Hi! So I have been coming on and off for some time (maybe since 2012) reading, investigating, getting ideas, because I want to build a controller similar to a BCR2000 that will do what I need.
	I have my BCR2000 since 2011, still in use, but it was obvious, pretty soon, that it lacked the feedback I need. Feedback as info about what is happening. Leds are insufficient and to just have numbers only from 0...127 is a pain, when I need to see numbers and figures like "Hz" or "3/4" or "a sine symbol", "parameter name", "Instrument number/name".
	So, here I am. MB_NG is now quite advanced and I've also reached a point where I have to ask questions to fill my lack of knowledge and findings of what is possible to do in MB_NG so I can conclude my idea and start doing.
	For now there is no need to be technical, I haven't started the project, so I don't have any hardware, nor do I know programming. When the time to go more in depth arrives I will ask. So bear with me.
	Questions (please answer with question number to avoid confusion):
	1.1-
	Usually values are presented from "0...127", so 128 positions. In the BCR2000 I can program for less than "0...127" (128), ex: "0...100" (101) or "0...3" (4) or "0...9" (10). Can I program for more, ex: "0...999" (1000) or "0.0...999.9" (1000.0) or "0...9999" (10000), even at the cost of various turns of the encoder?
	I'm referring to the values/pulses/positions (whatever the name, and I mix them here, sorry) on the code for the encoder, not physical pulses of the encoder. I think its called MIDI messages or Channel Control Change messages?!
	Why would I want that? Well, precision. Precision for the value of a parameter (automation of point/vector of that parameter included). I use cubase, and back in SX3 version I remember something like "6xxxxx,xxxx" possible positions, maybe NRPN values "16,384"?! It could have been, but I remember more decimal houses. The current cubase has "1000.0" positions. When I want a certain number, I want the exact number, not an approximation. Take frequencies as an example, 128 positions and I'm bound to approximations that are far from being near the value I want.
	1.2-
	Do the physical pulses of an encoder have any influence on this?
	1.3-
	Assuming that there is no way of changing the format of "0...127" positions, can I assign specific values (cubase values "0...1000.0") to specific positions (encoder code positions "0...127"), ex: cubase value "745.3" to encoder code position "86"? Also have this translated to the actual parameter value, ex: "hz".
	2-
	Given that 128 encoders are used and in use (ex: controlling vst parameters) can one of them still be used for Standard Control Surface menu system (by pressing "exit" or "shift" button) and of course still be programmed for a parameter?
	In the BCR2000 one just selects the encoder and rotate the various controls, that are assigned from fabric, even if the encoder being programmed is one of the assigned controls.
	3.1-
	Is it possible to create shortcut buttons that directly call for an entire preset instead of having to go select one from SD memory card, through the Standard Control Surface menu system?
	3.2-
	If yes, is it also possible to assign those shortcut buttons to a parameter of the DAW (one button executing 2 functions at the same time)?
	4-
	Banks, do they have a limited number?
	5-
	Is it possible to Bank Banks?  ex: Lets say I have one group of physical encoders with 2 banks and another group of physical encoders also with 2 banks, so each group can change banks independently. Can I have a 3rd, global bank, that by selecting bank 1 it selects both banks 1 of the two groups of encoders?
