victorm
    9
Recent Profile Visitors
victorm's Achievements
MIDIbox Newbie
  1. Hello friend, sorry for the delay, I had a week of hellish work in the workshop. I understand that setup is enough. I have tried the panel that you comment from ableton live configuring midi in midi out, but it has not worked, maybe I should use some previous version of CTRL?
  2. Hello, today I took a big step, I managed to install the bootloader, then install mine and later the file midibox_sid_v2_044, I'm trying to investigate what is sid_filter_table.hex setup_sammich_sid.hex, I don't know if I should install them too. The project sounds, I tried with ableton and get to hear an oscillator and send notes. I was testing with the CTRL guide to be able to handle more parameters by running the program under ableton live as a vst, but I haven't gotten it to work yet. Little by little . Some of you have worked some graphic version to control the midibox_sid program. Greetings And happy Thursday! :)
  3. The problem is that the two dins do not physically have pins, maybe it is poorly manufactured. I have to buy 2 new ones with the 5 pins.
  4. missin pin 2 and 4 lol
  5. Hello friends, I have been reading the instructions well, I thought I was roasting the microprocessor badly. The story is that it is a project of my Father, he is 65 years old or older. XD, he bought it to do the V2. and also the minimum project with which I am now helping you. Today I discovered, after coming from fk!$ the doctor, :) the problem, the female din5 connector, you only have 1, 3, 5 pin. I could never get in touch with the core, maybe wireless. Tomorrow, if my ankle allows me, I'll go find a din5 with all the pins. Sometimes we look for problems where they don't exist. Just putting the oscilloscope on pins 2 and 3 of the octo was enough to see that there was no sign of a signal. Tomorrow I will tell you how it is, I am very grateful for your comments.
  6. 104/5000 I go to the doctor now, then I make some screenshots about my studio and the lcd screen. :)
  7. I have this pcb. My pic was deleted several times, but it's still functional, I didn't know that there was a bootloader inside, so what do I need to leave my pic like the one in the photo? I charge a bootloader first? greetings and thanks for helping this newbie!
  8. I am going to start the process from the beginning, the pic will be deleted with the programmer, I have the pic and the programmer to burn the file you tell me. I am lost in this. What should I do first? Thanks and best regards friend!
  9. Hello friends, I am new and this is my first project, I bought midibox sid2, the small version. My odyssey is to load the necessary software inside the pic, I have a USB charger that supports this IC. I would like to know what HEX file I have to load into the PIC or if I have to load several. I've been reading something about a bootloader (bootloader_v1_2b_pic18f4685.hex.) I also have a file inside a folder called midi. Please, if someone can explain the loading sequence of the software, it would make me a father.
