1,279 -
71
Everything posted by Phatline
after initialize: void APP_Init(void){ int pin; for(pin=0; pin<16; ++pin){ MIOS32_BOARD_J10_PinInit(pin, MIOS32_BOARD_PIN_MODE_INPUT_PU);} } getting pin 0-7 is workin ok, but 8-15 give me no output: void APP_SRIO_ServicePrepare(void) { // get GPIO-Pins u8 x = 0; for(x=0; x<16; x++) { if(MIOS32_BOARD_J10_PinGet(x) != flag.j10PinState[x]) { MIOS32_MIDI_SendDebugMessage("pin: %d value: %d", x, MIOS32_BOARD_J10_PinGet(x)); flag.j10PinState[x] = MIOS32_BOARD_J10_PinGet(x); } } why?
always in need for core and Midi IO ;) - CORE STM32F4 with STM32F4DISCOVERY - MIDI IO price? where you from?... mike (austria)
Hi, i want to modify the blm_scalar app a bit http://svnmios.midiboxorg/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fblm_scalar%2FREADME.txt i want to use it in standalone and via midi/sysex... so my question: how to call the BLM internally? when i want to display a "array[16][16]=0 or 1 or 2;" i know i can call it like below but is there a more direct way to use it? thx. mike void APP_Background(void){ u8 chn = 0; u8 note = 0; u8 velocity = 0; for(chn=0; chn<16; chn++){ for(note=0; note<16; note++){ velocity = Seq[chn][note]; if( note <= 0x0f ) { //note<=15? // BLM16x16 LEDs led_mod_ix = chn >> 2; led_row_ix = ((chn&3) << 1) + ((note >> 3) & 1); led_column_ix = note & 0x7; //7 modify_led = 1; } else if( note == 0x40 ) { //note==64 // extra column LEDs led_mod_ix = 4; led_row_ix = (chn&3) << 1; led_column_ix = chn >> 2; modify_led = 1; } else if( chn == 0 && note >= 0x60 && note <= 0x6f ) { //Chn0, note>=96, note>0111 // extra row LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = note & 3; modify_led = 1; } else if( chn == 0xf && note >= 0x60 && note <= 0x6f ) { //Chn15, note>=96, note>0111 // additional extra LEDs led_mod_ix = 4; led_row_ix = 1 + ((note >> 1) & 6); led_column_ix = 4 + (note & 3); modify_led = 1; } if( modify_led ) { u8 led_mask = 1 << led_column_ix; // 90 xx 00 is the same like a note off event! // (-> http://www.borg.com/~jglatt/tech/midispec.htm) if( velocity == 0x00 ) { // Note Off or velocity == 0x00: clear both LEDs blm_scalar_led[led_mod_ix][led_row_ix][0] &= ~led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] &= ~led_mask; #endif } else if( velocity < 0x40 ) { // Velocity < 0x40: set green LED, clear red LED blm_scalar_led[led_mod_ix][led_row_ix][0] |= led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] &= ~led_mask; #endif } else if( velocity < 0x60 ) { // Velocity < 0x60: clear green LED, set red LED blm_scalar_led[led_mod_ix][led_row_ix][0] &= ~led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] |= led_mask; #endif } else { // Velocity >= 0x60: set both LEDs blm_scalar_led[led_mod_ix][led_row_ix][0] |= led_mask; #if BLM_SCALAR_NUM_COLOURS >= 2 blm_scalar_led[led_mod_ix][led_row_ix][1] |= led_mask; #endif } } } }} // END - FOR - LOOPS
store 16bit variable to 8bit FILE_Writebuffer
Phatline replied to Phatline's topic in MIOS programming (C)
hm i get a error: app.c:1094:13: warning: implicit declaration of function 'wmemset' [-Wimplicit-function-declaration] if(edit & (1<<0))wmemset(loop[track].PB, (u32)((8192<<16) + 8192), (sizeof (loop[track].PB))/4); // reset Pitch Bend when i then add: #include <wchar.h> to app.c then error: should i change this: typedef struct storage { u16 PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader:1; char virgin:1; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; to this: typedef struct storage { wchar_t PB PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader:1; char virgin:1; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; hm what size has this wchar_t? -
if(edit & 0x0f)memcpy(&loop_copy, &loop[track], sizeof loop_copy); clever i like that but i planned it more like: check which things have to copyied, so i can copy PB+NOTES, but not CC+Loop-Information, (for default) if i get it right: in your thought i can always copy only one thing: PB, All, Notes or Loop-Info but i can still use memcpy with for example: if( (edit[0]==1) && (edit[1]==1) && (edit[1]==1) && (edit[1]==1) ) memcpy(&loop_copy, &loop[track], sizeof loop_copy); THX for your help guys! for the rest i will take me time on 23.12... today we make fire in the snow, and celebrate the 21.12 to restart the sun-circle happy new sun year, skol! -
aja a < 8 of course, thx! Edit: read/write on SD-Card is working fine! MUTEX_SDCARD_TAKE; //Write to File sprintf(file_path, "msp/%d-%d.msp", track, clip); FILE_WriteOpen ( file_path, 16 ); FILE_WriteBuffer( (u8 *)&file_type, 4 ); FILE_WriteBuffer( (u8 *)&loop[track], sizeof(store_t) ); FILE_WriteClose (); MUTEX_SDCARD_GIVE; @ Background-tasks function example which make a hardfault when using 1024, when calling it... i call it once a time with a button press on the UI (DIN) > see code below but also will need such things for mooving sequencer data forward in loop, or backwards, or copy step 0-15 to all other 512 steps in a musically way > means could be a wild button orgie... in App.h: typedef struct storage { // to optimize SD-Load-Time, each clips data is stored in this struct u16 PB [512]; // Pitchband inital = 8192 = No Pitchbend! u8 SEQ[512] [8]; // 512Steps, 8NotePolyphony u8 MSQ[512]; // Motion-SEQ of one CC ...eg.:Control-Wheel of Keyboard char leader; // Programchange able? - only 1 of 4 Song-Clips can send Programchanges via BLMatrix char virgin; // is there any data in the clip? need to display on a ButtonLed Matrix-Launcher u8 length; // 1x16, 2x16... u8 decay; // 60ms... could be set with Encoder, but I dont need a variable, since the melody out will be used by the Triggermatrix... u8 rythm; // 4x4=16, 5x3=15 usw... to calculate maximal duration per UI-matrix page u16 bpm; } store_t; extern store_t loop[8]; in app.c: u16 SEQ_copy[512][8] = {{}}; //Copy actual Track into ClipboardBuffer u16 MSQ_copy[512] = {}; //Copy actual Track into ClipboardBuffer u16 PB_copy [512] = {}; //Copy actual Track into ClipboardBuffer u16 tact_info_copy[32] = {}; //Copy bpm, loop length, tact and so on // E D I T C L I P D A T A static void Edit_Clip(u8 track, u16 clip, u16 job){ u16 c = 0; u16 x = 0; switch(job) { // Clear case 0: for( c=0; c<512; c++ ) { if(edit[0] == 1) { loop[track].PB[c] = 8192; } // = no Pitch Bend if(edit[1] == 1) {for( x=0; x<8; x++ ) { loop[track].SEQ[c][x] = 0; } } // = no Note if(edit[2] == 1) {loop[track].MSQ[c] = 0; } // = no Control Change } break; // Copy case 1: for( c=0; c<512; c++ ) { if(edit[0] == 1) { PB_copy[c] = loop[track].PB[c];} // PB if(edit[1] == 1) { for( x=0; x<8; x++ ) { SEQ_copy[c][x] = loop[track].SEQ[c][x]; } } // NOTE if(edit[2] == 1) { MSQ_copy[c] = loop[track].MSQ[c];} // MSQ } if(edit[3] == 1) { tact_info_copy[0] = loop[track].leader; tact_info_copy[1] = loop[track].virgin; tact_info_copy[2] = loop[track].length; tact_info_copy[3] = loop[track].decay; tact_info_copy[4] = loop[track].rythm; tact_info_copy[5] = loop[track].bpm; } break; // Paste case 2: for( c=0; c<512; c++ ) { if(edit[0] == 1) { loop[track].PB[c] = PB_copy[c];} // PB if(edit[1] == 1) { for( x=0; x<8; x++ ) { loop[track].SEQ[c][x] = SEQ_copy[c][x]; } } // NOTE if(edit[2] == 1) { loop[track].MSQ[c] = MSQ_copy[c]; } // MSQ } if(edit[3] == 1) { loop[track].leader = tact_info_copy[0]; loop[track].virgin = tact_info_copy[1]; loop[track].length = tact_info_copy[2]; loop[track].decay = tact_info_copy[3]; loop[track].rythm = tact_info_copy[4]; loop[track].bpm = tact_info_copy[5]; } break; } } also the code above is working ifne ;) -
ok understand, i let the the file describtion in.... oje... there is something wrong with the code, http://wiki.midibox.org/lib/exe/fetch.php?media=phatline:seq-melody-footboard-beta.zip when i make arrays with 8x512, or arrays with 8x1024, the Files on SD-Card is always 5,6kb size, also on 1024 i got hardfaults when copy those structs into arrays (copy paste clear clips), by 512 no hardfault typedef struct storage { u16 PB [512]; u8 SEQ[512] [8]; u8 MSQ[512]; char leader; char virgin; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; no difference in SD-File-Size! typedef struct storage { u16 PB [1024]; u8 SEQ[1024] [8]; u8 MSQ[1024]; char leader; char virgin; u8 length; u8 decay; u8 rythm; u16 bpm; } store_t; also i initialize all Arrays, but actual most of them (all except the first member loop[0] in the program are 0-out void APP_Init(void){ //initalize 8 Clips with standart values u8 a = 0; for ( a=0; a>8; a++ ) { loop[a].leader = 0; loop[a].virgin = 1; loop[a].length = 1; loop[a].decay = 60; loop[a].rythm = 4; loop[a].bpm = 120; //initiate Pitchbend u16 b; for(b=0; b<512; b++) { loop[a].PB[b] = 8192; } }; //Initiate Pitchbend - copy paste buffer u16 b; for(b=0; b<512; b++) { PB_copy[b] = 8192; } } the 1024 thing i think is clear, it takes to long to calculate all the data, i would need something like a xtask... but i dont figured out how to make out of a i know: i use such things for counters in ms tact (decay-counters, blink blink...), but not for a function that gets called, work something out, and done... for example: static void Decay(void *pvParameters){ //Send Note OFFs after a while portTickType xLastExecutionTime; xLastExecutionTime = xTaskGetTickCount(); // Initialise the xLastExecutionTime variable on task entry while( 1 ) { vTaskDelayUntil(&xLastExecutionTime, 1 / portTICK_RATE_MS); for(DcyNteCount = 1; DcyNteCount < 128; DcyNteCount++) { for(DcyTrkCount = 0; DcyTrkCount < 8; DcyTrkCount++) { if (MeloDecayTIMER[DcyTrkCount][DcyNteCount] != 0) { MeloDecayTIMER[DcyTrkCount][DcyNteCount] --; if (MeloDecayTIMER[DcyTrkCount][DcyNteCount] == 0) { MIOS32_MIDI_SendNoteOff(MelPortOut, MeloOutCh[DcyTrkCount], DcyNteCount, 0); MIOS32_MIDI_SendNoteOn (MelPortOut, MeloOutCh[DcyTrkCount], DcyNteCount, 0);}} }} }//End While }//End TICK 0 >>> 1ms Task... -
would assume that all my tracks saved in a single file, and thats not the case, since i need to load the clips independendly for launching via BLM, but also need to load the clips via Program-change also so it ends up with: case 2: //LOAD all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { MUTEX_SDCARD_TAKE; sprintf ( filepathL, "sq/%d-%d.sq", t, clip ); FILE_ReadOpen ( &midifile_fi, filepathL ); FILE_ReadBuffer ( (u8 *)file_type, 4 ); FILE_ReadBuffer ( (u8 *)loop[t], sizeof(store_t) ); FILE_ReadClose ( &midifile_fi ); MUTEX_SDCARD_GIVE; //Calculate new Loop Lengths Loop[t] = loop[t].length * MainLoop; } by the way, do i need that FILE_WriteBuffer( (u8 *)file_type, 4 ); //"SQ01" = 4 Positons for what platforms do i need a filetype? compiler says for the line: FILE_WriteBuffer((u8 *)loop[track], sizeof(store_t)); : -
i am stucking @ the moment, while i know how to use it instead of my normal arrays, i dont know how to write the whole struct into file... ok here my struct: store_t loop[8] , how can i read/write them now into my FILE? a struct is not named in MIOS32 functions doku app.h (so all functions have access on it typedef struct storage { // to optimize SD-Load-Time, each clips data is stored in this struct u16 PB [512]; // Pitchband inital = 8192 = No Pitchbend! u8 SEQ[512] [8]; // 512Steps, 8NotePolyphony //loop[c].SEQ bevore u8 MSQ[512]; // Motion-loop[c].SEQ of one CC (Control-Wheel of Keyboard //loop[c].MSQ bevore u8 CC [32]; // Save all other Variables into this Array - for SD-Card... //loop[c].CC bevore char leader; // Programchange able? - only 1 of 4 Song-Clips can send Programchanges via BLMatrix char virgin; // is there any data in the clip? need to display on a ButtonLed Matrix-Launcher //loop[c].virgin bevore u8 length; // 1x16, 2x16... //loop[c].length bevore u8 decay; // 60ms... could be set with Encoder, but I dont need a variable, since the melody out will be used by the Triggermatrix... //loop[c].decay bevore u8 rythm; // 4x4=16, 5x3=15 usw... to calculate maximal duration per UI-matrix page //loop[c].rythm bevore u16 bpm; } store_t; app.c , initalize data //Card-Clip-Container store_t loop[8]; void APP_Init(void){ //initalize 8 Clips with standart values u8 a = 0; for ( a=0; a>8; a++ ) { sprintf( loop[a].file_type, "SIGL" ); loop[a].leader = 0; loop[a].virgin = 1; loop[a].length = 1; loop[a].decay = 60; loop[a].rythm = 4; loop[a].bpm = 120; //initiate Pitchbend u16 b; for(b=0; b<512; b++) { loop[a].PB[b] = 8192; } // 8192: inital No Pitchbend! }; app.c , store data //S T O R E Single Clip MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); //write struct FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access break; //L O A D single Clip MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_type, 4); //write struct FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Calculate new Loop Lengths Loop[track] = loop[track].length * MainLoop; break; -
thx good to know! i will try them structs code is for MelodienSpeicher, where arrays[8][512] polophonic played in 16th (Pitchbend, NoteOn/Off), and also hope that dont hurts when using structs u16 PB[8][512] = {{}}; // 8192: inital No Pitchbend! u8 Sequence[8][512][8]={{{}}}; //8Tracks, 512Steps, 8NotePolyphony u8 CC_MSQ[8][512] = {};//Motion-Sequence of one CC (Control-Wheel of Keyboard s16 TrackClipboard[512][8] = {{}}; //Copy actual Track into ClipboardBuffer u8 StepClipBoard[8][8] = {}; //Just a memory container to copy paste Sequencer Steps -
to be prepared, today read a lot about structs, and memory-save/performance/code-readable much to optimize .... it seems that there are things to keep on eye, to avoid heavy bus-load ...like order variable by byte size, and others which i cant summize a "i understand"... importend for me is that the the program goes fast thru, i dont have memory problems, i think, since it is a sequencer timing is No1 by using struct it will slow down program-process? a normal variable-array is slower? > time not so importend - in case of loading from SD-Card to RAM, but for RAM-Access-time in the Program, hope that question make sense? then there where people who said, that when i dont use 32bit types, the program have to calc my 1bit 8bit or 16bit into 32bit -memory-slots- and access time will go not so good, other saying that this is only for x86, arm a nother story... dont know: should i use "int" as standard (except for the big sequencer Arrys > memory to low i expirienced today more a 8 or 16bit...) or should i use u8 or u16 instead? i mean when i dont use structs for all those "not clip related"-variables, just single u8 variables make it any differnce at all? -mike -
thx has worked: FILE_ReadBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] call: SD(track, clip, job); for example: SD(6,1,2); //track 6 dont matter, ProgramChange 1, Load all Clips SD(0,7,1);//track 0, ProgramChange 7, Load single Clip (clip 7-0.sq) SD(0,1,3);//track 0 , ProgramChange 1, Store single Clip (clip 1-0.sq) SD(2,1,4);//track 2 dont matter, ProgramChange 1, Store all Clips SD(2,1,5);//track 2 dont matter, ProgramChange 1 dont matter, Copy track 0-0.sq 512x8 times on SD-Card = Make filestructure = initalize SD-Card > take 20 Minutes full code: http://wiki.midibox.org/lib/exe/fetch.php?media=phatline:seq-melody-footboard.zip relativly stripped down the SD-Management is done by: u8 clip_is_virgin = 1; u16 BPM = 120; u8 Rythm = 4; u8 SetDecayTime[8] = {60,60,60,60, 60,60,60,60}; us u8 Loop_Length[8] = {1,4,1,4, 1,4,1,4}; u8 CC_SD[8][32] = {}; //Save all other Variables into this Array - for SD-Card... u8 CC_MSQ[8][512] = {}; u8 Sequence[8][512][8]={{{}}}; xSemaphoreHandle xSDCardSemaphore; // take and give access to SD-Card xSemaphoreHandle xLCDSemaphore; // take and give access to LCD static file_t midifile_fi; //used to read files from SD-Card #define MUTEX_LCD_TAKE { while( xSemaphoreTakeRecursive(xLCDSemaphore, (portTickType)0) != pdTRUE ); } //a Mutex reserve LCD/SD for a task, until it is given away... #define MUTEX_LCD_GIVE { xSemaphoreGiveRecursive(xLCDSemaphore); } #define PRIORITY_SD ( tskIDLE_PRIORITY + 3 ) //3:Mios standart static void SD(u8 track, u16 clip, u16 job); void APP_Init(void){ xLCDSemaphore = xSemaphoreCreateRecursiveMutex(); // create Mutex for LCD access xSDCardSemaphore = xSemaphoreCreateRecursiveMutex(); //create Mutex for SD-Card access FILE_Init(0);// initialize file functions } void APP_Tick(void){ //@1mS rate SDCardCount++; //CHECK SD-Car every 2sec. if(SDCardCount > 2000) { SDCardCount = 0; SD(0, 0, 5); } //2s Counter > send Check-SDCard-Commant to StoreLoad-Function (u8 track, u16 clip, u16 job) } // S T O R A G E - SD - C A R D /// read write clips/programchanges static void SD(u8 track, u16 clip, u16 job){ //Job1=load all, Job2=store all, Job3=initalize card u8 t = 0; //track counter initation switch(job) { // R E A D /////////////////////////////////////////////////////////////////////////////////////////////////////// case 1: //LOAD single Clip MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD [track], sizeof(CC_SD [track])); FILE_ReadBuffer((u8 *)CC_MSQ [track], sizeof(CC_MSQ [track])); //Control-Change-Motion-Sequence FILE_ReadBuffer((u8 *)Sequence[track], sizeof(Sequence [track])); //u8 Sequence[8][512][8] FILE_ReadBuffer((u8 *)PB [track], sizeof(PB [track])); FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array Rythm = CC_SD[track][1]; Loop_Length[track] = CC_SD[track][2]; BPM = CC_SD[track][4]; SetDecayTime[track] = CC_SD[track][5]; //Calculate new Loop Lengths Loop[track] = Loop_Length[track] * MainLoop; //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. break; case 2: //LOAD all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { MUTEX_SDCARD_TAKE; sprintf(filepathL, "sq/%d-%d.sq", t, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD [t], sizeof( CC_SD [t])); FILE_ReadBuffer((u8 *)CC_MSQ [t], sizeof( CC_MSQ[t])); //Control-Change-Motion-Sequence FILE_ReadBuffer((u8 *)Sequence[t], sizeof(Sequence[t])); //u8 Sequence[8][512][8] FILE_ReadBuffer((u8 *)PB [t], sizeof( PB[t])); FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array Rythm = CC_SD[t][1]; Loop_Length[t] = CC_SD[t][2]; BPM = CC_SD[t][4]; SetDecayTime[t] = CC_SD[t][5]; //Calculate new Loop Lengths Loop[t] = Loop_Length[t] * MainLoop; } //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "PROGRAM LOAD - Finished"); MUTEX_LCD_GIVE; Update_LCD_s = 1; //normal LCD-Labeling in back again in a second break; // S T O R E ///////////////////////////////////////////////////////////////////////////////////////////////////// case 3: //S T O R E Single Clip //Fill CC-Array of Clip CC_SD[track][0] = clip_is_virgin; CC_SD[track][1] = Rythm; CC_SD[track][2] = Loop_Length[track]; CC_SD[track][4] = BPM; CC_SD[track][5] = SetDecayTime[track]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD [track], sizeof(CC_SD [track])); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ [track], sizeof(CC_MSQ [track])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB [track], sizeof(PB [track])); FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access Update_LCD_s = 1; //normal LCD-Labeling in back again in secunds SongNrLoad = SongNrStor; //transfair load nr 2 store nr. break; case 4: //S T O R E all Clips - FOR P R O G R A M C H A N G E for( t=0; t<8; t++) { // store file once by once //Fill CC-Array of Clip CC_SD[t][0] = clip_is_virgin; CC_SD[t][1] = Rythm; CC_SD[t][2] = Loop_Length[t]; CC_SD[t][4] = BPM; CC_SD[t][5] = SetDecayTime[t]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", t, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD [t], sizeof(CC_SD [t])); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ [t], sizeof(CC_MSQ [t])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[t], sizeof(Sequence[t])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB [t], sizeof(PB [t])); FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 access } SongNrLoad = SongNrStor; //transfair load nr 2 store nr. MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "PROGRAM STORE - Finished"); MUTEX_LCD_GIVE; Update_LCD_s = 1; //normal LCD-Labeling in back again in secunds break; // I N I T - S D - CARD //////////////////////////////////////////////////////////////////////////////////7////// case 5: //SD-Card Initalize MUTEX_SDCARD_TAKE; //SD-Card is now only for the following LINES reserved: statusSD = FILE_CheckSDCard(); switch(statusSD) { case 2: MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "NO SD-Card"); MUTEX_LCD_GIVE; break; case 3: if (!FILE_SDCardAvailable() ) {MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "Insert-FAT-Formated-SD-Card"); MUTEX_LCD_GIVE; break;} if (!FILE_VolumeAvailable() ) {MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "Format SD-Format to FAT first!"); MUTEX_LCD_GIVE; break;} break; case 1: // YES CARD! >>> next: check Card-content statusDir = FILE_DirExists("sq"); //ask file.c: exist a folder "t/" on the CARD? if(statusDir == 1){MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "good SD-file structure");MenueUpdateFlag = 0;MUTEX_LCD_GIVE; break;} if(statusDir == 0){MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "create 4096 Files on SDC it takes 20min - really!-wait!!! ");MUTEX_LCD_GIVE; //Fill CC-Array of Clip CC_SD[track][0] = clip_is_virgin; CC_SD[track][1] = Rythm; CC_SD[track][2] = Loop_Length[track]; CC_SD[track][4] = BPM; CC_SD[track][5] = SetDecayTime[track]; FILE_MakeDir("sq"); //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD[track], 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)CC_MSQ[track], sizeof(CC_MSQ[track])); //Control-Change-Motion-Sequence FILE_WriteBuffer((u8 *)Sequence[track], sizeof(Sequence[track])); //u8 Sequence[8][512][8] FILE_WriteBuffer((u8 *)PB[track], sizeof(PB[track])); FILE_WriteClose (); //copy-prototype file to 512x8 clip files on SD-Card for(t=0; t<8; t++){ s16 clipcount = 0; //declare and set the Bank Counter inital value to 0 for(clipcount=0; clipcount<512; clipcount++){ //countes 2 511 and do following commandos 511 times in a loop: char copyfilepath[16]; sprintf(copyfilepath, "sq/%d-%d.sq", t, clipcount); //make a new filename depending on the counter value 1.sq, 2.sq, 3.sq...511.sq FILE_Copy ((char *)"sq/0-0.sq", (char *)copyfilepath);} //copy the File 0.tm to all other 511 files... } //SD-Card is now free 4 apbess MUTEX_LCD_TAKE; MIOS32_LCD_DeviceSet(0); MIOS32_LCD_Clear(); MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString ("%s", "SD-CARD - INIT - FINISHED"); MUTEX_LCD_GIVE;MenueUpdateFlag = 0;} break; } MUTEX_SDCARD_GIVE; } } maybe that helps anyone, or me in the future... -
should it does it the same? incl(track) (step) cant wait to try it at home.many thx.4that. mike. -
how ever the endgoal is: 128 Program-Change/Songs a 4clips = 512clips 8tracks a 512 clips fileformat: [track]-[clip].sq >>> each clip is a single file which can be called when i Programchange, it loads the first row of clips >>> clip = PC*4 >>> to load a other clip i need to built a 8x8 blm first: the plan is: ----------------tr0 tr1 tr2 tr3 tr4 tr5 tr6 tr7 last PC x - Play-Clip from last Song empty grid x x x x x x x x - Indicate that there is no Song to choose clip.row0 x x x - Play Clips[tr0][cliprow0] of actual song.... clip.row1 x - clip.row2 x clip.row3 empty grid x x x x x x x x next PC x - Play Clips from next song.... so its a bit of ableton like... but more song structured. -
file is up to date in wiki: http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=phatline:seq-melody-footboard.zip when cleaned up this are the Functions involved > 1.APP_DIN_NotifyToggle >>> set a Flag to 1 (Hi) 2.TASK_Blink_Decay >>> wait 250ms, then send a Call to: SD(SaveNextFlag, SongNrStor, 2) = TRACK0, Song-PC0, store command 3.SD(u8 track, u16 clip, u16 job) >>> writing, reading, or initalizing files... // local prototype of the task function static void TASK_Blink_Decay(void *pvParameters); static void SD(u8 track, u16 clip, u16 job); void APP_DIN_NotifyToggle(u32 pin, u32 pin_value){ //1.STORE-LOAD-BUTTON-ACTION if(pin_value == 0) { switch(pin) { case 6: StoreFlag = 1; break; case 14: LoadFlag = 1; break; }}} static void SD(u8 track, u16 clip, u16 job){ //3.Job1=load all, Job2=store all, Job3=initalize card //STORE if(job == 2) { //Fill CC-Array of Clip CC_SD[0] = clip_is_virgin; CC_SD[1] = Rythm; CC_SD[2] = Loop_Length[track]; CC_SD[3] = BPM; CC_SD[4] = SetDecayTime[track]; MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8]={{{}}}; //8Tracks, 256Steps, 8NotePolyphony for(i=0; i<256; i++)FILE_WriteHWord (PB[track][i]); //write Pitchbend u16 values directly FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 apbess SongNrLoad = SongNrStor; //transfair load nr 2 store nr. SD_Done_StoreFlag = 1;} //LOAD if(job == 1) {//Load all Data- whole Program-Change-Patterns MUTEX_SDCARD_TAKE; //NOTE-Data of Clip sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD, 32); FILE_ReadBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8] for(i=0; i<256; i++)FILE_ReadHWord (&PB[track][i]); //read Pitchbend u16 values directly FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; //Paste Variables from Array clip_is_virgin = CC_SD[0]; Rythm = CC_SD[1]; Loop_Length[track] = CC_SD[2]; BPM = CC_SD[3]; SetDecayTime[track] = CC_SD[4]; //SEQ_BPM_Set(BPM); NeedSync = 1; //update ClockCounter when ready... SongNrStor = SongNrLoad; //transfair load nr 2 store nr. SD_Done_Load_Flag = 1;} //SD-Card Initalize - Files if((job == 3) && (clip < 8)){//CHECK SD-Card/Initalize Card .... .... }//End While }//End TICK 0 >>> 1ms Task... -
u16 PB[8][256] = {{}}; dont working, LCD hangs.... by just sending a ... SD(0,0,2 or 1) .... i decoppelt already the Load/Store button to directly act on the SD-Function (with counters in milliseconds) which solved issues but not the pitchbend thing... static void SD(u8 track, u16 clip, u16 job){ //STORE if(job == 2) { MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8]={{{}}}; / for(i=0; i<256; i++)FILE_WriteHWord (PB[track][i]); //write Pitchbend u16 values directly FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free SD_Done_StoreFlag = 1;} //LOAD if(job == 1) { MUTEX_SDCARD_TAKE; //READ FILE sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD, 32); FILE_ReadBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8] for(i=0; i<256; i++)FILE_ReadHWord (&PB[track][i]); //read Pitchbend u16 values directly FILE_ReadClose (&midifile_fi); MUTEX_SDCARD_GIVE; SD_Done_Load_Flag = 1;} -
this line stops my lcd from reacting and nothing will be written: for(i=0; i<256; i++){ //16bit pitchbend to 2x8bit -saveable with Writebuffer PB8[0][i] = PB[track][i] & 0xff; PB8[1][i] = PB[track][i] >> 8;} when used in: for (track=0; track<8; track++){ //count thru all tracks for(i=0; i<256; i++){ //16bit pitchbend to 2x8bit -saveable with Writebuffer PB8[0][i] = PB[track][i] & 0xff; PB8[1][i] = PB[track][i] >> 8;} MUTEX_SDCARD_TAKE; //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, SongNrStor*4); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //u8 Sequence[8][256][8] FILE_WriteBuffer((u8 *)PB8, 512); //2x256 FILE_WriteClose (); MUTEX_SDCARD_GIVE; //SD-Card is now free 4 apbess } , if i delete this lines: all files are written/loadet fine, maybe the bitshift takes to long... or sd access is to slow... or code is just waste... -
hm having troubles by Reading the HWORD - compiler error: make (im Verzeichnis: /home/...) rm -f project.hex Creating object file for app.c app.c: In function 'SD': app.c:857:40: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ------------------------------------------------------------------------------- Application successfully built for:.... app.c:857:40 isthis line: for(i=0; i<256; i++){FILE_ReadHWord ((u16 *)PB[track][i]);} //read Pitchbend u16 values directly ?? u16* and u16 by using this code //STORE if((job == 2) && (track == 8)) {//Store all Data- whole Program-Change-Patterns MUTEX_SDCARD_TAKE; for (track=0; track<8; track++){ //count thru all tracks //Write to File sprintf(filepathS, "sq/%d-%d.sq", track, clip); FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)Sequence[track], 2048); //8Tracks, 256Steps, 8NotePolyphony for(i=0; i<256; i++){FILE_WriteHWord(PB[track][i]);} //write Pitchbend u16 values directly //FILE_WriteBuffer((u8 *)PB8, 1024); //2x8Bit Pitchbendvalue...2 x 512 Steps= 1024 Blocks FILE_WriteClose (); } MUTEX_SDCARD_GIVE; } //LOAD if((job == 1) && (track == 8)) {//Load all Data- whole Program-Change-Patterns MUTEX_SDCARD_TAKE; for (track=0; track<8; track++){ //NOTE-Data of Clip sprintf(filepathL, "sq/%d-%d.sq", track, clip); FILE_ReadOpen (&midifile_fi, filepathL); FILE_ReadBuffer((u8 *)file_typeBank, 4); FILE_ReadBuffer((u8 *)CC_SD, 32); // ALL OTHER VARIABLES are saved in this ARRAY (CC_SD[128]) FILE_ReadBuffer((u8 *)Sequence[track], 2048); ////8Tracks, 256Steps, 8NotePolyphony u16 i = 0; for(i=0; i<256; i++){FILE_ReadHWord ((u16 *)PB[track][i]);} //write Pitchbend u16 values directly FILE_ReadClose (&midifile_fi); } MUTEX_SDCARD_GIVE; } } -
hi save my patches with FILE_WriteBuffer like this: // 16Bit Pitchbend-value to 2x8Bit value - to get a saveable format PB8[0] = * ((unsigned char *)&PB[track]); //low byte PB8[1] = * ((unsigned char *)((&PB[track])+1)); //hi byte //Fill CC-Array of Clip CC_SD[0] = clip_is_virgin; CC_SD[1] = Rythm; CC_SD[2] = Loop_Length[track]; CC_SD[3] = BPM; CC_SD[4] = SetDecayTime[track]; //Note-Data of Clip sprintf(filepathS, "sq/%d-%d.sq", track, clip); //First Pattern --- will be later copied 511 times! sq/8-512.pb FILE_WriteOpen (filepathS, 1); FILE_WriteBuffer((u8 *)file_typeBank, 4); //"SQ01" = 4 Positons FILE_WriteBuffer((u8 *)CC_SD, 32); //Track Variables like Looplenght FILE_WriteBuffer((u8 *)PB8, 512); //2x8Bit Pitchbendvalue x 256 Steps = 512 Blocks FILE_WriteBuffer((u8 *)Sequence[track], 2048); //Track, 256Steps, 8NotePolyphony 1x256x8 = 2048 Blocks FILE_WriteClose (); i want to save the Pitchband also, i but this is 16bit, and that cant be Written, i need 8Bit Values, so my my 16Bit Pitchband-Variable is named PB[track] it is done by: // 16Bit Pitchbend-value to 2x8Bit value - to get a saveable format PB8[0] = * ((unsigned char *)&PB[track]); //low byte PB8[1] = * ((unsigned char *)((&PB[track])+1)); //hi byte so far ok, QUESTION is: how to combine low and hi byte back to the 16bit Variable PB[track]? (after FILE_ReadBuffer is done) next question is how to split a multiy-array in low and hi bytes variables: for example PB[track][256] --- which is the Pitchbend-Information - over 256 Steps in a Sequence. thx 4 helpß
good point! its far better the ui is updated directly via srio then via midi sysex cc or notes.. 32th blinking of 16x2 trigger indicatos bling and blang via midi making trouble... for example i have connected a sequencer to a blm(acts as controller) but all trigger indicators are leds from the sequencer to give timed indication isnt there any mb bus? from core to core
MidiBox Cool Diy Device But Only For C-Code Experts
Phatline replied to zener's topic in MIDIbox HUIs
oh i had the same, thoughts back in the days... not knowing what a external c-function is, and where the hell they are - thats a thing to learn first to get a point how TK arrange things... since i learned how to wiki, i also document that - for me to remember - and for other to get some inspiration. hmm i see three options: * learn how to NG-Script * learn no NG-Script - learn C instead + get the compiler running on your Computer * ask someone who do the programming for you... but if you want to change something after - you probably have to script or c again. i personally never learned c in shool or mentor... back in the days when max4live come up, i startet with graphical programming (Without c), t he programm i created, i later programmed on TK MIOS32, and i learned only the c-things i needet to get the programm running which i already know -via internet youtube and google researching- i was knowing what i need and want... i cant learn anything that i dont need @ the moment ... i am no expert too, but i make my own devices and jam with my bandmate every week since years... a "only musican" should just ask a friend to help him a musican which want to use custom or setup a custom midicontroller - have to explore that matter and that take time and entusiasm -
not use a mpx16... hmm lot of your quests cant handle a akai mpx16, but its small, has envelops, it depends on your "typical"-sampling time for a patch... because here it is very limited! and it has a lot of BAD things like: https://www.reddit.com/r/synthesizers/comments/61ivbx/akai_mpx16s_midi_implementation_is_shit/
