gloom303
Everything posted by gloom303
  1. Hi all, New to the MIDIbox SID / sammichSID, and to the forum, but definitely not to MIDI, computers or music production in general. I got the sammichSID a few days ago and I can't seem to use it for more than 5-10 minutes at a time before it stops receiving MIDI. My DAW (BitWig Studio) throws up this error and I have to un/replug my MIDI interface to get the connection back. I know, I know; that suggests a Windows issue, which it might very well be, but.. I suspect the MIDIbox SID / sammichSID-unit is the culprit (something in its MIDI receive handling) because I am literally surrounded by synths from the 70s and up until now, and this is the only time I've ever had this problem. So far I've tried: Using a different MIDI output on the Alyseum Using a different MIDI interface Played MIDI notes manually Sent recorded MIDI notes from the DAW timeline Running the MIDIbox SID in mono mode Taken out one of the SIDs and running it in mono mode Tried two different PSUs (the current one is a proper quality Elektron 12VDC one that I normally use on the Analog Heat) Checked the MIDI output from BitWig Studio with MIDI-OX just to check if it for some reason was sending something bogus, which it wasn't ..and I'm none the wiser. I know MIDI is a pretty dumb protocol, but the error reported comes from the Windows MIDI Mapper, and when I Googled around a bit I found this error tends to happen in a wiiiiide variety of situations, none of which apply to my particular hardware setup of course, so again I'm none the wiser. That's why I wanted to check in with the forum here to see if anyone has been through something similar. I searched through the forum for the phrase "Undefined External Error", but nothing came up so while I'm not hopeful that a solution exists, perhaps someone with more experience than myself with this particular unit has some suggestions.
