pilgrims1
    30
Everything posted by pilgrims1
  1. NO! I want to save core module.... ^^ and... impossible.... I will try MIDImon...... Thank you....
  2. Yes....!! I want to send static two value... rather than send increase/decrease value of one cc command..
  3. Thank you Ultra..... But... I'm starter of MBHP..... so.... Teach me more detail for this.... can you??? Thank you very much....
  4. Is ti possible?? Example... CW turning encorder send CC#10 CCW turning encorder send CC#11 possible in 64E ?? Thank you !!
  5. Thank you for your reading & reply ^^*
  6. :) Thank you..... and sorry.... ^^*
  7. Dear ......... ^^* How can I build 128 button & 128 LEDs with 64E (without second core module link....) Please ..... Teach me the way....
  8. Thank you everyone who interest in my question..... Ofcause I know... 16 Led-Rings with 11 led... pdf.... But My interesting is saving DOUT Modules...... ^^* Is it possible with some modification code??? Pardon me.. my toddling is very slow... ^^*
  9. Can I connect 24LED rings(consists of 8 leds) with one DoutX4 module?? If possible? thats good to me ..... I will connect 96 LED rigns with only 4 DoutX4 module... ^^
  10. Thank you for your interesting .... Just in my opinion .... Nuendo's Generic Remote support Note message So each channel can use 88note ok? And 16channel x 88 = 1408 note can be used with one midi port... Is it possible? And data band with is not a problem (in my thought). This 1056 LEDs is not constant in out messages... like smpte mtc.... They sent or recieved few times..... It's purpose is just viewing Nuendos's Mixer's status..... Screaming_Rabbit !! Teach me more.... ^^*
  11. Wilba ?? ^^* I plan to make so big control surface for my stuido (with Nuendo) I will make 48channel (6 x MBHP LC) control surface... And I put 8 insert ON, 8 Send On, 4 EQ on LEDs(20 LEDs), Automation Read and Write LEDs with push button to each channel.. As a result... 2 Din 22Dout is required at each 48 channel..... So 22 x 48 = 1056 Dout is required... Wilba?? 1056 Dout is possible with one Core module?? And How many DOUTx4 module is required??? Can I change code myself?? Thank you for your advise... ^^* Help me please....
  12. Hm..... I want to make Insert On, Send On, EQ On indicator to every 48channel (thru Generic remote in Nuendos) So... one channel consists of 20 LED ( 8 insert, 8 send, 4 EQ(eachband)) So..... 20 X 48 = 960 LEDs ... If I use only 6 insert, 6 send 4 EQ on LEDs... It will be 16(6+6+4) x 48 ch = 768 LEDs
  13. Of curse... I want to Led matrix... but.. I want to assign to each LEDs from each midi cc or note message. Wilba?? Is it possible ?? If possible?? That is good to me for save money ( use only few core modules and Doutx4 modules) I'll need only two cores and 8 Doutx4 moduls. If not...(can not assign midi message to each LEDs) How many cores can be linked(maximum)??
  14. How many cores can be linked??? Can I link up to 6 core(24 x DOUTx4) for 768 leds at one midi port???? Thank you ...
  15. Thank you .... There is good product and wanted swtich(highlyUSA) ... Thank you .... I'll try to purchase from there.... ;)
  16. Can you teach me about.... Which LED illumniated Push button for MBHP LC with good price and good appearance is best for me??? Some NKK's button is so expensive... ;D Is there recommended Switch(LED illuminated) ???
  17. ;D I want to know just that 4LED bar array (per channel) is possible... and suitable MBHP is which?? (MBHP 64e or MBHP midio128????) Teah me please.... I will make huge control surface with new approching.... Please Help me.... I already use 2 control surface US-2400 and MCU But I want to huge and new control surface for more control until not use computer keyboard....
  18. I want build 64channel metering LED(consist of 4 or 3 LED per channel) with select button llike this... more details here.... Build 64 channel level meter(4 led per channel) and assign it to every Nuendo's channel level thru "Generic Remote" And build select button and LED(selected indicator)... Conclusionaly ... I could (want to) see every channels's level overview and which channel is selected... Please teach me.... which project is suitable for this purpose... Can I make it with only one project??(with slave core module......) Thank you for your reading and advices....
  19. I have tried get custom C-LCD for our MBHP-LC (55x2) but faild (I had asked manufacturer in my country about 55x2 c-lcd) but but but ..... Every 8channel control surfaces employs 55x2 LCD ( MC, Command8, O1X.....) Is there anyone who can find 55x2 C-LCD supllier of these manufacturers ???? Is there anyone who can find manufacturer's name by opening who's MC.... (May be ... it's lcd contain manufacturer's inform... ;D) ?? Let's find that factory !! ;D ^^* Oh my God...!! 2 2x24 lcd is best at this time??? :'( :'(
  20. I have tested my system about your comment.... But in my nuendo's Generic Remote works very well with every action is running well , good response, good reflect perfect situation... Testing preferences => Nuendo with US-2400 (with dual mode - MC & Generic midi controller mode) I have assigned 3 knob1-3 to channel 1-3 solo I ahve assigned 3 knob7-9 to channel 1-3 mute When I solo or mute 1, 2-3, -9 led rings reflect all this situation..... Thanks.... ;D
  21. And I discoverd that "Generic Remote" support many many function and parameters and commands... So... I will make some brilliant function.... Generic Remote offer "selected" ... so I will make 64 button & LEDs willing to direct select from central of my control surface rather than use individual select button (Because.... If I struct 32 or 48 channel MBHP LC.... my hand reach to channel 1-4, 45-48 with difficulty. ^^* ) Generic Remote offer so many commands.... And I will make 64 or 128 buttons(no LED is required) for many many commands.... So ... In my covetous... I want to make buttons for as all function(command) as possible Teach me the suitable MBHP (64? 64e? 128?) for above use.... ????? Thankyou for your reading and valuable opinion... ^^*
  22. If there is no other choice except 2 2x24 or 2 2x40?? I wanto go 2 2x24 for more narrow cofigulation huge control surface.... ^^* Thank you for your reading and advices....
  23. 2x40 or 2x24 is best?? If I could custom order 2x55 C lcd for my LC emul.... Can I use it with MBHP LC ??
  24. Thank you for your interest and advice... I'll refer to your comment.... 2x24 LCD..... So... How many character sacrified ?? in theory... 6(=55-48)? If it would be not big problem to using controller with nuendo.... I'll certainly follow your advice.... Thank you for your reading and valuable opinion...
