.de) if you need to update your code later...
  2. Hello, I am building a MIOS8 board that works for 4-5 weeks. I updated code in order to code a the Midi Thru function, and I added the following code : ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI byte has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedByte(unsigned char byte) __wparam { static char fx_status; // normal MIDI events are forwarded in MPROC_NotifyReceivedEvnt // this function handles sysex and realtime messages if( byte & 0x80 ) { // Status message if( byte >= 0xf0 ) MIOS_MIDI_TxBufferPut(byte); // transfer byte // determine status if( byte == 0xf0 ) { fx_status = 0xff; // forward until 0xf7 } else if( byte == 0xf7 ) { fx_status = 0; // f7 reached, no forward } else if( byte == 0xf1 || byte == 0xf3 ) { fx_status = 1; // expecting one additional byte } else if( byte == 0xf2 ) { fx_status = 2; // expecting two additional bytes } else { fx_status = 0; // expecting no additional byte } } else { // check if fx status active if( fx_status ) { // forward data byte MIOS_MIDI_TxBufferPut(byte); // decrement counter if required if( fx_status != 0xff ) --fx_status; } } } Unfortunately, since I update this code, I can not contact my midibox thanks to MIOS studio. Here is the error message of the MIOS Studio: Detected MIOS8 and MIOS32 response - selection not supported yet! Check MIDI IN/OUT connections and Device ID! My MidiBox still works, and the MIOS Studio still receives the Debug-Message. Is there a way to reset the chip or send a blank code? I do not have the burner. Thank you for your help.
