pilgrims1
    30
About pilgrims1
  • Birthday 01/01/1
  • Gender
    Not Telling
pilgrims1's Achievements
MIDIbox Newbie
  1. NO! I want to save core module.... ^^ and... impossible.... I will try MIDImon...... Thank you....
  2. Yes....!! I want to send static two value... rather than send increase/decrease value of one cc command..
  3. Thank you Ultra..... But... I'm starter of MBHP..... so.... Teach me more detail for this.... can you??? Thank you very much....
  4. Is ti possible?? Example... CW turning encorder send CC#10 CCW turning encorder send CC#11 possible in 64E ?? Thank you !!
  5. Thank you for your reading & reply ^^*
  6. :) Thank you..... and sorry.... ^^*
  7. Dear ......... ^^* How can I build 128 button & 128 LEDs with 64E (without second core module link....) Please ..... Teach me the way....
  8. Thank you everyone who interest in my question..... Ofcause I know... 16 Led-Rings with 11 led... pdf.... But My interesting is saving DOUT Modules...... ^^* Is it possible with some modification code??? Pardon me.. my toddling is very slow... ^^*
  9. Can I connect 24LED rings(consists of 8 leds) with one DoutX4 module?? If possible? thats good to me ..... I will connect 96 LED rigns with only 4 DoutX4 module... ^^
  10. Thank you for your interesting .... Just in my opinion .... Nuendo's Generic Remote support Note message So each channel can use 88note ok? And 16channel x 88 = 1408 note can be used with one midi port... Is it possible? And data band with is not a problem (in my thought). This 1056 LEDs is not constant in out messages... like smpte mtc.... They sent or recieved few times..... It's purpose is just viewing Nuendos's Mixer's status..... Screaming_Rabbit !! Teach me more.... ^^*
  11. Wilba ?? ^^* I plan to make so big control surface for my stuido (with Nuendo) I will make 48channel (6 x MBHP LC) control surface... And I put 8 insert ON, 8 Send On, 4 EQ on LEDs(20 LEDs), Automation Read and Write LEDs with push button to each channel.. As a result... 2 Din 22Dout is required at each 48 channel..... So 22 x 48 = 1056 Dout is required... Wilba?? 1056 Dout is possible with one Core module?? And How many DOUTx4 module is required??? Can I change code myself?? Thank you for your advise... ^^* Help me please....
  12. Hm..... I want to make Insert On, Send On, EQ On indicator to every 48channel (thru Generic remote in Nuendos) So... one channel consists of 20 LED ( 8 insert, 8 send, 4 EQ(eachband)) So..... 20 X 48 = 960 LEDs ... If I use only 6 insert, 6 send 4 EQ on LEDs... It will be 16(6+6+4) x 48 ch = 768 LEDs
  13. Of curse... I want to Led matrix... but.. I want to assign to each LEDs from each midi cc or note message. Wilba?? Is it possible ?? If possible?? That is good to me for save money ( use only few core modules and Doutx4 modules) I'll need only two cores and 8 Doutx4 moduls. If not...(can not assign midi message to each LEDs) How many cores can be linked(maximum)??
  14. How many cores can be linked??? Can I link up to 6 core(24 x DOUTx4) for 768 leds at one midi port???? Thank you ...
