Hi all,
I've been lurking around here on the forums for a while now. Some years ago i built my first MBSID v2, completely based on the modular mbhp. The device didn't last very long as i decided to do some modifications and then never finished the work. So poor little sid had to wait for some time, but now i'm back putting the system back together. this time with a mb6582 board.
Now, this board is actually finished and tested and looks good and is supposedly working. But there's this one annoying problem i can't get rid of:
i can upload to the first core (id 0) and it clones to the second core (id 1). After that it resets again and gets stuck for a while with this display output:
Cloning Slave 02
Address: 0r Reset
After this core 4 (id 3) gets cloned properly.
Sadly, uploading the SID application to each core separately doesn't solve the situation. The problem stays and after every "cold" boot, the problem occurs again, sometimes even after the reset after core 3 got cloned.
important to know: i'm working with an adapted setup_8580 at the moment, the control surface i (re)built is customized and a mix between mb6582 cs and old sid v2 cs. but that's another topic, first i have to get the thing to boot properly.
I've also tried all the other .hex files, but they don't help either.
Well, i've already spent way too much time on this, any input is appreciated,
cheers,
Jakob
