goyousalukis
    387
    5
Everything posted by goyousalukis
  1. If you can do it easily, disconnect everything from the core except the LCD. Load only MIOS and troubleshoot until you get "READY." on the LCD. That way you know that MIOS is working and so is your LCD. It really seems to me that you have a problem in the LCD wiring. With only the Bootstrap loader, you should see a row of blocks on the top row only. Then after MIOS is loaded you should see "READY." What type of display do you have? Can you post a link to its datasheet? If you disconnect the backlight, you should still see text. The contrast pot should make a big difference - from nothing to very dark. Justin
  2. Thanks for your replies, thats what I've done so far, I just don't seem to be getting the 12V DC yet. I'll double check everything. illogik, I bought the IC's from Mouser part num: 512-LM324AN and 570-8038CCPD Justin
  3. Hey, so I'm trying my hand at the MidiBox LFO extension by TK :http://www.ucapps.de/midibox_ext.html I am building the power supply first: http://www.ucapps.de/midibox_ext/lfo/lfo_powersupply.pdf I bought this transformer from Mouser: http://www.mouser.com/index.cfm?&handler=data.listcategory&D=*553FP3085*&terms=553-FP30-85++&Ntt=*553FP3085*&Dk=1&Ns=MfgrPartNumber%7c%7cSField&N=0&crc=true Is this ok? I am unsure of how to connect the rectifiers to my transformer. To get 15VAC, I have to tie pins 5 and 7 together and 6&8 together. The schematic shows three outputs to the rectifiers, but I only have 2 - do I just connect each of the 15V outputs to the ~ terminals of the rectifiers? Thanks for your help... Justin
  4. Just to clarify - each Sid Module only has 1 output, so a 4xMBSID only has 4 channels. Justin
  5. You need to download and install MPLAB and perl. (see http://www.ucapps.de/howto_tools_mplab.html) Then open the project in the directory you are working on(.mcp). Then re-assemble the main.asm. After that run the convert.bat file in the same directory. This converts the main.hex to main.syx. Then send it to your midi box. As far as the device ids and stuff. You should only need to modify the code for the first(cs) core. The other cores should just get the proper .syx file from the sid directory i.e. 2nd core gets setup_6581_slave1.syx and so forth. Remember that your second core needs to be id 01, then 02, and 03. Justin
  6. Well, I have used 100k linear pots from a joystick with MidiBox, and they worked great. The big question is are they really Linear? Faders from an audio mixer are almost always Audio Taper, not linear. Justin
  7. Hey that was it! I have to play the bass through my computer, cause I'm in South Korea and my bass amp is in El Paso. Texas. The noise goes away when the monitor is off. So would a flat panel LCD fix that problem? Maybe that would be a good excuse to upgrade my display. Thanks uclaros!
  8. goyousalukis
    Help??
    You will also need a power supply. If you still have an old C64 power supply you can use that, but you need to buy some more parts to build it. Here is a link to the schematic: http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf Or you can use a "wall-wart" type powersupply that delivers at least 12V . You will also need midi-sockets. You also need a multimeter. This is to measure voltages before putting in chips. You can also use it to check for bad solder joints. A digital multimeter is best, but you can get by with a cheap analog type too. Hope this helps. Justin
  9. goyousalukis
    Help??
    To clarify - When I said no programming, I meant you don't have to write any code. The pic does need to be programmed with the bootstrap loader. For this, you either need to make the JDM programmer, or if you buy the PIC from SmashTv along with the kits, he will program it for you. Yes, the kit is pretty easy to put together. If you print out the schematics, you can line up the parts numbers with the PCB and figure out what they are. For instance IC3 is a voltage regulator. If you don't know what a voltage regulator looks like, go to http://avi.dezines.com/mbhp/info.html and click on the core module. SmashTV has made an excellent visual guide to each component. Hold the mouse over any item, and it will show you what it is. The key is to take your time and make sure each solder joint is perfect. Take a look at the solder joints on a professionally made pcb, and try to get yours to look the same. You could also go to RadioShack and buy a small vectorboard and practice soldering some wires to it. Justin
  10. goyousalukis
    Help??
    Yes, the LCD does make everything easier. Especially troubleshooting. There is a way to change the midichannel via a sysex message: So you don't have to reprogram the pic. Just send the sysex message. Justin
  11. goyousalukis
    Help??
    You don't have to have an LCD. The bare minimum is just a Core and A Sid Module. There is no kit for the LCDs, you just buy the size and style you want. Here's an example for one on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26206&item=3842391981&rd=1&ssPageName=WD1V You will want at least a 20x2 size one if you get one. Once the MbSid is built, you can play the sid(s) with any midi keyboard. Or play it with any Midi computer program. If you want to modify the sounds, you hook the midi out of your computer to the MbSid's midi-in, and then use Thorsten's JSynthLib program to edit the patches. You will probably want to buy at least one bankstick - as this lets you store 128 patches at once. Each Sid is assigned its own midichannel, and it will respond to control changes on that midichannel. If you have more than one, you can assign them to the same channel, or different channels. You won't need to do any computer programming Thorsten has done it all for us. You just build the module and play. There are also a bunch of example patches that TK has created to show how to make sounds. Justin
  12. Through very careful research, I've come to realize that the noise varies with the orientation of the bass. If I swing it to the left, I get no noise at all. I guess it is some sort of radio interferance or something like that. Thanks for your help Smash... Justin
  13. Just connect A2 and A3 on the second AIN to ground. This will prevent the random midi events. A LFO is a Low Frequency Oscillator. In that example, the oscilator(s) are connected to a pin on the ain module. The LFO sends a voltage from 0 to 5 and then back down at a speed(frequency) set by a Pot. The Midibox reads this and converts it to a CC Message(0-127) just as if you were turning a knob at a regulated speed. Hope this helps. Justin
  14. Glad to help. I forgot to tell you: To test the rating of a pot, you measure the resistance between the middle lug and one of the other lugs. The highest resistance you get is the rating. So if you get 9.9k ohms, you have a 10k pot. Justin
  15. goyousalukis
    Help??
    Hi Daveojo, As Dave said, this is not a project that uses the whole commodore 64. It only uses the sound chip. That is because MidiBox step A uses an LCD to display the control menu for the MbSID. This is not a site that shows you how to do anything you want with the C64. It shows you how to make Thorsten's MidiBox Sid. Another user posted a link to something that you might be interested in. I think it was some C64 software you loaded and then controlled the C64 via a serial port on the PC. I will look for it and post it if I can find it. Justin
  16. Do you have 3 wires going to the pedal?, or just two? You need 3 one for groud one for +5v and then the one that goes to the AIN. Justin
  17. Ok, if your LCD says MIOS 1.7 and then says ready, that means that MIOS is loaded, but no other application. You need to upload an application via syx, before your din or dout boards will be used. Send the main.syx file from midio128_v2_1a.zip to your core, using MidiOx, or the new sysex tool. Hook up your DIN to the core and then press some buttons, you should get some midi events in MidiOx. Justin p.s. if you make changes to the code, you need to re-assemble the project, convert the hex top syx using the convert.bat, and then send the main.syx file.
  18. Hello, I recently accuired an electric bass with the following active circuitry: http://www.artecsound.com/se3.html It sounds great when the Balance pot is in the middle of the two pickups, but as I turn it either way, I get a high frequency hum introduced. There is no noise when the balance is in the middle. Anyone know what I can do to try and fix this? Thanks, Justin
  19. Yes, you are correct, although you can load the with_cs.syx app even if you don't have it yet. That way you won't have to reload it later. You won't need to edit anything if you keep the same pin assignments Thorsten used for the DIN/DOUT boards. If you do change the pin assignments(for the buttons, LED's and encoders), you will need to make the changes in the .inc files and then reassemble the source code using the MPLAB IDE. Justin
  20. Here is a schematic: http://www.tonepad.com/project.asp?id=18 this one looks easy here's the mouser partslist http://www.lucyjordan.com/interest/noisegate.htm Justin
  21. The eagle board files are all free at www.ucapps.de. http://www.ucapps.de/mbhp_din.html http://www.ucapps.de/mbhp_dout.html just look for the .brd files. Justin
  22. Yes, unless this is really loud, then it is normal. It is especially noticable on the wavetable sounds, because the wavetable keeps going and going.... Justin
  23. it is on the top because it is a "Sticky Topic"
  24. If you load an application like the mb64e that doesn't use the AIN module, you shouldn't get any random midi-events. That might be a starting point. Another option is to connect pins A0 - A7 of J5(on the core) to ground. This will guarantee that there is no jitter from open pins. Justin
  25. Yes, but what happens when you move away, and their MidiBox stops working? They have no direct knowledge of the build process, and haven't learned the essential trouble-shooting process that is involved in DIY. Are you going to sell them a guaranteed service contract for 1 year, 2 years- forever?. They can't expect help from this forum, since as previous posts have said, they have not invested the time. If they dont "have the time/tools/skills to complete the job" then they should pony up the dough and buy a complete product from one of the many manufacturers. I think you are opening up a can of worms, but that is just my opinion. If they are friends of yours, then I would at least make them be involved in the building of the PCB's, and the loading of the software. Perhaps charge them as if you were teaching a skill. Just my opinion. Justin
