Having a issue getting my SD Card to function normally.
I am Running MIDIbox NG V1.029 with latest available bootloader for LPC17 Core.
Before formatting the SDCard using 'sdcard_format' because MIOS Studio said the flash had the wrong formatting, using 'msd on' allowed me to access / copy data from the SD Card as if it was in a normal card reader without any corruption, but formatting the card with 'sdcard_format', and then trying to load the empty SDCard again, it attempts to generate the default files to the SD Card and shows appended sdcard output below.
I am Using a '4GB Patriot LX Class 10' SDCard on breakout adapter and have checked to make sure the correct signal pins are connected to the correct pins on J16 on a LPC17 Core kit from SmashTV, am I doing something wrong? Any pointer in the right direction would be awesome!
------------------------------------------ SDCard OUTPUT---------------------------
[6476.165] sdcard
[6476.422] SD Card Informations
[6476.422] ====================
[6476.422] --------------------
[6476.422] CID:
[6476.423] - ManufacturerID:
[6476.423] - OEM AppliID:
[6476.423] - ProdName: SD04G
[6476.423] - ProdRev: 48
[6476.423] - ProdSN: 0xb0012265
[6476.424] - Reserved1: 217
[6476.424] - ManufactDate: 183
[6476.424] - msd_CRC: 0x10
[6476.424] - Reserved2: 1
[6476.425] --------------------
[6476.425] - CSDStruct: 1
[6476.425] - SysSpecVersion: 0
[6476.425] - Reserved1: 0
[6476.426] - TAAC: 14
[6476.426] - NSAC: 0
[6476.426] - MaxBusClkFrec: 50
[6476.426] - CardComdClasses: 1461
[6476.426] - RdBlockLen: 9
[6476.427] - PartBlockRead: 0
[6476.427] - WrBlockMisalign: 0
[6476.427] - RdBlockMisalign: 0
[6476.427] - DSRImpl: 0
[6476.427] - Reserved2: 0
[6476.428] - DeviceSize: 7591
[6476.428] - MaxRdCurrentVDDMin: 0
[6476.429] - MaxRdCurrentVDDMax: 0
[6476.429] - MaxWrCurrentVDDMin: 0
[6476.429] - MaxWrCurrentVDDMax: 0
[6476.429] - DeviceSizeMul: 240
[6476.430] - EraseGrSize: 31
[6476.430] - EraseGrMul: 28
[6476.430] - WrProtectGrSize: 0
[6476.430] - WrProtectGrEnable: 0
[6476.430] - ManDeflECC: 0
[6476.431] - WrSpeedFact: 2
[6476.431] - MaxWrBlockLen: 9
[6476.431] - WriteBlockPaPartial: 0
[6476.431] - Reserved3: 0
[6476.432] - ContentProtectAppli: 0
[6476.432] - FileFormatGrouop: 0
[6476.432] - CopyFlag: 0
[6476.432] - PermWrProtect: 0
[6476.432] - TempWrProtect: 0
[6476.432] - FileFormat: 0
[6476.432] - ECC: 0
[6476.432] - msd_CRC: 0x16
[6476.432] - Reserved4: 1
[6476.433] --------------------
[6476.433]
[6476.433] Reading Root Directory
[6476.433] ======================
[6476.434] Retrieving SD Card informations - please wait!
[6476.434] SD Card: '': 3711 of 3711 MB free
[6476.436] [r...ld.] 10/01/84 06:23:42 PM <DIR> 753571756 <UbWyF%.1U
[6476.436] [r.s.l..] 00/13/32 09:29:00 AM 968686932 d1oel|6C..=
[6476.437] [rh..ld.] 12/26/58 09:09:54 AM <DIR> 3974720686 "kE&:q .Hu
[6476.437] [.hs.ld.] 03/01/16 07:48:62 AM <DIR> 4157422789 0$o|.FBO
[6476.438] [.hs.ld.] 02/03/67 09:33:12 AM <DIR> 4162411084 "Znp)Tq.!7
[6476.438] [rh..l..] 14/23/-9 05:18:58 AM 4125130921 !Ra1$y.L5
[6476.439] [.....d.] 05/15/63 03:12:32 PM <DIR> 2080912518 g gV1.:1I
[6476.439] [rh..ld.] 01/19/-9 09:01:28 PM <DIR> 575652786 3&T"O.B
[6476.440] [r...ld.] 00/27/-1 09:09:34 PM <DIR> 3982175994 &Y>QH)].#{z
[6476.441] [rh..ld.] 00/19/34 19:41:62 PM <DIR> 4123247430 C/NI2}~ .m"?
[6476.442] [r...ld.] 11/06/32 00:50:30 AM <DIR> 1228869781 #wx).yI
[6476.442] [r...l..] 12/11/91 10:11:50 PM 564131727
:4Qy+.o
[6476.443] [r...l.a] 03/16/30 16:04:04 PM 2190815959 3x,.zTf
[6476.443] [..s.l.a] 14/14/83 08:42:48 AM 4272602553 T3Jw.\}-
[6476.444] [r.s.l.a] 08/12/63 03:13:18 PM 48728003 {\WFar.KL
[6476.444] [rh..l..] 03/20/50 08:23:00 AM 3051983800 cWUjjy.Q)N
[6476.445] [rhs.l.a] 01/22/88 19:51:50 PM 2174540474 f{0[2qB\.w3
[6476.447] [..s.ld.] 01/01/33 12:38:52 PM <DIR> 2115173558 AzD5{.Uk
[6476.447] [..s.ld.] 06/07/89 16:59:42 PM <DIR> 1160627611
[6476.448] [r...ld.] 11/20/103 04:29:46 AM <DIR> 2289208753 .|ggd[:.X"
[6476.448] [.hs.ld.] 13/07/60 05:59:46 PM <DIR> 3678931109 s4^ N.aBj
[6476.449] [.hs.lda] 08/00/-2 04:13:60 PM <DIR> 4162280993 &A\oc."O
[6476.449] [..s.ld.] 05/18/-12 14:22:42 PM <DIR> 576674026 '#mwe\~.;*X
[6476.450] [.....da] 07/01/-17 13:10:28 PM <DIR> 3010040007 >>[!30M.N
[6476.450] [rh..l.a] 01/21/36 15:34:44 PM 1408117281 Bn_AHaM
.qg"
[6476.451] [r.s.l..] 03/06/46 03:49:08 AM 963223027 (u<{&.bf
[6476.451] [......a] 00/00/-20 00:00:00 AM 42512 DEFAULT.NGC
[6476.452] [rhs.ld.] 11/31/32 19:32:48 PM <DIR> 3914364582 MPo9iQj.sD
[6476.452] [......a] 04/13/26 17:33:02 PM 1846586365 BKVM+i~m.ND)
[6476.455] [..s.l.a] 15/06/69 12:48:06 PM 3779769467 .?F5 .z9
[6476.455] [r.s.l.a] 11/23/83 13:21:42 PM 1221094851 ?](2R.K%)
[6476.456] [......a] 00/00/-20 00:00:00 AM 518 DEFAULT.NGL
[6476.456] [.h..l..] 00/30/-15 19:22:02 PM 3597903676 Z\RwC.%p
[6476.457] [r...ld.] 01/15/87 14:08:04 PM <DIR> 211754017 3phpuz4P.n-H
[6476.457] [.h..ld.] 04/04/06 02:17:24 PM <DIR> 1658248676 $){S5w.q%_
[6476.458] [rh..lda] 00/00/-20 00:00:00 AM <DIR> 0 Q~ryQd7.zd
[6476.458] [......a] 00/00/-20 00:00:00 AM 222 DEFAULT.BIN
[6476.459] [......a] 00/00/-20 00:00:00 AM 520 DEFAULT.NGS
[6476.459] done.
