NaturalGeek
    11
Everything posted by NaturalGeek
  1. Thanks Thorsten! is it possible to store the patch on button release?
  2. Hi * Is there a way to persistently and automatically store the learned midi assignments? Thx!
  3. NaturalGeek
    CVIn
    Hi all, i would like to read CV. in theory this is achievable with the ainser64. but only from 0-5V. I need -15 - +15v Is there a simple solution for this? thx
  4. hi there, i'am wondering if there is any midibox based sequencer which is somehow like the doepfer dark time. just without any display or menue just very simple with knobs and switches to turn the step on/off and CV of course.
  5. HI all, i don't know if my PIC contains a bootloader, since MIOS Studio can't communicate with the bootloader, iam unsure if it is not flashed or something is broken. - does the bruned bootloader send any midi message on startup to identify themself to MIOS Studio (which i can sniff to check if the bootloader is installed)? - if it does and i don't get a midi message, i still don't know if the circuit is broken or if there is no bootloader installed - so is there a way to check for that without using midi? like some PIC Ports which are Lo or Hi only if a bootloader is installed? Thx Marco
  6. i replaced the hardware multiple times in this period of course. ^^
  7. as soon as everything is final, i will put the stuff into the forum, however my domains/servers are running since 12 years and there is no content which has been removed since the start ;) so, no worry
  8. Thank you jojjelito, since i'am currently working on a first test (its just a simple 24 knob midi controller) i'am on evaluating pots. i will now order 10k alpha pots which feels very nice. for the test controller, i will order some moogish knobs, for the patch editor they should be a bit more thin. As for the pot takeover, i will have a look for that later, i will first of all finish the case and the hardware for the second device (since i already used all PCB for the simple midi controller (which is actually my first midibox not the programmer) however. i've now done a front panel for the PG-8000 too. it fits to the hammond case 1441-18. and this case fits more or less exactly on top oft the DW-8000! i've added the front panel to my main post!
  9. Hi all, i'am about to create patch editors for several vintage Synthesizers and Effect Units ( primary the KORG DW-8000, Oberheim Matrix 1000 The Boehm Dynamic 12/24 and the Dynacord DRP-20 Reverb) This is my first Midibox Project, i will just put all configs, faceplates (schaefferag) and additionally used parts into this thread to make it available for the masses Additionally i want to thank all the people who made the midibox project possible. This is an absolutely awesome project and i'am very happy to have the possibility to use such great soft- and hardware for free. Thank You! The rock solid enclosure should have the size of the params table on the DW-8000 to place it on top of the synth. MIDIBOX MODULES: * CORE_STM32F4 (Discovery) * MIDI_IO * AINSER64 ADDITIONAL HARDWARE * DISPLAY: 2x20 VFD Display (http://www.ebay.de/itm/391029428633) * KNOBS: ???? (black with light blue caps (as the dw8000) * POTENTIOMETERS: 10K Alpha Pot (http://www.tube-town.net/ttstore/Potentiometer/Alpha-Potentiometer-16mm/Alpha-10-kOhm-linear-16-mm::746.html) ENCLOSURE * CHASSIS: Hammond 1441-18 (http://www.tube-town.net/ttstore/Chassis/Hammond-Chassis/Hammond-1441-Serie-Steel/Chassis-1441-18-black::209.html) * FRONT PANEL: Schaeffer AG - not verified! http://ketahole.de/klingklang/pg8000/files/panel.fpd or http://ketahole.de/klingklang/pg8000/files/panel.svg or http://ketahole.de/klingklang/pg8000/files/panel.dxf CONFIGURATION barely tested! * NGC: http://ketahole.de/klingklang/pg8000/files/dw8000.ngc * NGL: http://ketahole.de/klingklang/pg8000/files/dw8000.ngl
  10. dankeschoen! :)
  11. hi there, is there a way to define labels for values? just like in a Hash, to make it possible to iterate through a set of strings instread of 1..16 like: 1 => saw 2 => sine 3 => square or poly/unison etc?
